Ironhorse542Ironhorse54California Sidecar T...Helmet release button
Kneesinbreeze9rhino 2Harley Freewheeler /...Hiway pegs without installing crash...
Kneesinbreeze9Papa ZookHarley Freewheeler /...Hiway pegs without installing crash...
Davep6DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Ironhorse542Papa ZookCalifornia Sidecar T...Helmet release button
Kneesinbreeze9JerseyGirlRiderHarley Freewheeler /...Hiway pegs without installing crash...
DK Custom Products362SmittysTrikeHarley Tri GlideWhat did you do to Your Tri-Glide T...
Vin5Rogue1Harley Tri GlideCold Engine Revs High When Starting
diferg13hardwickbvNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13woodyNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH15Jack KlarichHarley Tri GlideElectric Fans on 2014 Tri Glide
Kneesinbreeze9Jack KlarichHarley Freewheeler /...Hiway pegs without installing crash...
TomyJ7Jack KlarichHome Built TrikesShenanigans
Vin5Jack KlarichHarley Tri GlideCold Engine Revs High When Starting
dthorn8Rogue1Harley Tri Glide2024 Tri Glide front axle nut torqu...
MDO101DK Custom ProductsHarley Freewheeler /...What Did You Do To Your Freewheeler...
diferg3Motorcycle MikeChampion TrikeChampion irs banging noise on bumps
Kneesinbreeze9My TurnHarley Freewheeler /...Hiway pegs without installing crash...
MDO101LD-OrdieHarley Freewheeler /...What Did You Do To Your Freewheeler...
diferg3difergChampion TrikeChampion irs banging noise on bumps
Rogue15Rogue1Harley Tri GlideOil pressure gauge.
Vin5Dan SCHarley Tri GlideCold Engine Revs High When Starting
Rogue15Dan SCHarley Tri GlideOil pressure gauge.
HDUSA113ol' schoolNew Member Introduct...New to Trike Talk
diferg13ol' schoolNew Member Introduct...Hello from Southeast Georgia U.S.A
scuzzi4scuzziHarley Tri GlideTri Glide extended reach seat
Vin5rhino 2Harley Tri GlideCold Engine Revs High When Starting
diferg3Marc HChampion TrikeChampion irs banging noise on bumps
Vin5VinHarley Tri GlideCold Engine Revs High When Starting
Frisco5Marc HCalifornia Sidecar T...Side pod door open signal
diferg13Uncle FesterNew Member Introduct...Hello from Southeast Georgia U.S.A
JohnnyVDA13Uncle FesterNew Member Introduct...Hello I am from Belgium
jef_nik20002jef_nik2000Lehman TrikeMonarch 2 center cap removal proced...
jef_nik20002Papa ZookLehman TrikeMonarch 2 center cap removal proced...
Tritek4stancotreauLehman TrikeAvoid buying a Lehman?
Rogue15Jack KlarichHarley Tri GlideOil pressure gauge.
Tritek4Papa ZookLehman TrikeAvoid buying a Lehman?
gfaltersack8DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
Kneesinbreeze9Noodles107Harley Freewheeler /...Hiway pegs without installing crash...
Rogue15Old Road DogHarley Tri GlideOil pressure gauge.
Tritek4TritekLehman TrikeAvoid buying a Lehman?
Burnerboy11rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
JohnnyVDA13Phu CatNew Member Introduct...Hello I am from Belgium
ZZMACH114BrokenBackJackHarley Tri GlideNew Member Hello from NH
diferg13BrokenBackJackNew Member Introduct...Hello from Southeast Georgia U.S.A
JohnnyVDA13BrokenBackJackNew Member Introduct...Hello I am from Belgium
JohnnyVDA13Papa ZookNew Member Introduct...Hello I am from Belgium
Frisco5FriscoCalifornia Sidecar T...Side pod door open signal
JohnnyVDA13Jack KlarichNew Member Introduct...Hello I am from Belgium
diferg13Jack KlarichNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH114SullyHarley Tri GlideNew Member Hello from NH
diferg13SullyNew Member Introduct...Hello from Southeast Georgia U.S.A
Kneesinbreeze9pigfoot63Harley Freewheeler /...Hiway pegs without installing crash...
AriNV14KneesinbreezeNew Member Introduct...New to trike
Burnerboy11KneesinbreezeCan Am Spyder Trike...How many of you ride a Can Am spyde...
TXFIRE766BurnerboyHonda TrikesNew to Trikes and needing a convers...
smokey_mountain2BurnerboyAccessoriesJ&S Moto conversion to Trike Li...
Frisco5BurnerboyCalifornia Sidecar T...Side pod door open signal
Frisco5ol' schoolCalifornia Sidecar T...Side pod door open signal
ZZMACH114trike ladyHarley Tri GlideNew Member Hello from NH
JohnnyVDA13trike ladyNew Member Introduct...Hello I am from Belgium
diferg13trike ladyNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13rhino 2New Member Introduct...Hello from Southeast Georgia U.S.A
diferg13GorillaNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH114Marc HHarley Tri GlideNew Member Hello from NH
diferg13Marc HNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13ZammyNew Member Introduct...Hello from Southeast Georgia U.S.A
Bloke10Marc HNew Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13Marc HNew Member Introduct...Hello I am from Belgium
Kneesinbreeze9ZammyHarley Freewheeler /...Hiway pegs without installing crash...
diferg13difergNew Member Introduct...Hello from Southeast Georgia U.S.A
Phill Griggs2ZammyTrike TravelPIE-PIE & PIE
Bloke10ZammyNew Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13ZammyNew Member Introduct...Hello I am from Belgium
Frisco5rhino 2California Sidecar T...Side pod door open signal
Rogue15rhino 2Harley Tri GlideOil pressure gauge.
JohnnyVDA13hardwickbvNew Member Introduct...Hello I am from Belgium
ZZMACH114hardwickbvHarley Tri GlideNew Member Hello from NH
Kneesinbreeze9KneesinbreezeHarley Freewheeler /...Hiway pegs without installing crash...
ctdair1ctdairHarley Tri GlideFixed Switch
Davep13GorillaNew Member Introduct...Hello from the mountains
ZZMACH114GorillaHarley Tri GlideNew Member Hello from NH
HDUSA113GorillaNew Member Introduct...New to Trike Talk
JohnnyVDA13GorillaNew Member Introduct...Hello I am from Belgium
Bloke10GorillaNew Member Introduct...Hello from Uttoxeter UK
Sunman7GoldWingrGregHonda TrikesF1 Warning Light
ZZMACH11ZZMACH1Harley Tri GlideRinehart VS Vance & Hines for M...
Bloke10rhino 2New Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13rhino 2New Member Introduct...Hello I am from Belgium
JohnnyVDA13ol' schoolNew Member Introduct...Hello I am from Belgium
JohnnyVDA13JohnnyVDANew Member Introduct...Hello I am from Belgium
Bloke10Jack KlarichNew Member Introduct...Hello from Uttoxeter UK
Bloke10SullyNew Member Introduct...Hello from Uttoxeter UK
Bloke10ol' schoolNew Member Introduct...Hello from Uttoxeter UK
Bloke10hardwickbvNew Member Introduct...Hello from Uttoxeter UK
Bloke10trike ladyNew Member Introduct...Hello from Uttoxeter UK
Burnerboy11BurnerboyCan Am Spyder Trike...How many of you ride a Can Am spyde...
Phill Griggs2Phill GriggsTrike TravelPIE-PIE & PIE
ZZMACH13Longbeard71Harley Tri GlideLooking for Dynajet Power Vision mo...
Bloke10BlokeNew Member Introduct...Hello from Uttoxeter UK
Papa Zook2Jack KlarichHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
ZZMACH12Jack KlarichHarley Tri GlideElectric Fans on 2014 Tri Glide
ZZMACH13Jack KlarichHarley Tri GlideLooking for Dynajet Power Vision mo...
Davep6Jack KlarichHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Smitty9013Marc HSidecar ForumSmall crack down the rabbit hole
HDUSA113Marc HNew Member Introduct...New to Trike Talk
HDUSA113ZammyNew Member Introduct...New to Trike Talk
Oldman-TriGlide10ZammyHarley Tri GlideEnclosed Trailer Size
Smitty9013ZammySidecar ForumSmall crack down the rabbit hole
HDUSA113Uncle FesterNew Member Introduct...New to Trike Talk
ZZMACH114Uncle FesterHarley Tri GlideNew Member Hello from NH
ZZMACH114stancotreauHarley Tri GlideNew Member Hello from NH
Davep6rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Smitty9013Smitty901Sidecar ForumSmall crack down the rabbit hole
ZZMACH114TrampasHarley Tri GlideNew Member Hello from NH
Page 2 of 2 FirstFirst 1 2
Results 21 to 30 of 30
Thread: 08 Gl1800 Engine rattle maybe HELP
  1. #21
    300+ Posts Smoken'JOE's Avatar
    Oct 2009
    Racine, Wis
    Default Re: 08 Gl1800 Engine rattle maybe HELP
    Quote Originally Posted by ThirdWheel View Post
    Joe, is that why you put the grab bars on?
    :yes:...................My ratio is 3.55 (Jeep rear end)
    Was wondering if a different ratio would increase gas mileage. With a little better shift.
    1st to 2nd@20mph
    3rd@35mph
    4th@45mph
    5th almost never before 60mph. Or is shudders. Ride mostly in 4th.
    Folks at Roadsmith seem to think not.
  2. #22
    30+ Posts Buddy Moore's Avatar
    Mar 2010
    Hendersonville Tenn.
    [QUOTE=Bare;34243]
    Quote Originally Posted by tatco View Post
    2008 GW1800 MotorTrike. Here in Colorado I always use 85. The last tank I got was from an off brand. It started to knock when I luggedat lower rpm. And it was more pronounced when going around a right hand curve. So I'm going to run some high test through it to see if that cures the problem of the knock. Wonder if the added weight of the trike kit dictates that I use a higher grade?
    BARE, did you happen to notice that the noise was worse in the turns?
    Maybe I just need to get those rpms up when I go through the turns.[/QUOTU
    UPDATE...........
    Ok the steels and fibers have been replaced, there was always a thumping noise in the clutch basket at start-up when cold now its gone, however the knocking is still there I fill the tank with 93 octane NO DIFFERENCE DID NOT HELP.
    No change in turn
    Bear, if you haven't, I would check the timing on the engine. Not saying that is the problem That will cause the knock
    I am thinking that at 50mph in 5th gear is to low (That's when it knocks rattles)if I shift from 4th to 5th at 55 mph NO RATTLE.
    Maybe you are right the trike Differential is higher than stock 1800 that and the weight difference is why more RPM shift points are necessary.
    Does any one know the how much the gear ratio has changed??
    Bare
    Bare, If you haven't checked the timing on the engine, I would. Not saying that is the problem, but if it is out of time it could cause it to knock.
  3. #23
    20+ Posts EZglider's Avatar
    May 2010
    West Melbourne,Florida
    Hey Bare,I had the same noise.The shop said it was the clutch and replaced it and basket.The noise was still there.It ended up being the alternator drive.It has a dampener and the clip that holds it together broke.Had to have engine removed to replace it.2200 dollars and it's fixed.Good luck.
  4. #24
    i wouldnt have believed it . my engine sounded like it was coming apart heaver rattle at about 3000 rpm slight knock at idle. turned out the cheap alternator i bougt on ebay the bearing was bad causing all of it i replced it and now just smooth as silk
  5. #25
    550+ Posts Solidbob's Avatar
    Tx
    You are aware this Thread is 4 years old....
  6. #26
    450+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    Change your plugs...
    Oh yes... i forgot to tell you
    change your plugs....
    I used to run 89 in my 05. I though well if 87 is good 89 should be great....
    that is until I took a aturn on washington DC and my engine made noises like someone had dropped a box of flat washers in the engine...
    I went to Wd in billings and it was very intermittent, that is untill I went up beartooth pass, and it was gone. I asked the Honda rep and he told me it could be one of 3 things.
    Plugs, or baro, or vacum sensor.
    Went back home changed the plugs....
    KNOCK GONE. the plugs were covered with unburned fuel..
    Went back to 87, and haven't heard detonation since.
    I should have learned this from my mini vans. It calls for 87 and I once put 89 in the tank and it ran like CRAP.
    But once the plugs are crapped out you must change them out, and after that go back to 87 gas.
  7. #27
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    VTX 1300 here. Can't use 5th till 60 mph.
  8. #28
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I've read over and over that burning a higher octane in an engine that only requires 87 is a complete waste of money. Especially in this day and age when oil companies are widening the "spread" between 87 and 91 or 92. Used to be 20 cents, and now it is 40 or more in some places. Even the oil companies admit a higher octane is not necessary and they love to sell the stuff.
    I've owned several Wings, from 1100 to 1800 and never had to run at lower gear at highway speeds and that means 5th gear at 40 MPH. Never seemed like I hurt any of the engines.
  9. #29
    I had the rattle . sounded like the engine was trashed. it was the rear bearing in the cheap altenator i bought on ebay. i would not believe that the sound would transfer like that. new bearings sounds like a sewing machine again
  10. #30
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Quote Originally Posted by skuuter View Post
    I run a tankful of premium through mine about every tenth tank or so just for the extra injector/carbon cleaners in it...."how I know" about the mileage.....
    Skuuter, do a search, Google, on "top tier gas" , it is very interesting. Top tier gas is gas recommended by major auto manufactures, GM, BMW, Mercedes, Ford, etc, that contains cleaning additives to meet their specs. Only those gas companies that meet those min. requirements get listed. Most interesting is the requirement that those detergents that are used must be used in all grades of gas that they sell and at all their stations.
    Sorry to get off the original topic.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
  1. Engine Life of the GL1800
    By Motogordo in forum Honda Trikes
    Last Post: 09-20-2012, 07:17 PM
  2. gl1800 engine tapping noise
    By john in forum General Discussion
    Last Post: 06-05-2012, 08:12 AM
  3. New rattle
    By mw1151 in forum Harley Tri Glide
    Last Post: 10-19-2011, 06:29 AM
  4. Valkyrie with a rattle?
    By Fishboat in forum Honda Trikes
    Last Post: 07-16-2011, 08:31 AM
  5. 06 GL1800 Rough Engine
    By kwputt in forum Honda Trikes
    Last Post: 05-28-2011, 08:04 PM
