dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Jack Klarich2ISP-FLGeneral Harley ChatExhaust Heat Shield
gfaltersack4ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
Jack Klarich2Jack KlarichGeneral Harley ChatExhaust Heat Shield
Likes Likes:  0
Results 1 to 13 of 13
Thread: Cheap IRS
    5+ Posts
    Jan 2016
    Athens, AL
    Default Cheap IRS
    Has anyone used the rear subframe/suspension out of a Miata? They are common, inexpensive, mostly self contained.
    250+ Posts wehrme's Avatar
    May 2014
    Decatur, IL
    Haven't heard of using a Miata, but have seen a couple that used Pontiac Fiero's.
    Brother Mike
    5+ Posts
    Sep 2016
    Round Hill, Alberta, Canada
    Default I've just scrounged a complete irs from a 90 Subaru Justy
    IRS includes a structural crossmember, diff, diff-mount crossmember, halfshalfts, hubs, struts, drum brakes with hyd slave cyls and cable e-park-brakes, coil springs, struts, trailing arms, trailing arm mounts, sway bar and mounts.
    Wheel bolt pattern is 4x100, which is VW, Toyota, Honda, Acura, and others. Should be easy to find wheels, I will try to find a 5spoke alloys to match my front Honda Comstar.
    Took about an hour to take it all off the car, including spinning out and hacking out a welded nut inside a unibody cavity.
    I have two CX500 Hondas, one will be losing its swingarm and rear wheels. I hope I can fabricate a frame that can bolt on, so if I hate triking, I can unbolt and go back to tipping over.
    The Subaru Justy before disassembly was 58 inches wide at the outside of the tires, so I may not even narrow it at all. The car had 60 hp, and put most of the power out the front wheel drive. The rear diff is the tiniest car one I've seen, but I hope it will hold up to the massive power and torque of the bone-stock 35 year old CX500.
    The Justy coils will be too much, I may try cutting them, or go to scrapyard and scrounge an active suspension compressor from a Merc-Lincoln, and do airbags in place of coils.
    My first trike build of any sort, I'm trying to figure out posting a pic of the scrounged irs sitting in the back of the pickup.
    Any advice? One of the Strilchuks (Lehman connection) are neighbours here, advises me to make it as low as is practical. And then he laughs and wishes me luck.
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by jiggseob View Post
    Welcome aboard. No advise but it sounds like a nice project. If possible keep us updated.
    50+ Posts
    May 2014
    NH
    Id luv to see a picture up of it
  6. #6
    750+ Posts
    Jan 2010
    east windsor ct
    see no reason it wont work.... before you get too far into it i would suggest checking the gear ration on the bike an the miata,, got into trouble w that a while back... bike was 2: something an the car was 4.11 i had to find some monster tall tires to make it work
    not positive but if you cut springs i think it makes them stiffer
  7. #7
    5+ Posts
    Sep 2016
    Default pics of the irs on the back of my truck
    Here are pics of the irs assembly, still all dirty, on the back of the truck
    Ratio of Subaru diff is 3.70:1 Ratio of CX500 final drive is 3.09:1 (11/34). So I will have to select as tall tires as is possible to keep my hwy revs down.
    The Subaru setup is 53 inches wide at the hub-faces.
    As it sits, the coils are fully extended, so the suspension is all jacked up way higher than one would want it to run. I'll have to find a way to squat it down, by shortening/cutting the springs, or by changing the springs out for some sort of airbags. Maybe getting several fat girls to sit on it ??
  8. #8
    5+ Posts
    Sep 2016
    Default Strut top mounts
    Yes, it would have been ideal if the crossmember had included top strut mounts; I will have to frame that up. The struts hold the knuckle vertical, so I will have to provide an inch or so of for-aft and side-to-side slotting of the mounts to provide adjustment of camber and trailing arm angle.
    I'm hoping to be able to stay low-tech and use the provided drum brakes. I even managed to take off the flex brake hoses, recently replaced by the previous owner of the Justy.
    I find parts such as the struts a little difficult to source. Not many Justys came to Canada.
  9. #9
    50+ Posts
    May 2014
    NH
    I like it . looks like a real nice set up
  10. #10
    750+ Posts
    Jan 2010
    east windsor ct
    ratio is pretty close
    wasnt that lucky to find one that low... didnt really look
    i did find with the tall tires an stock drum brakes, brakes were lame at best subie is light so back brakes are also "light" ....now you put tall tires on makes em worse... ended up cutting the drum part of and making aluminum spacer / adapter and putting disc brakes on it... that fixed it
  11. #11
    10+ Posts
    May 2017
    Cochranton,PA USA
    How did this turn out for you? I have been thinking about using a rear out of a 99 outback but gear ratio is 4.11 and bike is only 2.66 so may use some other rearend if i can find one cheap enough.
  12. #12
    5+ Posts
    Sep 2016
    Default Side tracked... house projects, kids, etc
    My IRS setup, and my CX500 are sitting in the shop, looking at each other, and thats about it.
    I did go back to the bush where the IRS donor car was, and body-sawed the lower rear body-pan, including all of the rear suspension mounts. I may use that body-pan as the bottom, and then box-in the top. No need to fabricate the frame-up of rear suspension mounts, just use the box-in framing of the top to brace up the pan. The body pan is form-fitting on the IRS, and when I box over it, there will be a lot of storage space inside.
    The kids have both moved out, so there is hope....
    Jiggs.
  13. #13
    5+ Posts
    Jul 2019
    Texas
    I know this is a few years old, but have there been any work/progress on this? I am using Miata parts on my own build.
    TORKER.
  1. How many want a cheap Trike
    By Illini_Triker in forum Honda Trikes
    Last Post: 12-19-2014, 09:34 AM
  2. Cheap GPS ??
    By Rsw in forum Accessories
    Last Post: 05-29-2013, 06:21 AM
  3. Trunk light mod, cheap
    By dadorfman in forum General Discussion
    Last Post: 02-06-2013, 02:51 PM
  4. Cheap Trailer !
    By Rsw in forum Trailers / Campers
    Last Post: 10-14-2011, 01:43 PM
  5. hot to raise your hitch cheap
    By silverdevil in forum Stallion Trikes
    Last Post: 06-04-2009, 11:30 PM
