SSpoon3Jack KlarichNew Member Introduct...Hello from VA
SSpoon3GorillaNew Member Introduct...Hello from VA
SSpoon3SSpoonNew Member Introduct...Hello from VA
Likes Likes:  6
Results 1 to 12 of 12
Thread: Seat Bolt
    250+ Posts BOXX3R's Avatar
    Jul 2015
    Huntington Beach, Ca
    Default Seat Bolt
    I have had the seat off of my Tri-Glide a number of times and that pesky little bolt that holds the back of the seat down is not easy to get too, especially if the top box is installed. I have dropped the bolt several times onto the frame, and luckily it did not drop down inside the frame somewhere. And to reinstall the bolt I have had to use painters tape wrapped around the screw and the screwdriver to get it back down into the hole.
    So I decided there must be a better way. I ordered a Zinc-Plated Brass Male-Female Threaded Hex standoff, with a 1/2" diameter hex that is 1 1/2" long with 1/4"-20 thread from Mcmaster Carr part# 92700A198. They are not cheap at $10.33 each and an additional $6.00 for shipping, but IMO worth it.
    I put a 1/4"-20 hex button head with RED Loctite into the stand off, or you could use the stock bolt. But now it is real easy to pull the bolt out once loosened and real easy to finger tighten it back up to reinstall the seat, and it is still below the deck.
    "HOW we ride today, may determine IF we can ride tomorrow"
    300+ Posts 67wizard's Avatar
    Aug 2015
    Nv.
    Wow u should be able to get that at the local hardware store.
    With the trunk lid open its not to bad of a thing to do. I put the screw in the seat hole then put a screw driver on it and lower the seat. No problem so far.
    CMA member, VietNam 66-67
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Default Caveman Style.......
    I just cut a quarter size piece of plastic from a water bottle made a X slit in the middle and push it on the bolt bottom of the seat tab, So when i remove the seat the bolt stays with the seat..
    But i do like your idea...
    2019 Tri-Glide.......
    Jul 2015
    That is a GREAT idea to make the bolt captive, Ima have to do dat, thanks.
    Aug 2015
    Nv.
    I like that idea better than what I was doing. DAAA
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
  6. DKCustoms postbit
  7. #6
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Great post good idea
  8. #7
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    Quote Originally Posted by 67wizard View Post
    Do the same using a 12" phillips screwdriver with a magnetized end (that I magnetized myself). Haven't had any problems dropping it so far.
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
  9. #8
    Trike Talk Executive Chef
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Heres what I did, matched the size to this thumb screw. got it at Home Depot.
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Member Patriot Guard Riders
  10. #9
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Thats even [As they say in Brooklyn] more better....
    And you Don't need no stinken screwdriver.
  11. #10
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Having my tour pak leveled and relocated aft 1.5" with the tglidestuff dot com rails makes getting to the seat screw very easy. The simple thumb screw solutions seem like an easy solution. Thanks.
    Bob
  12. #11
    100+ Posts nevtat's Avatar
    Aug 2010
    Las Vegas, NV
    Default Great idea!
    Glad I'm not the only one who has trouble with that damn screw! I like your idea, I'll give it a try. They only thing I found that helps me is I use one of those screwdrivers with the spring clips that hold the screw in place.
    Thanks again.
  13. #12
    5+ Posts Biker_ded's Avatar
    Jul 2020
    Hickory
    Cool seat bolt
    As mentioned earlier. get a 1/4"-20 screw that works with a magnet (the stock one won't) and a screwdriver with a magnetic tip-works great. Simplest solution so far.
  1. Broken tie-link bolt.
    By rhino 2 in forum General Discussion
    Last Post: 09-07-2016, 09:04 PM
  2. HD mistake fix - Seat Mod For undersized seat bolt & loose seat tab on Freewheeler
    By Bill G in forum Harley Freewheeler / Road Glide 3
    Last Post: 06-14-2015, 04:58 PM
  3. What's up with this seat bolt??
    By MDGeorge in forum Honda Trikes
    Last Post: 04-07-2014, 09:29 AM
