BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  2
Results 1 to 14 of 14
Thread: Progressive Monotubes used with rake install?
    Feb 2016
    Cordova, TN USA
    Default Progressive Monotubes used with rake install?
    I have monotubes in my Gl1800 and would like to use them with a rake kit I am installing. I know how to machine the parts to fit but have been unable to find any info on the internal construction of the aluminum screw in cap area. Don't want to make this conversion if am going to cut into the gas charged area.
    Any suggestions will be appreciated.
    Mar 2011
    mountain home,ar. USA
    If the Progressive monotubes don't require a different fork cap than OEM, all you should need to do is buy a extended fork cap and install to compensate for the rake.
    Talk to Progressive to be sure and to get good info on whether the monotubes work correctly on a raked fork.
    BTW, I have a 2 1/2" extension on my 6 degree rake to bring front end back correct height on my Roadsmith kit. YMMV.
    Jun 2010
    Indianapolis, In.
    You need to call Progressive to find out for sure.
    Having said that, I contacted them when the mono-tubes was 1st introduced. After some time and several conversations, I was told they would not be "making" mono-tubes for trikes with rake kits. I was also told, if the caps were changed, that would void any warranty.
    However, there seems to be an increasing number of trike owners that are installing the mono-tubes.
    Maybe Progressive will change their tune if enough of us contact them!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    40+ Posts
    Apr 2015
    Sunset,La. USA
    I didn't add any extensions to mine. My trike leveled out well.
    Mar 2011
    Quote Originally Posted by ferg View Post
    Every raked trike I have seen has at least a one inch extension. I'm not sure how yours could be level with a rake kit installed unless the front end was already high or the rear end low. Whatever works I guess.
    40+ Posts
    Apr 2015
    Sunset,La. USA
    Quote Originally Posted by mhgoldwing View Post
    Not wanting to hijack this thread, you have a P.M.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    I do not recommend using the fork extensions with monotubes. ferg is correct that the monotubes alone will level the front end, so fork extensions with monotubes aren't needed.
    Feb 2016
    Cordova, TN USA
    Thanks for the info and suggestions. Will try forks without extensions first. I did not try to remove the Progressive fork caps that seemed to be attached to the monotubes. If I could remove the existing caps on the monotubes there would be not problem fitting them into the extensions.
    Will just have to work through this one.
    Buck
    200+ Posts tndragonrider's Avatar
    Feb 2016
    Monterey, TN, USA
    I have yet to get my wing back with the Razor kit. As soon as I do I will know if I need extensions. I probably won't since the Monotubes are higher to begin with, the Razor doesn't lengthen the wheelbase and the rake is only 4 degrees.
    If you need them added just PM for the Monotube thread size that I got from Progressive. The ones the have are also put on with Red Loctite, so a 20 second shot of heat from a propane torch will be required to release it.
    Present ride--'05 GL1800 w/ 2015 Motor Trike Razor Conversion
    Past Rides--'07 Triumph Speed III, '03 GL1800, '83 GL1100, '97 Honda 750 Magna, '80 Honda GL500 Silverwing, '69 Triumph Trophy 250, '78 Honda CB750F, '75 Honda CB400, '76 H-D Superglide (Liberty Edition), '69 Yamaha 125 Enduro, '69 Kawasaki Mach III, '70 Yamaha HS1 (90 Twin)
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by tndragonrider View Post
    You will not need the extensions.
    300+ Posts
    Jun 2014
    S.E. Ohio,Close to the triple nickel
    I want to or need to change the front suspension on my trike.I am not sure what to do.I was 1st thinking of progressive springs to raise the front and take some bounce or movement out of the front.I see some are doing the monotubes.How is that working on the trikes? Also how about a fork brace?
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by Fabricater View Post
    Your buddy who is painting your trike can hook you up with a rake kit and fork extensions. Id go with that before you change the springs, you might not like the stiffer ride.
    300+ Posts
    Jun 2014
    Quote Originally Posted by Bazooka View Post
    I think you got me confused with someone else.I have your 6 deg rake kit installed ,I think the front is a little low and have a little more movement than I like,but it does ride good.I also have more push or maybe it's flex in the corners than I like.Maybe I need heavier wt fork oil? I have 5 wt in it now.
    Yes on the heavier fork oil. I run 30 wt in my TRI
  1. Replies: 9
    Last Post: 04-24-2016, 08:15 AM
  2. rake install
    By geraldlanc in forum Honda Trikes
    Last Post: 06-05-2012, 07:19 PM
  3. Progressive springs with 6* rake??
    By wanderingbear in forum Honda Trikes
    Last Post: 10-21-2011, 11:20 AM
  4. rake kit install 1500
    By jm93wing in forum General Discussion
    Last Post: 07-12-2009, 09:42 AM
