LD-Ordie3SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie3Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie3LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Results 1 to 7 of 7
Thread: Hydraulic clutch too hard to pull
    30+ Posts
    May 2013
    Keokuk, Iowa
    Default Hydraulic clutch too hard to pull
    Had surgery on my trigger finger which did not go well. Be a long time before I can pull in the clutch on my 2015 Tri glide. Any options out there like the easy pull clutch Harley used to have which doesn't work with a hydraulic clutch. Its almost riding wx...
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Meme Master
    Jan 2014
    Farmington, NH USA
    Google: Rekluse auto clutch.
    Pricey yes, but worth every penny if it gets one back out "in the wind", IMO.
    30+ Posts
    May 2013
    Keokuk, Iowa
    Thanks, I like the clutch arrangement for the right handlebar.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    So how do you manage the clutch lever and throttle with the same hand ?
    A Recluse or Auto-clutch is what you need.
    Jim Murphy
    Iron Butt Rider 2001
    Jan 2013
    My first thought would be move the throttle to the left side. Doesn't take too much grip to turn throttle. Palm paddle.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Quote Originally Posted by Huelshorst View Post
    They are good for some, but really don't make sense for most. Why "learn" how to ride all over again for a short period of time, unless you're thinking the finger issue will be permanent?
  1. 014 & pull in clutch to start in gear?
    By Beorn of Ga in forum Harley Tri Glide
    Last Post: 09-09-2014, 06:55 PM
  2. Do I have to pull the clutch to replace the compensator
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-25-2013, 10:44 AM
  3. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
  4. ez pull clutch
    By chev58 in forum Harley Trike Conversions
    Last Post: 11-29-2011, 05:57 AM
  5. E-Z pull clutch
    By Mcwac in forum Harley Trike Conversions
    Last Post: 10-11-2011, 03:20 AM
