Likes Likes:  64
Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 101 to 113 of 113
Thread: V8 Diesel Trike... old Uhaul truck
  1. #101
    70+ Posts BMB Guns's Avatar
    Dec 2015
    Louisiana
    Quote Originally Posted by diver View Post
    Nice, how long is the shaft?. ...I like it
    11 1/4 center to center on the u-joints ! That is with 1 1/4 of spline pulled out. That should be plenty of travel for my application.
    The Warrior of the Wasteland! The Ayatollah of Rock and Rolla!... FYI: My 12 year old daughter drew my Ghost Rider on a trike Avatar for me! She's so talented!
  2. #102
    Dec 2015
    Louisiana
    Default Quiet but still working!!!
    Well, the clutch is in, transmission bolts up, engine mounts are fabricated and installed, front of frame is cut and capped off with a big ass piece of channel. Slow but steady
    Name:  2016-12-12 21.52.03.jpg
    Name:  2016-12-12 21.52.37.jpg
  3. #103
    Dec 2015
    Louisiana
    Default Running in the frame!!!
  4. #104
    Meme Master
    Jan 2014
    Farmington, NH USA
    Great to see some more forward progress on your trike
    Are you setting it up more for the drags, or street?
    Looks & sounds good with the turbo spoolin'!
  5. #105
    Dec 2015
    Louisiana
    Oh this will be a grocery getter and road triper! My cousin also owns a biker bar just down the hill from my shop so I guess I'll be there alot too!
  6. #106
    Sure sounds SWEET
  7. #107
    Dec 2015
    Louisiana
    Haven't posted in a while. Project is not dead just taking a back seat. I added a new machine to my shop! Can you say "custom heavy duty steering neck!" ?!?!Name:  20170609_195144.jpg
    ....annnnnd... my pic is sideways... :/
  8. #108
    Meme Master
    Jan 2014
    Farmington, NH USA
    New shop equip. looks good Brady.
    After a 5 month break, bout time to get back to work on that trike now, isn't it?
  9. #109
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default reply
    wish that lathe was in my shop! 353 sounds great,
  10. #110
    Sep 2018
    goldsboro, n.c. usa
    Default like your build
    Quote Originally Posted by BMB Guns View Post
    The rear pinion won't be 10 degrees off. As I stated earlier, I cut the saddles off of the rear axle to allow me to roll the differential/pinion to an upward angle to match the angle of the engine/transmission. The offset to allow the u joints to work will be handled by the pinon shaft which is not dead center on the axle.
    did you finish your trike yet? would like to know how the front end works? would like to use build something like it to run car rim on front. thanks
  11. #111
    4750+ Posts
    Mar 2015
    Texas
    Looks like this puppy died on the vine.
    American Legion Rider
  12. #112
    I can't figure how this happens ... but ... I did make it straight ... maybe it will inspire the builder to get back to the project ... LOL. Gotta admit .. it's kewl and massive.
  13. #113
    May 2020
    Grand Island, NE USA
    Default BMB F350 Build
    BMB, I have been around the trike building community for a while and have actually seen a few truck based trikes. One thing I know they ALL did and it makes your ride much more comfortable. Do some research into removing some of the leaf springs. As I am sure you already know that suspension is for very heavy loads, you could remove a bunch of them and improve your ride while still being safe.
  1. Diesel trike???
    By BIGJEEPMAN in forum Home Built Trikes
    Last Post: 10-05-2018, 10:53 PM
  2. CUMMINS DIESEL Trike??
    By Scott39 in forum Home Built Trikes
    Last Post: 09-19-2011, 10:56 PM
  3. building a cummins turbo diesel trike need help on front end
    By redneck5014 in forum Home Built Trikes
    Last Post: 07-29-2011, 05:23 PM
  4. Courage Trike CT Diesel
    By Courage in forum Other Brands Trikes
    Last Post: 12-27-2010, 09:05 PM
