Results 1 to 8 of 8
Thread: Road Star Trike Front Tire
    200+ Posts dbruce56's Avatar
    Nov 2014
    Salem, Al
    Default Road Star Trike Front Tire
    Not quite there yet but, probably by the end of this riding season I will be needing a new front tire. Was wondering which tire the Road Star trikers are using. Right now have a Dunlop on it of unknown mileage.
    On another note. Which seat are you using? Thinking seriously of replacing the stock seat.
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    Quote Originally Posted by dbruce56 View Post
    I have 15k on a bridgestone battleax rear tire mounted in reverse on the front. Shows no wear from the rough texas roads. A friend got only 8k from the harley tire on his triglide on the same roads.
    80+ Posts Roadie's Avatar
    Oct 2013
    Fredericksburg, VA
    I run the same front tire I ran as a two wheeler (Commander II) great tire and handles in any kind of situation.
    800+ Posts Big Juice's Avatar
    Nov 2013
    Hot Springs Village, Arkansas USA
    I have a CSC triked StratoLiner and I am preparing to replace my front tire again (20K miles on the conversion). Only got 9K out of my first Bridgestone BattleAx, now on my second one and only have 8K on this one. Both tires had plenty of tread depth left, but they were cupping very bad and the tread was taring between tread bands and didn't want to chance a blowout on the highway! Seams I am having the luck of the TriGlide rider mentioned above with a BattleAx. Bottom line, I am not putting another BattleAx on this time, going to try the new Avon Trike front tire, IF I can find one here locally. Good luck on your choice, hopefully others will post up with their experience (I have heard that the Mich. Pilot is good and the Metz 888 is good). As you may know, most everyone runs a rear tire (sized correctly for the front), mounted on the front in a reverse direction and tire pressure at 40/41. I have seen the explanation of the reverse reasoning, but not sure I believe it makes a difference (although I did as everyone else does and mounted it in reverse direction). Good luck and safe riding!
    ​O J Miles - now riding "Lucille", a 2017 Spyder F3-Ltd. Roadster.
    When 2 wheels aren't enough and 4 are too many.
    Ahhhh, a hot cup of coffee and a good cigar, after a good ride.......
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    +1 on the Avon front trike tire!!!
    Dec 2013
    Jenison, MI
    Quote Originally Posted by Big Juice View Post
    Texas back roads are tuff on tires, more stone than tar. Half of my miles are on Michigan potholes. As a 2 wheeler, I got 10K on Pirellis.
    Cupping is usually caused by bearings, suspension or imbalance. I'm using RideOn to balance my tires. No cupping!
    Nov 2014
    Salem, Al
    Well, to update this thread,,,After a bit of thought and review reading, I decided to go with the Avon AV71 trike tire. Right now the tire is awaiting tomorrow when I swap out the old, worn out Dunlop for the Avon.
    90+ Posts sprt220's Avatar
    May 2008
    Madera,Ca
    Default tire
    I have a Metzler front tire. My first 2 were the Dunlop that came with the bike.I find that not so much milage on the tire as much as when it starts cupping due to us only riding on the middle of the tire. I also have a Corbin Dual tour seat.
  1. Triking a Road Star
    Last Post: 03-21-2022, 06:45 PM
  2. Just picked up my Road Star Champion trike
    By badbutch in forum Yamaha Trikes
    Last Post: 06-08-2015, 11:11 PM
  3. tire size for rear tire on front? 2007 goldwing trike
  4. V Star 1100 trike rear tire size ???
    By Pre-1898 in forum Yamaha Trikes
    Last Post: 01-13-2015, 08:05 PM
  5. Belt Adjustment on Road Star Trike
    Last Post: 02-22-2014, 08:10 AM
