Results 1 to 3 of 3
Thread: Residual Valve
    80+ Posts
    Sep 2014
    SE New England
    Default Residual Valve
    Has anyone seen a residual pressure valve with thisconfiguration.
    I have looked at all the Lehman documents and none of then show a valve like this, nor do they mention the bleeder on the end of it in the bleeding / air purge process
    There are 2 brake fluid lines going into the residualpressure valve that come from the OEM inner and outer hard bent lines that run on the right side of the Trike. The outer line has a yellow dot on it and is connected too the fitting closest to the bleeder valve. The other line is connected closer to the tee fitting on the residual that feeds the left and right caliper. I don't now what sequence to follow when I have a bleeder (1) on eachrear caliper and then (1) on the residual valve as well. The Lehman docs only show (1) brake line going into the valve.
    My conversion is a 2012 GL1800 with a 2012 Lehman Monarch IISA build
    Would appreciate any help that is offered
    I have photo's of this configuration but have not figured to past them into a thread.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Question answered.......
    Jim Murphy
    Iron Butt Rider 2001
    80+ Posts
    Sep 2014
    SE New England
    Thanks for your help
  1. Residual brake valve on Lehman Monarch 1
    By DeerWrangler in forum Honda Trikes
    Last Post: 09-01-2023, 09:55 AM
  2. Champion Residual Valve
    Last Post: 05-16-2014, 08:21 PM
  3. Champion residual in line valve
    By Teal in forum Honda Trikes
    Last Post: 09-06-2011, 05:34 PM
  4. Oil Valve: Quik Valve
    By Konrad in forum Honda Trikes
    Last Post: 08-05-2011, 07:34 PM
  5. Roadsmith Residual Value Replacment
    By chuckiejoh in forum Roadsmith Trikes
    Owners Forum
    Last Post: 10-25-2010, 09:11 PM
