Likes Likes:  3
Results 1 to 17 of 17
Thread: Trike front tire - narrow versus wide
    30+ Posts riderdave's Avatar
    Sep 2013
    Tyler, Tx, USA
    Cool Trike front tire - narrow versus wide
    Need some guidance help here. Currently running a narrow 120/70/19 front tire on a Harley ultra motor trike . Was wondering if anyone had an opinion on using narrow front tire versus fat front tire. Trying to improve handling in corners. At present, when powering out of a curve the front seems a bit light and wants to skip unless I back off a little. Would a "fatter" front tire help?? Thanks
    Riderdave:Dorag:
    Quote Originally Posted by riderdave View Post
    Yea .. a little .. "skip" is kinda common on the trikes ... a fatter flatter front tire would work better, the wide round is not needed as the trike doesn't lean ... I'm hoping Avon comes out with a trike designed front tire for the hd's ... in the meantime, I'll be going with a rear mounted backwards for better handling when I need a new tire.
    I might be wrong, But i would think a wider/fatter front tire would make the steering harder/heavy.. As it is now a lot of first time Trikers complain the steering is hard/heavy with the stock tire...
    Just to add i had a 2013 sportster with a fat front tire and you had to really force it into turns...
    Gone But Never Forgotten dirtdobber's Avatar
    Jul 2011
    sand mountain, AL
    A larger front tire will help with that.
    I have a 110 x 19 on the super glide trike and it will slide if I hit a curve too hard.
    If possible go to a 130 tire, our goldwing doesn't do it but the mystery super glide with a 110x19 front tire does it
    http://i25.photobucket.com/albums/c5...an_cross_f.jpg
    20015 freewheeler
    2005 113 pro twin super glide
    2010 ss106 wide glide
    2004 1800 VTX custom
    2012 GW RS
    5+ Posts Trikin's Avatar
    Sep 2015
    Keytesville
    I had a stock sporty tire on mine when I first got it, put 300 miles on it and decided it needed to go. Upgraded to a fatter tire and no longer feel like every rock in the road is bumping my tire around.
    If you noticed ... I said fatter flatter tire ... easy mistake.
    Our SG has a 130/70/18 front tire and steering effort is very linear and precise. It's gonna get a good workout next month in the TX Hill Country so I'll know more about it,then.
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    They now have an 18" and a 16" (OEM Tri Glide size)
    http://www.avonmoto.com/products/cru...om/cobra-trike
    Bob
    100+ Posts
    Jul 2012
    W.Rutland, Vt.
    Quote Originally Posted by HDB0B View Post
    Bob
    Thanks for that info Bob .I want to try that Avon trike tire.I have an 18" Anarchy wheel on the front.I have always had good results on my other Harleys with Avon Tires.
  11. #10
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    Quote Originally Posted by jwkhd1 View Post
    Always liked the Avon tires - Great grip.....but never met one that gave me great mileage.....jc
  12. #11
    850+ Posts rwhgme's Avatar
    Sep 2010
    Shawnee,Ks
    15000 mile warranty..and 137.49-174.00 size dependent.
  13. #12
    100+ Posts KeithsBMW's Avatar
    Dec 2013
    Dandridge, TN.
    Yes a fatter front tire will improve handling in corners on dry pavement, may hydroplane sooner on wet. Hannigan has a 180 Front End package for HD's. Excellent mileage from tire. Wide footprint on road.
  14. #13
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I've been running a reartire, reversed, on the front for about 12,000 miles now.
    Not only is the rubber holding up really well...I may get 25-30k out of it. The most I've gotten out of the stock tire is 18k.
    It also has far more grip than the stock front tire. I've ridden in several downpours, and it does better than the stock tire, even in 2 inches of water.
    It is the Dunlop American Elite, MT90 B16, and is wider than the stock front tire.
    www.DKCustom.com
  15. #14
    Oct 2015
    Lakewood
    Default rEvers ed rear tire
    What is the point in reversing a rear tire when installed on the front of a trike?Trying to get fimilar before I buy my trike.
  16. #15
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by tacojunkie View Post
    There is quite a bit written about it, but the basic premise is that the rear tire is spliced together with acceleration in mind, so when putting in on the front, the splice should be for braking force, thus the reason for reversing it.
    My concern was the tread for the rear might not channel the water well when it is reversed up front. That has not been my experience. With the tire I'm running, it does better in the rain than the stock one.
    www.DKCustom.com
  17. DKCustoms postbit
  18. #16
    Jul 2014
    S.E. PA, USA
    Here is a link from Avon tires explaining directioal arrows and tread splice. http://cyrilhuzeblog.com/2009/08/23/...by-avon-tyres/
    Bob
  19. #17
    Because of limited selection,I'm just not a fan of 19" bike tires. However,here's a option I would look at,Dave.
    https://www.denniskirk.com/544553.sk...CPdBoCl9jw_wcB
  1. Bars. Wide or narrow, tall or short?
    By roadking2 in forum Harley Trike Conversions
    Last Post: 01-21-2015, 12:10 PM
  2. tire size for rear tire on front? 2007 goldwing trike
  3. how wide can tire be?? i have 18x3.5 front whee for trike..l
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 12-07-2013, 12:55 PM
  4. Front tire on trike
    By saab9k in forum Tires, Wheels, Brakes, Front End
    Last Post: 04-03-2013, 07:05 AM
  5. front tire on trike
    By roscoe 07 in forum Honda Trikes
    Last Post: 01-13-2011, 03:13 PM
Tags for this Thread
