***DK Custom Products Outlaw Permanent HiFlow Reusable Oil Filter***
Jun 15, 2013
9,132
8,865
Red Banks, MS
DK Custom Products Outlaw Permanent HiFlow Oil Filters
Available in polished aluminum or anodized black!
This Reusable Filter is the Last Oil Filter You Will Need to Buy
Medical Grade 304 Stainless-Steel Filter Flows 7 Times More Oil than a paper filter
Reduces Oil Pump Drag which equals increased Power to Rear Wheel
Faster Oil Pressure at Startup
Rare Earth Magnet Prefilters the Oil
Reduces/Eliminates Bypass of Unfiltered Oil on Startup and at High RPM
Easy to Clean
17mm Nut on the Billet Housing for Easy Removal and Install
Read all the specs on this oil filter, it offers features and performance not found in typical paper filters and it is truly the last oil filter you'll buy!
Because of the HiFlow characteristics of this Oil Filter, resulting in less oil pump drag, Dyno Runs consistently show an increase of 4-8 HP and an increase of 4-12 ft. lbs in Torque (Twin Cams).
Quote from Hot Bike Magazine:
"Besides doing a superior job of cleaning and cooling the oil, independent testers doing back-to-back dyno comparisons of these reusable oil filters and an ordinary disposable, charted as much as an 8-horsepower bump along with 10 more lb-ft of torque."
Read more about the full specs of the polished aluminum HERE and the black anodized HERE
Darryl
Superior Filtration, Higher Oil Flow Rates, Plus Looks Good Doing It!
INCREASED HP & TORQUE - COOLER RUNNING ENGINE
HiFlow Reusable Filter is the Last Oil Filter You Will Need to Buy
Click HERE for Info
~OUTLAW High Performance Cleanable Oil Filter~
*Polished Finish*
**INCREASED HP & TORQUE - COOLER RUNNING ENGINE**
Click HERE to see more photos and details!
*Also available in Anodized Black*
DK CUSTOM PRODUCTS
HiFlow Reusable Filter is the Last Oil Filter You Will Need to Buy!
Fits All Harley's 1986-Up (Sportster, Twin Cam, Big Twin Evo)*
*Does not fit 1986 FXWG, FXSB, FXEF
Customer Review:
Good quality! Review by: Tom
Great part that functions as an oil filter and an oil cooler. Way better flow than paper oil filters. Buy it you won't be disappointed. (Posted on 7/29/2019)
Thanks, Tom!
Go HERE for more photos & details!
Astro5150
Astro5150
