Results 1 to 12 of 12
Thread: vibration
    10+ Posts sprayman's Avatar
    Mar 2010
    belle river ont
    Default vibration
    vibration when i first take off 95 goldwing trike could it be front u join
    TOI - Michigan CadtoChrome's Avatar
    Dec 2008
    Oakley, MI
    Default Re: vibration
    Quote Originally Posted by sprayman View Post
    We need a little more info on your problem.
    Does the vibration stop?
    Is it a low speed only (like just starting off or below 10mph)
    can you give us some idea where the sound comes from?
    Is there any noise associated with the vibration?
    What ever you can tell us will help.
    Regards,
    Chuck
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Mine does a little chatter if I take off with out enough gas. Only the first 20 feet.
    150+ Posts TRIKERBOB69's Avatar
    Mar 2010
    PA.
    any vibration that is noticable "can" be a problem, u-joint, drive shaft or even a wheel hub, does it vibrate when you decel from say 65? if so it does sound like its in the drive train, in that case,,,,see you installer! check the wheel tightness and check you cv boots if yours have them! bol jmho
    1250+ Posts katfish16's Avatar
    Feb 2008
    Gallion, Alabama
    Have U had the alternator changed or worked on.???? If so the rubber busings should have been changed. This will cause engine vibration...
    Steve & Cathy
    Alabama
    U.S. Coast Guard (retired)
    350+ Posts Nauga Mok's Avatar
    Dec 2009
    Las Vegas, NV
    Realy need more information regarding when it happens, under what conditions it happens, etc. Any solutions we come up with from what you've given us would be pure guess work.
    NM
    Mar 2010
    belle river ont
    sorry it took so long to get back it chatters when you let the clutch out slow only noticeable on take off and not all the time i do get a vibration between 65 and 70 no; vibration between gears other than the little chatter taking off in first thanks for all the reply s
    might be clutch chatter. only a guess
    TOI - New England
    Mar 2008
    Conn
    the problem of having such a smooth and quiet bike . I once hunted for 10 min while riding for a gingeling noise sounded like a ringing . after 10 min I found it was my key in the ignition .
    Thats funny John
    200+ Posts Jimsjinx's Avatar
    Mar 2008
    Alabama
    You may just need to try different oils. Mine had a "shudder" on takeoff, especially on a hill. First, I learned to give a tad more throttle, but the vibe was still there, but less of it. I changed out the Honda Spec'ed oil, and went with Delo 400 LE, and it is virtually gone. It still does it if I don't get on it when taking off 2 up. Hope this helps, jimsjinx
    TOI - New England
    Mar 2008
    Conn
    Mine feels better with the Shell Rotella 10W 40 in the Blue jug I get at Tractor Supply or Wally World... 2nd best thing I did to the trike
  1. Vibration?
    By howardg in forum General Discussion
    Last Post: 07-01-2013, 09:44 PM
  2. MPA Vibration
    By Deadeye in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-22-2012, 02:34 PM
  3. What is that vibration?
    By SJR in forum General Discussion
    Last Post: 07-30-2011, 10:38 AM
  4. Bad Vibration
    By chatty in forum General Discussion
    Last Post: 08-18-2009, 12:11 PM
