Results 1 to 13 of 13
Thread: roverv8auto front engine
    May 2015
    Nambour queensland Australia
    Default roverv8auto front engine
    G'day all. this my build I thought I had it on here. the engine is LPG fuelled rover v8 with auto transaxle & Di dion rear suspension out of An Alfa Romeo Alfetta V6
    13000+ Posts FuzzyWuzHe's Avatar
    Oh boy ... another build thread
    May 2015
    G'day Fuzzywuzhe. I thought I had put 1 up couldn't find it. I hope people out there follow along as I go further into the build.
    May 2015
    Good evening all. this is the rear guard set up. Its used on beach buggy type vehicle. I have to wait for a price & when they will be flopping 1.
    250+ Posts Dirtydan's Avatar
    Jul 2015
    San Tan Valley, AZ
    Subscribed. Looks like fun!
    May 2015
    This is the LPG carby's setup. it will use a tanks shaped to fit into a spare wheel well with an off
    road spare tyre cover on it.
    Yep lets enjoy this.
    May 2015
    G'day all. thanks for following the build. I hope to get the mounting plates cut out & drilled this week to solid mount to the frame I also have to make the rear frame to support the rear shock absorbers I watts linkage & LPG tank.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Is that the Buick Aluminum Head engine?
    May 2015
    G'day 1dn5up. The engine is out of a range rover. All aluminium same as the Buick 215. Rover bought the rights to the engine. the alloy head Buick was a 300. We didn't get to many of those out here in OZ. This motor is popular for it low weight. I hope to get away with the standard front forks but it will depend on steering & trail when it's rideable. because of the dual disc & anti dive brakes I'm thinking of mounting the forks onto a separate fork & increasing the rake in the spacers
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I had that engine in the Rover Car with 2 SU carbs. It was a real slug .
    Would make a grate power plant for your project. Wish you luck.
    May 2015
    good engine heavy body.
  1. Replies: 45
    Last Post: 05-15-2019, 03:41 PM
  2. vw engine ser# ID
    By bluedog in forum VW Powered Trikes
    Last Post: 07-14-2013, 08:17 AM
  3. New engine?
    By molinoman in forum Stallion Trikes
    Last Post: 05-01-2013, 09:14 PM
  4. vw engine/hp
    By grigglybob in forum General Discussion
    Last Post: 03-06-2013, 03:26 PM
  5. What To Do With A Spare Engine
    By msocko3 in forum Harley Trike Conversions
    Last Post: 02-02-2012, 01:06 AM
