Results 1 to 4 of 4
Thread: Weber 34 ict question
    200+ Posts
    Apr 2015
    pineville, la
    Default Weber 34 ict question
    Just put new Weber 34 ict's on my stock 1600cc type 1 trike. From the factory it came with 60 idle and 145 main. On adjusting the carbs to Weber's specs the left carb mixture ended up at 2 and the right at 1 7/8 to the best of my ability which is in the middle of what Weber said it should be. The instructions said to set the idle screw on 1 3/4. It said to not going in on the idle screw no more than the initial setting. My problem is my idle is to low ( 500 to 600). Has anyone had this happen to them and what did they do to get the idle up.
    I have read about drilling a 1mm hole in the butterfly helps but I don't want to start drilling unless it is necessary. Any suggestions would be appreciated.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Did you balance the carbs yet? When you say that one is 2 turns and the other it 1 7/8 turns; is this doing the balance on them?
    200+ Posts
    Apr 2015
    pineville, la
    Default 34 weber ict question
    What I did was I had the speed screws at 1 3/4. When I adjusted the carbs the left carb sounded good at two turns out and the right carb at the 1 7/8. Then I balanced them leaving the mixture screws at that. The left carb was little high so I brought it down a hair to match the other and my idle is low. I was just trying to leave the idle screws at 1 3/4 or less. I may have to go in more on them to get it to idle up. If you could give me your idea on how to adjust them I would appreciate it. I may be going about it all wrong.
    Quote Originally Posted by stinger608 View Post
    Oct 2015
    Conway
    Default Found a set of great carb replacements
    When I was building my sand rail powered by a 1974 Porsche 914 DC motor that was once fuel injected we changed it over to a carb using a Webber manifold. The prob was we ears ate so expensive. My buddy suggested I replace the Webber with a pinto carb 34/36 I bought it on eBay remanufactured for 60.00 it worked perfect found out the pinto carbs are also webers but made for ford cheap and it was flawless
  1. What size weber
    By starrider1946 in forum VW Powered Trikes
    Last Post: 04-29-2016, 07:09 PM
  2. tuning weber idf 40
    Last Post: 05-18-2015, 07:59 PM
  3. new with gw question
    By Dray in forum Honda Trikes
    Last Post: 12-02-2010, 07:48 PM
