Likes Likes:  10
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 62
Thread: Oil Filter Relocation & Dual-Cool Oil Cooler
  1. #41
    450+ Posts MB1953's Avatar
    May 2014
    Peru, IN USA
    Quote Originally Posted by hedgie57 View Post
    Well , I must be dumber than I look. Can't get the bolts for the passenger floorboard out. Split one socket trying , any tricks?
    I had to use heavy wall socket and a long breaker bar. Evidently the factory installed them with a serious dose of threadlocker! It was a struggle for the first few turns, then it got progressively easier. the last1/2 dozen turns spun out by hand. If I was to do it again, I would consider an impact wrench.
    2017 TriGlide Vivid Black - DK Outlaw AC, Fullsac performance baffles, PowerVision from DK, Love Jugs Mighty Mites from Papa Zook, HD Black Reach Bars, all kinds of BLACK stuff... Hi, my name is Mark and I used to be a chromeaholic!
    was - 2014 TriGlide Vivid Black - DK Custom Lift, 2" tank lift, DK Dual Cool, DK Discrete breather, Wards Parts Werks FCS, HD Reach Bars, all kinds of shiny stuff!
  2. #42
    Quote Originally Posted by MB1953 View Post
    I had the same experience.
  3. #43
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    The factory, or a tech at a dealership, may have over-tightened them, or used excessive thread-locker. Specs are 55-65 ft. lbs., so that is not really high.
    It is an oddball bolt, with a smaller than normal hex head for the size thread it is. It is also a shallow hex head, so make sure your heavy socket is on totally flush and use a long arm ratchet or breaker bar. Do Not use heat. There is plastic and rubber too close.
    You might have some joy if you put a socket on the bolt and give it a sharp rap.
    If you have not removed the passenger floorboard, you definitely want to get that out of the way for easy access.
    If you try the above and still are having a problem, give us a call or email with your phone number.
    www.DKCustom.com
  4. #44
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    Quote Originally Posted by LadyonaMission View Post
    I am waiting for someone to offer up the tricks. I installed the driver floorboard extensions on the right side of my Freewheeler, but I can't get the bolts out on the left side.
    When one of mine finally broke loose on the gear shift side, I durn near tore a couple of knuckles off. It hurt. Bad.
  5. #45
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    I ALWAYS heat up my bolts before trying to remove them. It softens the loctite and allows much easier removal.
    Using an impact gun on a loctited bolt can easily strip the threads ... and now you have a real problem.
    I use a simple cheap torch lighter from Walmart for under $4.
    http://www.walmart.com/ip/Ronson-Jet...ghter/31954644
    Bob
  7. #46
    40+ Posts hedgie57's Avatar
    Jan 2014
    Ohio
    Finally got the top bolt out. Once I got it to move I just kept going back and forth. Seems like maybe the friction created loosened it up a bit. Was still a bear to turn. Bottom bolt won't budge, gonna play with it today maybe try an impact wrench. Sure hope the rest of it goes smoother. Thanks all for your ideas on this, was very helpful
  8. #47
    Feb 2016
    omak, wa, usa
    Default i wimped out
    After standing on the end of the wrench with my oversized frame I had dealer do the install
  9. #48
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Default 2 of 3
    Today while riding I had the bright idea that maybe I could move the bolts while the trike was hot so I pulled in, put on gloves and loosened 2 of the 3 with an 8" wrench, extension and socket. The 3rd one will not budge so I guess I will have to come up with a better idea.
  10. #49
    Sep 2014
    Box Elder, SD
    Wow, that is a little crazy. I didn't have any issues taking the bolts out. When you get everything loose, trying cleaning up the threads before reinstalling. Jim
  11. #50
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    After the thread cleaning, I use never size and the lock washer method on all aluminum stuff and even steel. Oxidation is not user friendly.
  12. #51
    Just make sure the Never [Anti] seize is not copper based, If it is it will oxidize Aluminum..Especially if theres any contact with moisture... I ruined a set of Aluminum wheels on a 05 Dodge i had...
  13. #52
    80+ Posts
    Aug 2012
    Lethbridge Alberta
    Have a couple of new pictures-
    Here is one with a disposable filter on it (stock OEM, K&N, etc. they all fit fine)-
    Here is a picture and comment that we received today from Brent.
    You can see he customized it a bit with his own plumbing.
    "Made a little change in the plumbing. It dropped the temp. about 15 degrees."
    i would assume that running boards won't fit with this set up?
    thx
    SALTY
    Proud Canadian Veteran
    Lethbridge Alberta
  14. #53
    Quote Originally Posted by Salty View Post
    thx
    If not,the soon to be announced universal kit might fit, Salty. I'm waiting for that one.
  15. #54
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    thx
    Depends on which running boards you're looking at, and/or if you're willing to do some modification...or, like Clint mentioned, we will have a universal oil filter relocation soon. It will mount off the front downtube.
    www.DKCustom.com
  16. #55
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    It's been close to a year since we introduced these. (wow, time flies faster and faster the older I get!)
    Thank you to everyone that has installed them. We truly appreciate your business and we hope you are thoroughly enjoying the benefits.
    For those looking to install an oil filter relo off the front downtube, they can be seen at this LINK.
    We now have a ton of Customers running both this style and the downtube style on their two-wheelers also....But it All Started with the Trikes!
    www.DKCustom.com
  17. DKCustoms postbit
  18. #56
    Mar 2015
    Warrenton, VA, USA
    Kevin, do you have the Combo Oil Filter Relocation & Dual-Cool Oil Cooler Package for a Dyna? I have an 08 FatBob that I put a Frankenstein Trike kit on that I would love to cool down.
  19. #57
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by rallsqh View Post
    We don't have a pre-packaged combo, but you can see the oil coolers at this link-
    http://www.dkcustomproducts.com/Dyna_c136.htm
    And the Oil Filter Relo's at this link-
    http://www.dkcustomproducts.com/CnC-...NC-OFR-UNI.htm
    Once you decide which oil cooler you want, then call or email the shop, let them know you are from Trike Talk, and they will make you a special package price for the two of them.
    www.DKCustom.com
  20. #58
    100+ Posts Cagmo's Avatar
    Jun 2016
    Glen Carbon, IL, USA
    Default oil filter relocation
    I installed the oil filter relocation kit on my '16 TG yesterday. Good, clean installation and it should be a big improvement for future oil changes. Easy to do laying on the floor, but a heated garage did make it that much better in Illinois in Jan.
  21. #59
    gerald martin
    Guest
    Default oil filter
    love this filter relocater. do you just replace the filter with the adapter and leave the oil cooler hooked up as stock
  22. #60
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by gerald martin View Post
    Yes, if you have a '13 or earlier that comes with a factory oil cooler, then you do just that.
    Remove filter from current location, and put the adapter in its' place. The install the oil filter relo and put the filter there.
    You do not touch anything with your factory oil cooler.
    www.DKCustom.com
  1. Replies: 32
    Last Post: 08-18-2023, 10:47 AM
  2. DK Custom Products - Oil Filter Relocation
    By geezerglide11441 in forum Harley Trike Conversions
    Last Post: 06-06-2016, 09:22 AM
  3. coil relocation
    By starrider1946 in forum VW Powered Trikes
    Last Post: 06-02-2015, 09:43 PM
  4. Tourpac Relocation
    By mervt198 in forum Outrigger Style Trikes
    Last Post: 01-25-2012, 06:52 PM
