hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn4dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn4Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
SSpoon14hardwickbvNew Member Introduct...Hello from VA
dthorn4nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn4TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Likes Likes:  5
Results 1 to 9 of 9
Thread: Will I Have A Clearance Problem Loading Into a Toy Hauler?
    1+ Posts FlyingChief's Avatar
    Jan 2016
    Indio, CA, USA
    Default Will I Have A Clearance Problem Loading Into a Toy Hauler?
    Getting very close to buying a late-model (2012-current) GL1800 trike with a Roadsmith conversion. We will want to take the trike with us when we travel in our Raptor toyhauler. There are two problem areas for clearance with 2-wheelers: scraping the back of the bike/mufflers at the bottom of the ramp and hitting the frame (high-center) at the point that the ramp transitions to the floor of the TH. Given the longer wheelbase of the RS, am I heading for trouble?
    I'm looking for actual experience from anyone who is loading an RS into a toy hauler. Will I have clearance problems at the bottom of the ramp or at the top of the ramp? With or without the running boards?
    Thanks!
  2. Roadsmith banner
  3. #2
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    It all depends on the height of the toy hauler and the length of the ramp. You may need an extension of shorts to make the ramp longer to raise the angle of the ramp. Every hauler will be different. Think short extension ramp to get onto the hauler ramp. I have to jack the nose of my trailer up to lessen the hump at the entrance of the trailer.
  4. #3
    300+ Posts brianl's Avatar
    May 2013
    leominster, ma. USA
    Default ramps
    I have a 97 wing with a Roadsmith kit. I couldn't load it onto my landscape trailer (4'-0" ramp) without bottoming out. I tried all the tricks like jacking up the front of the trailer etc. I bought a set of 3 curved ramps, 9'-0" long and it works great. You can check them out at http://www.discountramps.com/big-boy...amp/p/MF3-AMR/ That's me loading up in the picture.
    P.S. They come apart and fold up and should fit easily into your trailer.
  5. #4
    450+ Posts GrandpaDave's Avatar
    Jul 2013
    Hankinson, ND, USA
    Hi,
    I don't have the RS kit, mine is a Champion and it has about 3" of ground clearance. When I load it into my toy hauler 5th wheel this is what I have to do to keep the trike from dragging and the mufflers from digging in when I unload. The extra ramps are 4' long. I'm planning on attaching a hinged 5' long x 6' wide extension to the top of the ramp door that I can just flip out this spring to make it a simple process instead of carrying the three ramps.
    Here's a picture of the trike and the camper set up to load / unload the trike. Hope it is helpful.
  6. #5
    20+ Posts
    Sep 2015
    Murchison ,Tx
    Default Ramps
    Are the 3 runners made of wood ( 1x8 Etc ) or metal? I am About to pick up my Valkyrie RS trike. I will pick trike up with utility trailer with dove tail and 3 ft ramp . Didn't think about high center. May be a problem.
    Thanks in advance
    Elliott
    TW
    Green / Cream. Valkyrie Trike
    Roadsmith
    400+ Posts mgwtrike's Avatar
    Nov 2014
    Loving the Southern Life in Central Florida
    Quote Originally Posted by FlyingChief View Post
    Thanks!
    Would it be possible to take your Raptor toyhauler to a Honda dealer or a Roadsmith conversion center
    and try a Roadsmith conversion unit and see what you need to do for clearance?
    Goldwing:
    A real butt kicking, wheel popping, tire burning old man's bike.
    MIKE W.
    Jul 2013
    Hankinson, ND, USA
    Quote Originally Posted by Ebbiker123 View Post
    Thanks in advance
    Elliott
    Elliott,
    The runners are 48" 2 X 10 material with an aluminum lip type end on them.
    Dave
    2000+ Posts Rick Kay's Avatar
    Dec 2011
    Huron, Ohio
    Grandpa Dave has a nice setup! I do something very similar, but I don't use the center board, which gives me a little more room for the exhaust tips. I generally have to take the tongue jack all the way up, also, which makes all the difference with clearance issues.
    Dave, was your photo taken at the KOA in the Ocala National Forest? They have identical RV hookups.
    Rick
    2006 FLHTI/2012 CSC Daytona
    1987 FLST
  10. Roadsmith banner
  11. #9
    20+ Posts
    Sep 2015
    Murchison ,Tx
    Default Runners
    Quote Originally Posted by GrandpaDave View Post
    Elliott,
    Dave
    Thanks for the info. Brought my new trike home yesterday and had a little clearance problem. I may try your way, seems effective and simple enough.
    Thanks again
    Elliott
    TW
    TW
    Roadsmith
  1. loading ramps
    By gerald martin in forum Harley Freewheeler / Road Glide 3
    Last Post: 11-12-2015, 03:20 PM
  2. car dolly/ bike hauler/problem
    By eagle1 in forum Trailers / Campers
    Last Post: 09-18-2015, 08:10 PM
  3. Loading Ramps
    By Strohkr in forum Harley Trike Conversions
    Last Post: 04-02-2013, 10:52 PM
  4. Loading onto a trailer
    By rickt in forum Honda Trikes
    Last Post: 11-26-2010, 04:08 PM
  5. Trailer, Toy Hauler Loading
    By lzski326 in forum Trailers / Campers
    Last Post: 09-06-2010, 10:59 PM
