Likes Likes:  1
Results 1 to 17 of 17
Thread: Removing tour-pac from Tri-Glide ??
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    Default Removing tour-pac from Tri-Glide ??
    Always told to go to school on somebody else's experiences. I want to remove my tour-pac and replace it with the '09-'11 FLHXXX luggage rack and passenger back rest. Going to ride this configuration around town......road trips, put the tour-pac back on.
    My question (no I haven't crawled under my trike yet) how hard is it to get to the bolts that hold the tour-pac on the body ?? I have very thing ready to bolt on just have to get under the trike or in the trunk and get after it. BUT having Parkinson's getting on the ground is the easy part, it's the getting up off the ground that is the challenge. Getting up and down trying to accomplish this is what's going to wear me out. Have found that things that use to take me 30-40min now take better than an hour or 2. Would rather have everything ready, in place, and get it done.
    Having had detachable tour-pac setups on my Ultras I already know about antennas, speakers, wiring and such.
    Suggestions ???? (other than letting somebody else do it.) LoL !!!
    Thanks in advance for the education.
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
    50+ Posts
    Jan 2015
    Millersburg, Pa
    If I remember right on the top of the inside of the trunk you have to remove four nuts. (7/16 or 1/2" socket) Remove seat and unplug wiring and antenna wire. You should then be able to lift right off. (is heavier then it looks)
    250+ Posts BOXX3R's Avatar
    Jul 2015
    Huntington Beach, Ca
    I got you PM, and went out to snap a pic. There are 3 (7/16") nuts on each side that hold the Tour Pac on.
    I have a bad back and my bend overs don't bend over so well anymore either. So when I removed mine I sat on a rolling shop stool behind and to the side of the open door, and used a 7/16" socket and a long extension with a ratchet and reached up and felt where the nuts were to remove them. Then I did the same thing to install the rack which uses 5/16" x 18 bolts with a 1/2" head.
    I chose to cut the heads off of 6 ~ 5/16" bolts and thread the bolts into the rack as studs with blue locktite on them, and then put the rack down onto the trunk and secured it with 1/2" locknuts. I thought I was going to have to drill out the holes in the trunk because of the difference in the bolt sizes. But to my surprise the holes are already 5/16" rather than the smaller 1/4" studs that the Tour Pac uses.
    If you have any other questions, do not hesitate to ask I will be happy to help.
    There is a better pic of the underside of the trunk top in the last post of this thread.
    http://www.triketalk.com/forum/threa...there-be-Light
    "HOW we ride today, may determine IF we can ride tomorrow"
    Jun 2013
    Texas
    Great info.... Thanks fellow.
    Good idea on cutting the bolt heads off. Plan to install it useing nylon lock nuts with fender washers. Plan to use a come-along to lift the tour-pac off and it on an extra roll around tool rack I have. Might even bolt it to that tray to prevent uh-oh's from happening.
    Thanks again,
    8~\o
    900+ Posts Bubba49's Avatar
    Feb 2014
    South Carolina
    If you don't already have the FLHXXX luggage rack and sissy bar, you might be out of luck. I've been told that the sissy bar is no longer being sold or made. There's a guy on another forum whose been looking for one for weeks now. Call your local HD shop and have them do a global search for one (probably won't find one though). I have one for my 11 XXX, but wouldn't part with it because of its discontinuance.
    Bubba
    Quote Originally Posted by Texan View Post
    8~\o
  6. DKCustoms postbit
  7. #6
    Jun 2013
    Texas
    Quote Originally Posted by Bubba49 View Post
    Bubba
    Thanks,
    I guess ya might say I lucked out on the parts....found 'em from another member up in Canada. Took some doing to get 'em but finally did.
    Thought about doing this a couple years ago and dropped the idea when I found out ALL the parts for the FLHXXX were being discontinued. I DID find a luggage rack (no back rest sissy bar) in up state New York for $350.00 but he sold it 10 minutes after he listed it on eBay. There has to be so stock laying around in a couple 2-3 Harley shops around the country but nobody's ask 'em. There was a local fellow had a tour-pac installed on his FLHXXX here locally a couple years ago and from what I can find out the dealership tossed the luggage rack.
    DUH !!!!
    I'm good and feel that if I ever do decide to stay with the tour-pac I can always get my $$$$$$ back.
    8~\o
  8. #7
    2000+ Posts Rollin Thunder's Avatar
    May 2013
    SUN CITY WEST. ARIZONA
    Hey Tex; Just saw your post about you taking off the tour pac. Can you post pics of before and after ? Rick . If you did it all ready. Or not
  9. #8
    Jul 2015
    Quote Originally Posted by Rollin Thunder View Post
    I also want to see pics of Texans transformation
    Below is a link to a thread I did when I took mine off.
    http://www.triketalk.com/forum/threa...-Going-TOPLESS
  10. #9
    Jun 2013
    Texas
    Yeah, I'll post some pics. Started to when I installed my chrome inner primary but there are bunches of those out on YouTube. Figured everybody already had done this.
    Will post some pics on my going topless cause I can't/couldn't find any thing on it. What I should document is the dang search for the FLHXXX parts. OMG!! If they are out there everybody's keeping quiet.
    Ha!! Have a friend that has a FLHXXX says he'll just loan me his bike and save me some time.
    8~\o
  11. #10
    1+ Posts
    Jul 2016
    Nederland
    Default Trunk bolts inside the trunk
    I removed my tour pack and I got lucky and found a rack. My tour pack has 4 bolts that screw into welded on nuts on a flat metal bar inside the top of the trunk. My trike is a 2013 Tri Glide. My question is what is the braided ground wire for that's attached to one of the bolts inside the trunk used for? Also if I cut the nipples off of the plastic tits that hold the flat bar to the inside of the top of the trunk will it come off easily?
  12. #11
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    2014 - Tour pak relocation rail install pictures .... not sure of your year.
    Name:  006 Box Off.jpg
Size:  395.3 KBName:  007 Box Off.jpg
Size:  422.9 KBName:  010 Mounted Support show lengths.jpg
    Bob
  13. #12
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Quote Originally Posted by Gleeg1962 View Post
    Braded ground for antennas
  14. #13
    10+ Posts
    Jul 2017
    NC
    I'm hoping I can detach the tour pack and it wiring, I still be drivable 10 miles to a body shop mine needs a little repair, where my dealer screwed me when the lock cyl. fell inside the trunk.
    2017 tri with less than 400 mi on the clock.... nice huh- what a battle this has been
    SKULLSHAKER
  15. #14
    60+ Posts 30glock's Avatar
    Jul 2016
    Somewhere in usa
    Quote Originally Posted by Skullshaker View Post
    SKULLSHAKER
    Take It back to the dealer.
  16. #15
    10+ Posts
    Jul 2017
    NC
    Quote Originally Posted by 30glock View Post
    I am using my dealer minus his body shop he was going to send it to, that he has never used so he said. No thanks.
    I'm using my own body shop guy that produces show quality work. With my dealers money, I'm a little anal when it come to my things
  17. DKCustoms postbit
  18. #16
    10+ Posts
    Jun 2018
    Danvers MA USA
    Default 2017 Lock Assembly on Trunk
    So it seems like others have had this same issue. My trunk lock assembly came off in my hand when I stopped at the dealership. They did fix it after a 3 Hr. wait time but the seal around the assembly came out the first Time I washed the bike after the repair and it is loose again. 2 week wait for parts and I will have to loose another riding day while they fix it again.
    By the way I am going to be putting in a Tour Pac Relocation Kit this weekend any hints on Disassembly to make it go smoother?
  19. #17
    1+ Posts
    Aug 2021
    Dunbar,Pa USA
    Default tour pack removal
    like to remove my tour pack any tips? or pictures? thanks
  1. Tri-Glide detachable tour-pac
    By Texan in forum Harley Tri Glide
    Last Post: 05-21-2014, 07:57 PM
  2. a different approach to triking my 89 tour glide
    By pcombe in forum Harley Trike Conversions
    Last Post: 07-30-2013, 06:58 PM
  3. stock parts for 1989 Harley tour glide ultra
    By pcombe in forum 2 Wheelers
    Last Post: 05-31-2013, 10:01 AM
