Results 1 to 4 of 4
Thread: Off the table and more problems to be addressed Shovel head Blues
    Aug 2015
    ft worth
    Cool Off the table and more problems to be addressed Shovel head Blues
    Switched a 4spd of 35yrs not shifting right, and installed a sputhe 5spd and its not shifting like i want, new Rivera clutch $500 bucks.
    Was no fun switching trannys, work intensive. Rode it a bit and it seemed to do better, shifted a bit better but hard to shift, and the clutch seems to be releasing, its a shovel with a sealed primary.
    Front tire had 12lbs, took it to 43lbs now head shake low speed, i brought the rake back in on it, it has adjustable rake aftermarket trees. GRRRRRR.
    Back on the table the rear chain is tight, mmm, maybe that contributes to the problem, we shall see, any suggestions. ?
    Sep 2012
    Lakeland, FL
    Good luck to you, I would not have the patience or the expertise. I know my limitations.
    Aug 2015
    ft worth
    Cool
    Thanks for the luck. I built this from 75 to 77 soooo Ive had patience that has run out a time tor two. Now instead of being mad, im disappointed, i don't mind working on stuff, but i like a happy ending, no pun intended, wink, wink. Best to ya.
    You want patience, try pulling all that plastic off that wing to service it, you will find your bottom i bet.
    Sep 2012
    Lakeland, FL
    Now ain't that the truth, can you say "air filter"?
  1. Trike Lift Table Opinions Please
    By grumpy in forum Honda Trikes
    Last Post: 04-02-2016, 01:10 PM
  2. Outlaws and big shovel
    By Phill Griggs in forum Trike Travel
    Last Post: 04-09-2015, 12:28 PM
  3. Jack for lift table
    By hARLEY jOE in forum Harley Trike Conversions
    Last Post: 08-08-2014, 04:04 PM
  4. lift table
    By Frang in forum Harley Trike Conversions
    Last Post: 06-14-2013, 05:47 PM
