Likes Likes:  64
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 41 to 60 of 113
Thread: V8 Diesel Trike... old Uhaul truck
  1. #41
    70+ Posts BMB Guns's Avatar
    Dec 2015
    Louisiana
    More leading link pics. I have the lower forks made. Busing welded in with grease zerks! 1 inch grade 8 fine thread bolts. Bolt bushings are easily replaceable 1 inch pipe.Name:  2016-02-18 12.19.06.jpg
Size:  369.3 KBName:  2016-02-18 12.19.38.jpg
Size:  415.6 KBName:  2016-02-18 12.22.30.jpg
Size:  203.3 KBName:  2016-02-18 12.20.02.jpg
  2. #42
    Dec 2015
    Louisiana
    It's been a while since I posted. Project is still going. The 3-53T is alive!*
    https://youtu.be/SDnKQviTiTk
  3. #43
    Sound good
  4. #44
    Nice ... oh boy ... oh boy ... an ongoing build thread
  5. #45
    Dec 2015
    Louisiana
    Oh... Almost forgot. *Part of the reason I haven't posted is that I've been chasing the transmission dragon for well over a month! The flywheel housing on the 3-53T is SAE 3. Almost nothing out there bolts up without adapters. I need a transmission with overdrive to get up to highway speed. Long story short. A Spicer 3053a from *2.5 ton Military truck!!! SAE 3 bellhousing with 0.85 overdrive! *I'm planning on going pick it up in a couple of weeks!!!
  6. #46
    This trike will be able to take on ISIS ...
  7. #47
    100+ Posts butchvoss's Avatar
    Jul 2013
    patrick SC
    Quote Originally Posted by BMB Guns View Post
    Did i miss something. I thought you were using a 7.3
  8. #48
    Dec 2015
    Louisiana
    Quote Originally Posted by butchvoss View Post
    That was the original plan. I found the 7.3 full of rain water due to a hole in the air cleaner lid. A friend had the 3-53T which is a dream engine in my opinion compared to the 7.3
  9. #49
    300+ Posts J.T.M.'s Avatar
    Jan 2015
    Buffalo, Ky, USA
    Keep the build and pics coming.
    Every day is a good day.
    US NAVY SEABEES 1971-1975
    2010 Ultra Classic/ Hannigan Transformer
    1987 Honda Rebel 450
    Sold all the others
  10. #50
    Dec 2015
    Louisiana
    Default Quick update from the Gulf of Mexico
    Well, the above pic is why I haven't made progress on the trike recently! Hard to get things done in the middle of the Gulf of Mexico. Anyway, when I get back in land I'm going pick up a transmission! Found a 3053A Spicer with an SAE #3 bellhousing that will bolt right up to my 3-53T Detroit! Things will start moving along again once those two are joined with a suitable clutch in the middle... I'll keep y'all posted.
  11. #51
    Dec 2015
    Louisiana
    Default The diesel trike is slowly progressing
    Well, I purchased the engine last week and I'm getting it cleaned up and dressed out for the trike. I'm hoping to get my transmission soon and really start rolling!!!Name:  20160611_184002.jpg
  12. #52
    Dec 2015
    Louisiana
    Default Radiator and fuel tank
    Well, I mounted the radiator and fuel tank. I'm going to try something different with the rear mount fan. I'm going to belt drive the fan with a saft on pillow blocks that will run from the front of the engine to the back of the trike! Yes, electric fans would be easier but this will be sooo cool!!! Also, the radiator is big! It's big enough for a 6-71 detroit. The little 3-53t should be able to idle all day in the desert without overheating. The file tank is a 30 gallon factory ford diesel tank that was on the uhaul. Keep in mind, the Mad Max movies I grew up watching are a huge inspiration for this trike. A beast to travel the wastelands on!!!
  13. #53
    Dec 2015
    Louisiana
Size:  357.8 KBName:  20160623_180150.jpg
Size:  323.5 KBName:  20160624_123354.jpg
Size:  306.9 KBName:  20160623_203852.jpg
Size:  964.5 KBName:  20160624_182126.jpg
    Primary and secondary fuel filters installed with brand new custom stainless fuel lines. Altenator bracket fabricated and installed!Name:  2016-06-25 09.15.45.jpg
  14. #54
    Meme Master
    Jan 2014
    Farmington, NH USA
    That's what I call "stump pullin power" right there!
    Are you planning on running dual rear wheels on it too?
    Your trike project is great to watch, as the final product should literally be bulletproof! No joke intended, based on your TV "history"
    As another 2nd amendment supporter myself, are you thinking about any gun art being incorporated on your trike?
    Keep up the good work, & keep the pictures coming. We all appreciate them!
  15. #55
    Dec 2015
    Louisiana
    I will be running 4 tires on the rear axel. It's a dually and gonna let everyone know it!
    As for gun stuff. I have considered "covert compartments" to hold a few of the kids while on long trips. At least one quick access and a few for long term storage.
    I might also incorporate some spent brass in the decorating phase.
  16. #56
    Dec 2015
    Louisiana
    I got the transmission!!!!!!
    The Warrior of the Wasteland! The Ayatollah of Rock and Rolla!... FYI: My 12 year old daughter drew my Ghost Rider on a trike Avatar for me! She's so talented!
  17. #57
    That's bigger than a lot of trikes ... heavier too ... gonna be a big gal
  18. #58
    750+ Posts
    Jan 2010
    east windsor ct
    Talking
    this must be one of those Austrailian motors!!
  19. #59
    Dec 2015
    Louisiana
    Ha! Yeah, I have no idea what happened! This one is better anyway.
  20. #60
    Meme Master
    Jan 2014
    Farmington, NH USA
    Is the metal baseplate in your pic, going to be incorporated into the frame?
    It looks pretty good regardless, but having the engine/trans on a removable platform might ease the construction, & any later service requirements down the road?
    Keep pluggin away, you'll get there!
    Ask any true builder & he or she will tell you: its sometimes one step forward & 2 steps back...
    The trick is keeping those backward dance moves to a minimum!
  1. Diesel trike???
    By BIGJEEPMAN in forum Home Built Trikes
    Last Post: 10-05-2018, 10:53 PM
  2. CUMMINS DIESEL Trike??
    By Scott39 in forum Home Built Trikes
    Last Post: 09-19-2011, 10:56 PM
  3. building a cummins turbo diesel trike need help on front end
    By redneck5014 in forum Home Built Trikes
    Last Post: 07-29-2011, 05:23 PM
  4. Courage Trike CT Diesel
    By Courage in forum Other Brands Trikes
    Last Post: 12-27-2010, 09:05 PM
