Results 1 to 5 of 5
Thread: 92 motortrike air pressure questions
    90+ Posts
    Sep 2012
    Magnolia, Ms USA
    Default 92 motortrike air pressure questions
    I have recently bought this trike. The rear tires are 235/60/15 . When I bought it with 35 lbs in them. Lowered them to 30 and running 30 on the air bags. Ran good, but a little rough. After reading here most run 18-25 lbs. Lowered to 20 lbs and took it for a spin on some back roads. We'll it would sway bad in the rearend. Raised the airbags to 40 and still no improvement. Put the tires back to 30 and was much better with very little swaying. Any thoughts on this? Going to put some 215/65/15 after the first of the year.
    Forgot to mention shocks are 1 notch from maximum setting.
    David
    300+ Posts alienwulf's Avatar
    Sep 2015
    Menifee Ca.
    I am running a champion but to compare got 30 on the air shocks and 21 on rear tires and 36 in front. Try different settings you find the Happy Spot may take a few tries it did for me.
    90+ Posts
    Sep 2012
    Magnolia, Ms USA
    Quote Originally Posted by alienwulf View Post
    Motortrike no longer use this size tire. Will see how it goes once I change the tires. My back roads are pretty bad.
    David
    Suggestion. Just to try out. Lower the rear tires to 22 to 24 lbs. 0 to 10 the air bag. See if the swaying goes away.
    90+ Posts
    Sep 2012
    Magnolia, Ms USA
    Headed back to work for 21 days. Once I get back home I will give it a try.
    David
  1. oil pressure
    By cavie in forum Harley Trike Conversions
    Last Post: 11-11-2015, 03:02 PM
  2. Anyone a Motortrike Dealer on here? I have a couple of questions
    By FLTR2008TRIKE in forum Harley Trike Conversions
    Last Post: 01-12-2015, 12:28 PM
  3. tire pressure???? suspension pressure???
    By flangar in forum Stallion Trikes
    Last Post: 05-10-2014, 09:53 PM
  4. Questions.. Losing oil/funky oil pressure
    By classicfins in forum VW Powered Trikes
    Last Post: 10-09-2012, 04:31 PM
  5. Air Pressure
    By deuce1959 in forum Honda Trikes
    Last Post: 09-02-2012, 05:21 PM
