SSpoon4SullyNew Member Introduct...Hello from VA
SSpoon4Jack KlarichNew Member Introduct...Hello from VA
SSpoon4GorillaNew Member Introduct...Hello from VA
SSpoon4SSpoonNew Member Introduct...Hello from VA
Likes Likes:  2
Results 1 to 13 of 13
Thread: Maintenance Help Please
    20+ Posts Hiram33's Avatar
    Oct 2014
    Southington CT
    Default Maintenance Help Please
    Hi
    I have a Champion kit for my Road King this is my first spring maintenance since we converted to a trike. I have the independent suspension belt drive. The owners manual is a little short on info.
    What do i need to do to service the differential every spring
    thanks
    Peter
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    It is pretty much maintenance free. The diff is sealed.
    INSPECT for leaks.
    INSPECT the belt for looseness, chips, cuts and holes.
    INSPECT the CV Joint boots for rips and leaks.
    INSPECT exhaust hangers and clamps are tightened properly.
    INSPECT lights are all working properly.
    INSPECT trunk is closing properly and seals.
    INSPECT..... INSPECT....... INSPECT......
    Ride safely.......
    Jim Murphy
    Iron Butt Rider 2001
    key word is INSPECT as stated. That should hold true for the whole bike/trike
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Nothing to service. just look it over.
    Like they beat into our heads in the Navy .. "You get what you INSPECT not what you EXPECT"
    Oct 2014
    Southington CT
    Default thanks
    Thank you all
    My confusion was that i have a Champion kit but the work was done at Lehman so the owners manual i have a from Lehman and that maintenance procedure was not fitting what i was seeing under the trike
    thanks again
    Martinsburg, WV
    If you have the Independent Suspension Harley-Davidson FLH-FLT kit, Lehman & Champion are all the same except for maybe the rear brake setup.
    Jim Murphy
    Oct 2014
    Southington CT
    Default Thanks but still a little confussed
    So here is what the manual says so this is what needs to be done?
    for the belt drive. The question i have is the plug seem to be on the bottom not the side. Again this is a 1995 conversion kit
    thanks
    Click image for larger version.
    Jan 2013
    You say that you have independent suspension with belt drive yet you circle information for a driveshaft differential??? I'm cornfussed.
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Suggestion:
    Go to www.champion.com and download the assembly instructions for your model.
    It will give you a very good idea of what you should check, give you bolt and fastener torque values. tell you how to check belt tension, axle alignment and other wonderful things and Explain maintenance techniques etc.
    Don't forget to look for leaks around your wheel seals and check for leaks or cracks around your shock mounts?
    Mine is a champion straight axle but if you were to go to my build site I documented my assembly and it will give you some good pointers.
    ( click on a picture in there and will give you some text to read as well.
    google-- pcombe library/photobucket
    I hope it helps?
    Belt adjustment
    Axle alignment
    Name:  d-8-usingadialcalipertoadjustalighnmentonaxleanddrivepulleys_zpsfd2f8067 (600 x 548) (2).jpg
    Name:  DSCF3230 (600 x 448).jpg
    Oct 2014
    Southington CT
    Quote Originally Posted by cavie View Post
    Sorry fro the confusion but that is way i received the manual the trike is a belt drive
    Martinsburg, WV
    Quote Originally Posted by Hiram33 View Post
    I have never had an occasion to have a Champion belt drive differential apart. I have never heard of one failing and I am sorry to say I don't know what the service policy interval is on it. But I will check right now.
    Spoke to Kenny at Lehman/Champion just now. Unless you see a leak in the assembly, there is no need for service. It uses a very heavy grease that is high-temp resistant. He also said there have been no recorded failures.
    I hope this helps.
    Jim Murphy
    Oct 2014
    Southington CT
    Default thanks
    I hope this helps.
    Thanks for the fast feed back and the checking up on the service policy
    Peter
  1. Routine Maintenance
    By pddgm in forum Harley Trike Conversions
    Last Post: 09-10-2015, 11:41 AM
  2. 10K maintenance
    By rayg5102 in forum Harley Trike Conversions
    Last Post: 10-11-2013, 03:38 PM
  3. Does anyone know the maintenance schedule?
    By Boscoporp in forum Honda Trikes
    Last Post: 11-22-2010, 01:33 PM
  4. Necessary maintenance
    By spiritdream in forum General Discussion
    Last Post: 06-02-2010, 11:59 AM
