Results 1 to 9 of 9
Thread: Drive Shaft U-Joint grease
    80+ Posts Red Wing One's Avatar
    May 2015
    Komoka Ontario Canada
    Default Drive Shaft U-Joint grease
    I've done my first oil change on my new to me 2013 Lehman Monarch II LLS (purchased in May)
    As recommended by board members, I want to grease the U-Joints, but when I look at them, I don't see any grease nipples?
    Has Lehman done away with this feature? The U-Joints look much smaller than the ones pictured in the installation manual!
    I tried calling Lehman, but it's hard to get through!
    Thanks in advance.........Marcel
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Pictures from the website install instructions show grease fitting on the 2012 model. 2013 is for
    fb6
    http://www.lehmantrikes.com/products...n-instructions
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Marcel, I have a Champion that I have to grease every 3,000 miles. My instruction manual tells me it there are no grease fittings then it is permanently lubricated. This may be in your case but best to find out for sure.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
    550+ Posts Solidbob's Avatar
    Tx
    Quote Originally Posted by Red Wing One View Post
    Remember they have moved everything to California....
    2015 Lehman Trikes USA | 11841 Monarch Street | Garden Grove,Ca 92841-2110 | Call us Toll-Free 1-888-3WHEELS (3943357)
    May 2015
    I blocked up the trike and was able to get up close......there are no grease fittings on the U-Joints........they must be permanently lubricated!
    I hope they last!
    The number I have for Lehman is 1-888-394-3357.
    I just tried it again, it rings once then goes to a busy signal!.
    May 2015
    Default Many thanks to Bazooka!!!!!
    Bazooka, I spoke with Bill at Champion, and he confirmed that my driveshaft has permanently lubricated u-joints.
    He also enlightened me about the issue I have with the poor brakes on my Lehman.
    He highly recommended that I de-link my rear brakes. This is something that Champion (and other trike kit manufacturers) do as a rule.
    I've contemplated doing this theorizing that the automotive calipers needed all the power that the small Honda master cylinder could provide.
    He said that the online install manual for the Champion IRS would show me how to do it. He also said that their parts department could supply me with the few items needed to de-link.
    I will definitely take this project on later this winter.
    I will post on the site with my results!
    Best regards..........Marcel
    Sep 2016
    Springfield, Mass. USA
    Please keep us all posted on how you made out replacing your brakes................
    Where do you live, If your anywhere near me, I'd love to help you out.................Springfield, Massachusetts
    8/3/22
    Sep 2016
    oooop's I just noticed Canada (I guess that won't work too well)................I tried!
    8/3/22
  1. Which U-joint grease?
    By Mick in forum Honda Trikes
    Last Post: 12-25-2023, 08:24 AM
  2. Put a new drive shaft in.
    By bayoudave in forum Honda Trikes
    Last Post: 05-29-2014, 07:51 PM
  3. Drive shaft grease
    By dogman513 in forum Honda Trikes
    Last Post: 12-14-2013, 10:52 PM
  4. drive shaft
    By Tri-Pacer in forum General Discussion
    Last Post: 09-01-2011, 08:37 PM
  5. Bad U joint & drive shaft
    By wdy41 in forum General Discussion
    Last Post: 02-07-2010, 12:48 AM
