Likes Likes:  3
Results 1 to 18 of 18
Thread: Vibration on CSC GW Trike - Questions ...
    60+ Posts
    Oct 2009
    Fairfield Glade, TN & Port St Lucie, FL
    Default Vibration on CSC GW Trike - Questions ...
    I have a 2002 GW Trike, conversion done by CSC. The bike had almost 40,000 miles on it and recently it developed a shake and vibration in the front end when I get the bike up to 60 mph. There is no shake or vibration at 50 or less. It is not highway specific and does it all the time. I took it to my local Honda shop and they told me that the front wheel was cupped and needed replaced. So I ordered a new tire and installed it and vibration at 60+ still there. (Not a bad deal even though it did not fix the problem, a new tire is always good) This is a phenom that just appeared this riding season. Last year there was no vibration. I am not sure if it is a trike issue or a GW issue. But I am looking for other things I can look into if the shop does not come up with any other items.
    Any ideas?
    150+ Posts
    Nov 2009
    Elkhart, KS
    Default Re: Vibration on CSC GW Trike - Questions ...
    How did you balance the tire?
    I'm assuming the shop checked for loose or worn bearings in the front?
    Myself, anytime I replace a tire, it gets 2 oz of dynabeads for balance.
    60+ Posts
    Oct 2009
    Quote Originally Posted by ricle41 View Post
    I am not sure how they balanced the tire. I will ask them when I take it back in. I will also ask them about bearings, but will see if a simple balance will fix it.
    I was thinking if it was bearings I might feel the vibrations at a lower speed?
    But thanks was good information.
    Sponsor - Southwest Touring chaz_36's Avatar
    Feb 2008
    Arlington, Texas
    Check rear tire balance.....might be the culprit.....
    150+ Posts TRIKERBOB69's Avatar
    Mar 2010
    PA.
    check the tire balance on all 3, then save some money by not buying snake oil products to balance things out and spend the money on a new set of bearings, you may have original honda steering bearings, they are replaced when they rake them now but before I believe they used the factory ones that tend to fail over time,,,,JMHO
    700+ Posts BlueTrinity's Avatar
    Apr 2008
    Central Pennsylvania
    Quote Originally Posted by TRIKERBOB69 View Post
    WOW! .....Snake Oil ????
    I assume you're talking about Dynabeads ?????
    Dave
    Those voices in my head may not be real, but they have some really good ideas.
    300+ Posts mpolissky's Avatar
    Jun 2009
    Boynton Beach, FL
    Consider upgrading your front end with Traxxion Dynamics products. I'm doing this upgrade in two weeks. From what I read, it's well worth the $$$.
    GL1800 with 2009 Roadsmith Trike Conversion, Traxxion Suspension and much more...
    In Memory of Bob Reeves trikes4ever's Avatar
    Aug 2010
    Lake Livingston, TX, USA
    Dynabeads to the resucue AGAIN. Had my tires mounted (Mickey Thompson S/Rs) on Weld Draglites before I took the Deuce in for the Frankenstein conversion. Per their recommendations I put 3 oz in each tire. The tire shop just threw the bag in - I asked why they didn't cut it and dump them, and they said they use these all the time (car and truck tires) and never cut the bag. When the shop called for me to pick up the trike the guy said it was vibrating terribly on a very short test run so he didn't take it on his normal 15 mile run. Weather was ****ty and I didn't want to wait so I just picked her up and hauled her home. I was fairly certain that the bags just had not disintegrated yet, so there was a clump weighing 3 ozs sitting in each tire - obviously in the wrong place. Took her for the maiden voyage the next day, and smooth as glass. If the shop had driven her another mile or two she probably would have been fine - but he didn't want to cup the brand new tires - that's how bad it was.
    So - to those who prefer 'snake oil' over the high $$$ solution - it's ok to just throw in the entire bag (inner bag only) - you just have to drive a few miles before the beads start working. NO external weights on my wheels!
    2003 Deuce
    Triked with Frankenstein 34" Hot Rod rear
    Chrome everywhere - the Deuce comes that way
    My last VW trike build
    TOI - Michigan CadtoChrome's Avatar
    Dec 2008
    Oakley, MI
    Just a thought, have you checked your neck bearing torque?
    have seen similar problem and it was neck (triple tree) bearings less than required torque.
    Chuck
    Aug 2010
    A pretty convincing demo.
    2003 Deuce
    Mar 2010
    PA.
    Quote Originally Posted by BlueTrinity View Post
    :Monster:
    60+ Posts
    May 2011
    grand jct. co
    damn ! thats cool. i'm definitly gonna buy them beads if my water bottles start wobbling, i just hate wobbly water bottles !
    30+ Posts fred-houston's Avatar
    Apr 2010
    TeXaS
    I have actually used the Dynabeads for years. Mainly on the rear of my BMW, because the dealer where I get my tires mounted does not have the adapter to be able spin balance the wheel.
    Have numerous friends who use them exclusivity on both two and three wheel bikes. Call them snake oil if you like, but they work like a champ.
    80+ Posts
    May 2011
    Out there
    Smile Re: Vibration on CSC GW Trike - Questions ...
    Quote Originally Posted by Monkei View Post
    Any ideas?
    Have you checked the steering head bearings for play?
    The fork bushings for wear?
    You didn't say how old the conversion is, raked trikes wear out bushings. A somewhat less likely possibility is the driveshaft, rear problems can cause front end effects.
    CSC has gone through a few changes there.
    Nov 2009
    Mass
    I had this problem.....it was the brand new tire that I bought! Its very rare to get a tire that is out of round.....but this one was! I did get a refund from the maker.....but it was hard to convince them. BOb
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by trikes4ever View Post
    Wow! Your video was what I needed to see to be convinced............I'm buying the bead(s) tomorrow for all three wheels...............thank you
    Jun 2010
    Indianapolis, In.
    RideOn does the same thing plus seals punctures!!!!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Apr 2010
    Shenandoah Valley of Virginia
    Work well in bike tires and even car tires of 65-70-75 series or higher. I have them (not balance beads, I used .22 cal. Air-Soft Red Jacket hard plastic BBs in same weights as charts say, different medium, same effects) in the '85 GL1200 Bike and the '97 Trike which has 215/70-15 rear tires and no external weights, super smooth too.
    After much experimentation both as a primary and as a "fine tune" method, with 55 and 60 series and lower profiles ... not so good in them. One time they may be OK, slow down or encounter a good bump and I think the beads get rolled across the floor of the tire. Just not consistent at best in wide lower profile tires at beast and sometimes, consistently not good.
    I have access to good mount / dismount / balancing equipment, I knew I was "playing".
  1. Honda Motor Trike front end vibration.
    By triker69 in forum Motor Trike
    Last Post: 07-05-2012, 10:14 AM
  2. trike set up questions....
    By mopar in forum General Discussion
    Last Post: 05-10-2010, 04:23 AM
  3. Motor Trike Vibration/Rattle
    By Mr.Wizard in forum Harley Trike Conversions
    Last Post: 05-25-2009, 07:03 PM
  4. vibration in handlebars on champion trike
    By john in forum Honda Trikes
    Last Post: 05-16-2009, 11:08 PM
