ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  3
Results 1 to 11 of 11
Thread: SSS: Stupidly Simple Solution
    60+ Posts KWSchin's Avatar
    Oct 2015
    Cuero
    Default SSS: Stupidly Simple Solution
    I posted a while back about the progress on my Kawasaki Voyager Champion conversion, and how it was unrideable, with the front end flopping hard left, or right.
    Well, I found the stupidly simple solution; drop the rear tire pressure from 35 pounds to 20 pounds. Yep, that's all it took. Lowered the rear end by a 1/4" and now she's a dream.
    Me n Mama went for a little spin, sans the bodywork, and it was a pleasure. Still waiting for the rear brake residual valve. Once the rear brake system is done, it will be time to put on the bodywork, and wrap things up.
    Easy to back out of the shop, and U-turns are a breeze. I'm gonna like this, for shore.
Size:  520.5 KBName:  DSCN0026.JPG
Size:  541.8 KBName:  DSCN0027.JPG
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Looking good so far!!!
    Glad you found a simple solution!!!
    Dec 2012
    Santee
    Schin
    Did Champion not send you the residual valve? Mine was in one of bags of parts.
    Ray
    2017 Harley Triglide
    Tijuana Border
    Quote Originally Posted by ol' school View Post
    +1
    Oct 2015
    Cuero
    Default Residual Valve
    It did come with the kit, but the threaded male end cracked when I tried to torque it to specs. Luckily I felt it give before it broke off in the "T" fitting. Supposedly one was mailed to me, but it's never shown up, and it didn't have a tracking number. After a week of waiting, Champion shipped one by UPS, with a tracking number. It's supposed to arrive by Wed.
    "Schin
    Did Champion not send you the residual valve? Mine was in one of bags of parts."
    250+ Posts 2Paps's Avatar
    Jan 2016
    W FL Panhandle
    Are they stock pipes? Does Champion replace the exhaust?
    Tryke Flyer!
    2010 GW 1800 with 2010 CSC Cobra kit
    2010 Kawasaki Voyager ABS with 2016 CSC Kruze Kit - Gone but definitely not forgotten.
    60+ Posts trikerbiker634's Avatar
    Jul 2015
    sun prairie, wi
    is the exhaust fairly quiet? and champions own exhaust for trikes?
    Dec 2012
    Santee
    Stock pipes for the 2009 Kawisaki.
    Ray
    Tijuana Border
    Jan 2016
    W FL Panhandle
    Hmmm, interesting. CSC changes out the aft end of the exhaust and replaces it with "theirs."
    Tryke Flyer!
    250+ Posts Dirtydan's Avatar
    Jul 2015
    San Tan Valley, AZ
    On my Champion they sent new intermediary adapters for the exhaust. They go between the muffler and the head pipe. Stock mufflers on mine also. Although they are gutted.
    I had the hardest time bleeding the rear brakes. I had it together once bled and done. But I routed the line incorrectly coming off the master. So took it apart, re routed and put it back together. Couldn't get an air bubble out to save my life. Even with a vacuum system. We finally took it all apart and with low pressure and the aid of some plugs forced fluid through section by section. Brakes bled finally. Phew!
    Oct 2015
    Cuero
    Default Stock Pipes on the 2009 Voyager
    "Are they stock pipes? Does Champion replace the exhaust?"
    Champion's conversion for the Kawasaki Voyager uses the stock head pipe, and mufflers, with extensions. The left muffler pipe has to be cut, but the right is used, as is.
    The stock exhaust is not quiet, but it's not loud either. It's got just enough noise for both my wife and I to be happy. :-)
    Expecting the Residual Valve today, so back to work on her tomorrow. Yay!!
    Shin
  1. SSS: Stupidly Simple Solution
    By KWSchin in forum General Discussion
    Last Post: 02-21-2016, 09:13 PM
  2. Quick solution to add 12V / 5V to FLRT trunk
    By cagless in forum Harley Freewheeler / Road Glide 3
    Last Post: 07-07-2015, 09:22 AM
  3. Possible Solution to the Voyager Kit Legality Question
    By Simdog in forum Outrigger Style Trikes
    Last Post: 10-19-2012, 10:14 PM
  4. Help on oil cooling solution
    By tryker55 in forum Harley Trike Conversions
    Last Post: 10-10-2011, 01:09 PM
  5. A solution to burning leg
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 08-28-2009, 08:52 PM
