LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  24
Thanks Thanks:  1
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 54 of 54
Thread: Air Intake Plenum Break
  1. #41
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Quote Originally Posted by trikeman View Post
    Auto Zone had replacement. Perfect fit. No cutting or modifications. Bout 20$.
    Do you remember the part number? Thx Rick
    Stallion #378
    Suzuki Burgman 650
  2. #42
    250+ Posts
    Dec 2010
    oly,wa
    1 x stainless steel joiner, 3.0" model JOI000114 7.99
    1 x 3.0" Silicone 90 degree elbow, red model SIL000444 16.99
    1 x Silicone Reducer 3.0" to 2.75" red model SIL000549 11.99
  3. #43
    Dec 2013
    Hot Arizona, USA
    Thanks Dragon, but I was asking Trikeman the part numbers from Autozone. Rick
    Stallion #378
    Suzuki Burgman 650
  4. #44
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Quote Originally Posted by rocket1lf View Post
    Sorry for the delay. Been busy last couple of weeks. Just getting back. I’ll check asap and let you know.
  5. #45
    Oct 2010
Size:  606.8 KBName:  E9445685-A18E-4A6C-9875-9A2B2624C0A5.jpg
Size:  1,008.6 KB It’s been a while since I did the repairs. Don’t remember if I had to purchase new clamps or used existing clamps. The adapter for both ends of hose is supplied. The second adapter is not seen. It’s in package but it’s in the end of the hose. I hah no issues with it. Ran bout 50,000 miles with it and was still good when I sold Stallion last fall.
  6. #46
    Dec 2013
    Hot Arizona, USA
    Thank You. I appreciate the info. Rick
    Stallion #378
    Suzuki Burgman 650
  7. #47
    Oct 2010
    YW
  8. #48
    Sep 2022
    Dallas, TX, US
    Well here is a good one. MJ was riding her Stallion last night. We went to dinner came out and rode about 4 miles and stopped at a Publix for some milk. Came out started the Stallion and when we started to give it some gas it died just like it ran out of gas. we know it had at least 3 to 4 gallons so that was not the problem.
    It would start and idle even in gear but push on the pedal and it would die. We idled down the street for 3 miles in traffic to the motel. I figured fuel filter or maybe fuel pump. Got up made arrangements at a garage to look at it and called AAA to have it towed.
    While I was waiting I opened the hood to make sure I remembered where the data port was and noticed that the air intake plenum looked strange. Looked at it closer and it was completely broke in half where the air filter and plastic sectioned that the MAP sensor are mounted and attaches to the section of the plenum that goes to the throttle body.
    It appears that the plastic failed from getting brittle over the 7 years of heat and vibration. I had some repair tape wrapped it nicely to put the whole thing back together sealed. That fixed the problem.
    With the MAP sensor not being able to read moving air (the sensor was down line from the break) the ECM would not let the Fuel Injection work. No air No gas. Something to be aware of as our Stallions are aging. I will be looking into seeing if I can replace the plenum. Works great for now.
    You posted a long time ago. Although you didn't replace fuel filter or pump then. I'm wondering if you know where each part is located and If you may know the PN. I am definitely going to have to replace the fuel filter (fuel pump will be a last resort) Looking for location and PN information before I start getting my hands dirty or help me decide I don't want to and let someone else at a shop do it for me.
  9. #49
    Sep 2022
    Signal Mtn TN
    The fuel filter is on the left side underneath. Put the trike on a ramp look underneath, easy to see. It is a Ford Ranger part and you need a special tool to release the fuel line, obtainable at any parts place.
  10. #50
    Quote Originally Posted by Trikervet60 View Post
    5/16- 3/8 tool available about $7.00 @ most automotive stores
  11. #51
    Sep 2022
    Dallas, TX, US
    Thanks Jack that what I needed to know. Many Thanks
  12. #52
    the fuel pump is in the gas tank sorry i dont know the pn but i would not be surprised if it was not a ford part.
  13. #53
    IMO you can't do better than OEM pumps, I have bad results with many aftermarket pumps including Napa among others
    OEM pumps may cost more but get my vote
  14. #54
    Sep 2022
    Dallas, TX, US
    This fuel pump PN for 07 - 11 Ford Ranger 1FAC13350
    If I end of replacing I will let everyone know what PN is.
  1. GL1800 intake & exhaust
    By haddont in forum Honda Trikes
    Last Post: 06-10-2013, 01:38 AM
  2. break in period?
    By geraldlanc in forum Stallion Trikes
    Last Post: 04-09-2013, 06:28 PM
  3. Sorry to break the rule?
    By Pooh105 in forum Stallion Trikes
    Last Post: 10-16-2012, 09:35 PM
  4. break down
    By retdpd in forum General Discussion
    Last Post: 07-07-2010, 04:58 PM
