Likes Likes:  2
Thanks Thanks:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
Thread: ATTN: STALLION OWNERS......Front wheel bearing
  1. #21
    200+ Posts
    Feb 2017
    Arp, TX - USA
    I would imagine your mechanic meant not getting water on bearings using a pressure method (car wash, pressure washer, etc). We also do not recommend that as the high outlet pressure of the water can easily push past seals & cause a failure.
  2. #22
    Oct 2018
    Huntsville AL USA
    Good to know.
  3. #23
    Nov 2020
    Fort Myers
    Default bearing
    Dont know if you have found bearing yet but they are available for
    $11.50 each Part Number 6814-2RS, from 123 bearings. telephone
    1 646 712 967270mm X 90mm X 10mm is measurements
    123 bearings. 1 646 712 9672
  1. Need help from stallion owners
    By redneckray in forum Stallion Trikes
    Last Post: 06-16-2018, 10:39 AM
  2. Calling all 2009 Stallion owners (or previous 2009 owners)
    By TnTrikeRider in forum Stallion Trikes
    Last Post: 12-24-2015, 06:18 PM
  3. Attn 1999 GL1500SE owners ..... I have a question.
    By TwoBye in forum Honda Trikes
    Last Post: 02-14-2014, 04:33 PM
  4. To All Lehman Kit Owners-Bearing Issue
    By 1550vt in forum Lehman Trike
    Last Post: 09-27-2010, 09:14 AM
  5. All you Stallion owners!!!
    By bigred06 in forum Stallion Trikes
    Last Post: 05-20-2009, 07:52 AM
