Results 1 to 9 of 9
Thread: Tr-Glide rear shock options with shock lift mount.
    20+ Posts rick1201's Avatar
    Jun 2012
    Millsboro, De
    Default Tr-Glide rear shock options with shock lift mount.
    Hello, I am looking to replace the HD air shocks on my 2011 Tri_Glide. Progressive offers a Tri-Glide specific non air shock. Model 444. The length of this shock is 1/2 inch longer than the stock air shocks. It is my understanding this length will NOT work with the lift brackets I have installed. Looking for recommendations in a spring shock that would be compatable for my use, I am quessing a 13 inch size shock. I plan on mounting upside down for an easier adjustment to the preload settings. Any recommendations from anyone who has replaced the air shock? In addition I am planning on the HD springs ,any advice on where to start with a pre load setting ? Any and all comments and advice would be appreciated. Thank you.
    Rick
    I used the 444 before they made a TRI application. I used the ones for a standard touring bike. I weigh 220lbs and mostly ride by myself. Wife has her own trike. I set the pre=load at 3 turns. 20k miles on setup and am completely happy. I also run the lift kit with the 444's
    Apr 2013
    Redmond
    I did the same and set my pre-load to 3 turns as well based on your recommendation and subsequent to the original setting, wife and i went on a week end trip so anticipating the extra luggage weight i increased 1/2 turn to 3 1/2 and eventually returned to 3 turns, as the extra 1/2 was too much. Kinda rough ride solo. It really is dependent on the weights you are dealing with. I weigh 165lbs and the wife is about 125lbs so the OP should take his and passengers weight into consideration to determine his own settings.
    Roger
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by rick1201 View Post
    Rick
    The shocks are built to mount upside vertical. They will not function properly mounted horizontally or in the upside down position. Valving inside the shock is in the bottom and must not be allowed to get air.
    Jim Murphy
    Iron Butt Rider 2001
    Lee the manufacturer (Progressive) states in their install instructions that the shocks can be mounted upside down for better access to the adjuster if necessary.
    Apr 2013
    Redmond
    Lee, pray tell, where would the AIR be coming from in a sealed unit???
    Roger
    100%, as I personally spoke to Progressive prior to purchasing my set!! At that time, they did not have the shocks specifically for the TriGlide. Mine works fine, how about yours Gorilla????
    Roger
    250+ Posts Dirtydan's Avatar
    Jul 2015
    San Tan Valley, AZ
    Jun 2012
    Millsboro, De
    Thanks for the helpfull advice. I am thinking that I will go with the 444 shocks also. I weigh in at around 285 so will probably go with the HD springs and starting out with 2 and a 1/2 turns and go from there. Wife rides around half the time but weighs in somewhere around 140 or so. Thanks again for the advice.
    Rick
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    I installed the Progressive 416's on my Trike. That let me keep the ease if the air adjustment for changing weights & also took care of the non working Harley shock. Totally different ride.
    I also have no leaks in the air system, so it isn't a problem either. All it takes is a bit of care when you work on the air.
    You can also use an electric air system if you want. That gives you the ability to change the pressure according to road conditions without stopping.
    But I guess each to their own.......
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  1. shock mount on motortrike
    By 3W-lonerider in forum Honda Trikes
    Last Post: 07-17-2013, 03:54 AM
  2. Rear Shock Lift Kit
    By Fire-Hound in forum Harley Trike Conversions
    Last Post: 01-29-2013, 05:36 PM
  3. Tri-Glide rear shock psi
    By motorman7 in forum Harley Tri Glide
    Last Post: 09-01-2009, 09:54 PM
