Likes Likes:  11
Results 1 to 20 of 28
Thread: Honda F6B Hannigan Build With Pictures
    Cut N Shoot Customs
    Cut N Shoot Customs's Avatar
    Feb 2016
    Conroe
    Default Honda F6B Hannigan Build With Pictures
    Texas Trike Talk member Will (A/K/A Wylbur78) came to see us about having his 2015 Honda F6B converted to a trike. We recommended Hannigan's new F6B conversion and he agreed so the order was placed. A few weeks later, this showed up at our door.
    Visit Cut N Shoot Customs Website
    Visit Cut N Shoot Customs Trike Shop on Facebook
    New and Used Trike Sales - 16 Years In Business
    Trike Conversion Sales & Installation - Factory Trained & Certified
    California Sidecar - Roadsmith - Hannigan - Motor Trike - Frankenstein
    Conroe, Texas - Call (346) 800-7946
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Click image for larger version.
    First step is to start removing all the Tupperware. The seat, backrest, hard bags, center valance, rear subframe, fender liner, electronics pod, etc come off and go into a parts pile.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    The rear fender liner and the upper half of the subframe will be modified and remounted after the kit is aligned and bolted up and the auxiliary gas tank is installed. Next the rear wheel and tire and drive assembly is removed, but the swingarm and front half of the Honda drive shaft stays in place.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Next, the partially assembled kit is aligned with the bike and the tedious process begins of aligning and hooking up the drive shaft to the Hannigan drive line, installing the various mounting brackets and drilling the cast part of the frame to accept the mounting bolts. Hannigan uses more mounting points than most with a total of 14 separate mounting bolts just on the main frame. The F6B install is not for the novice installer, lots of mods involved, but it is an amazing conversion.
    Sorry for posting both as CUT-N-SHOOT and Bazooka, but I have more and better posting/editing tools available as administrator, so it goes a bit faster using the admin panel.
    ~Zook
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Next the auxiliary fuel tank and fuel pump is installed, plumbed to the stock tank and wired, the trailer hitch is bolted to the frame, the upper subframe lower half is sawed off just below the crossbar (above the gas tank) and re-installed, this removes the part of the subframe that had supported the hard bags. After that the factory radio/amp is relocated to a bracket supplied by Hannigan and is located just above the gas tank. It almost looks like it is sitting on the gas tank itself but it is not, its mounted to a bracket and suspended just above it and has a foam isolator pad below it.
    You will notice that Hannigan offsets the differential to the right side in order to align it with Honda's swingarm/driveshaft. The single factory swingarm shock is housed within a round vertical cavity deep within the belly of the Goldwing and with the Hannigan kit, the shock is removed and replaced with a proprietary square tube strut so as to lock the swingarm in a fixed position so it can mate to the Hannigan rear drive assembly. The suspension duties are now handled by way of Hannigan's independent trailing arms and shocks.
    nice boss very nice
    That's gonna make a mean looking trike ... is that satin black?
    70+ Posts Raxus's Avatar
    Aug 2013
    Creston, Ia
    Wow looking great! Keep the pics coming
    Rax
    [IMG]http://i192.photobucket.com/albums/z...rsz_1021_1.jpg[/IMG]
    US ARMY Vet '85-'90 19D Cav Scout
    2014 FLHTCUTG tGlide Lift, Cupholder him/her, Passenger comfort pegs
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Great thread Chief ! Keep it coming.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    So we pulled the front end off and installed one of my 6 degree rake kits and now its all together and test ridden so we could deliver it to the local Honda dealer, Cycle Shack North in Conroe for the brake recall. These guys are great and they are only a couple of blocks from my shop so its very handy.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    So now for the final assembly. Will wanted an air filter change, oil change and coolant fluid flush so we took care of that for him. We aligned the rear wheels, installed the aux fuel tank line, fuse and switch, the trunk release cables and latches are installed, the wiring harness is built from scratch, hooked up and tested for run, brake and turn signals working, the side panels are cut, aligned and installed, the exhaust shield brackets are installed, the exhaust pipes are re-aligned, the seat and backrest are reinstalled.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    nice boss very nice
    Quote Originally Posted by Raxus View Post
    Rax
    Quote Originally Posted by Lucky View Post
    Thanks guys.
    Fuzzy, Honda calls the color Matte Silver, but it is far from silver, more like a satin dark grey. It was a hard color to match, and not just the color match as much as the amount of shine or should I say lack of shine. It has a slight sheen to it and that part was difficult to duplicate according to Hannigan and their paint suppliers. It turned out to be an exact match though, so kudos to Tim at Hannigan for the amazing paint job.
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    SWEET! (and I'm not even a GW fan!)
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    So here is the finished product. I think she's a beauty and so do her owners.
    She is quick, smooth as silk and handles like a Corvette and with the auxiliary
    fuel tank she will go the distance without lots of fuel stops.
    250+ Posts Dirtydan's Avatar
    Jul 2015
    San Tan Valley, AZ
    That is one sweet looking trike.
    might make a die hard harley rider switch
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    That turned out really nice, a beautiful machine.
  19. #19
    There's only one word to describe it ... "Nasty" ... and that's a good thing.
  20. #20
    Oct 2015
    Friendswood
    Default Thanks Zook for all your hard work!!
    Quote Originally Posted by Bazooka View Post
Name:	F6B right front.jpg
    She turned out really nice huh?
    I appreciate all the wonderful reply's and comments on my Trike. I'm loving riding her and Zook is right she handles like she's on rails!!! I've definitely had to get used to taking the corners like you do instead of leaning into them, well I'm still leaning into them but that's just to make sure I keep my speed up!!
  1. Honda Valkyrie Roadsmith Build With Pictures
    By Cut N Shoot Customs in forum Cut N Shoot Customs
    Last Post: 02-04-2024, 07:55 AM
  2. If Honda was to build a trike
    By SEABILL in forum Honda Trikes
    Last Post: 05-10-2014, 10:21 AM
  3. 06 Twin Cam 120" Build (Lots of Pictures)
    By msocko3 in forum Harley Trike Conversions
    Last Post: 05-26-2013, 06:09 AM
  4. Pictures of my Honda VXT 1300 with the trike kit
    By wa.bound in forum General Discussion
    Last Post: 05-24-2011, 08:08 AM
  5. Prototype build pictures
    By Popeye2347 in forum VW Powered Trikes
    Last Post: 04-01-2011, 06:30 PM
Tags for this Thread
