Speed Bleeders
Likes Likes:  3
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Tri Glide Brake Light add-on
  1. #21
    50+ Posts
    Jan 2015
    Millersburg, Pa
    Deleted
  2. #22
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Livin2Ride View Post
    I think that if you want a safe and reliable feed for your extra lights you need to add a powered trailer lighting module and keep the additional light off any of the CanBus circuits and limit your chances of blowing something in the BCM. I'm running a trailer module from Electrical connections and haven't had any issues with anything on the bike. You can tape off the unneeded wires and just use the ground and brake feed if that is all you want.
    I had not thought of that! But that would definitely work!
    Quote Originally Posted by triglide15 View Post
    I added led lighting to the rear of my 2015 tri glide be tying into the tail lights. I did this about 600 miles ago and have had zero problems. I just went out and pulled the tour pak liner back and unplugged the light. Looking into the plug with the plug lock on the right side. The top two are the turn signals the lower left is the running light the lower right is the BRAKE ONLY. So splice into that wire to add a brake only light. Best to solder wiring Attachment 34844
    But it looks like HD does give access to the brake signal on it's own dedicated wire...after looking at my TP lights yesterday, it seemed that they had to have done this, and here it is.
    www.DKCustom.com
  3. #23
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    I love you guys!!
    Pic's by the end of the weekend! jc
  4. #24
    50+ Posts
    Jan 2015
    Millersburg, Pa
    jc 1300, I must of had a brain fart earlier and didn't think of this. Much better location to tie into. Between your seat and tour pack there is wiring attached to brackets. Pull off your seat and locate the wiring coming out of tour pack trace it to the correct plug unplug it see attached photo for the position of the BRAKE ONLY pin (needle stuck in pin) I would tie into it at this location.
    Name:  20160401_153059 (800x450).jpg
  5. #25
    Apr 2015
    LOL - Better yet - Thank you - jc
  6. DKCustoms postbit
  7. #26
    Apr 2015
    So ya think I'm a bit behind on my reply? Good Lord....TRIGLIDE! Everything you proposed worked out perfect. An easy splice and routed the wires thru the trunk. So as planned, the light is just a brake light and you can barely see it when not in use. Just a little something more going on back there when I'm stopping - Thanks again Triglide - jc
    https://www.facebook.com/john.compto...73984427063588
  8. #27
    400+ Posts
    Feb 2008
    RADCLIFF, KY
    I'm putting a set of Hyperlites on my TG and I called them about a brake only wire, they told me the light blue with red stripe was the brake wire and black of course ground.
    2017 Tri Glide, Bonnieville Blue / Fathom Blue
    2005 Bushtec Roadstar Trailer
    BLUE KNIGHTS, KY II
    AMA, HOG, Iron Butt Member
  9. #28
    Apr 2015
    Quote Originally Posted by Casper View Post
    Dat be da one!! Triglide was just nice enough to show it for the color blind...jc
  10. #29
    1+ Posts
    Oct 2021
    Lenoir NC 28645
    Default 3 wire light bar
    Quote Originally Posted by jc1300 View Post
    hey brother on the the three wire light bar I wanted it all to work the running light brake and turn to work does this plug have all of them there so i can hook my light bar there? I trace down under my seat the turn and brake light but not the running light but it looked mighty light not as bright as my other lights are, mine is a 2010 triglid in which me and wife just pure love if I had of known I have this much enjoyment on a triglids I had one 20 years ago I guess the reason why is my wife now will ride with me and that alone is the reason I really love it but she don't feel safe without brighter lights and as you know yourself you can never have to much on rear to keep others from running over you so if you could help me also I really need your help if possible I don't want to step on the other guy toes because he asked for help first so help him first then if you have any time to help me then that would be great if not I fully understand if you could help me too I am a disable vet so I can used all the help I can get thanks ride safe
  11. #30
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by herringdan View Post
    Hey......Dan...Welcome to Trike-Talk........--.....
    2019 Tri-Glide.......
  12. #31
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Welcome Dan, I have a 2013 and I spliced into the harness that feeds the tail lights on the TRI. The 2010 was a HD send to Lehman Trike for conversion then back to HD for sale. I am not sure where the harness on the 2010 runs but it has got to be there somewhere and that's where to splice in for your light bar. You may have to purchase some type of converter if your light bar does not have turn signals built in, to tell the light bar to light for Brake and not turn. Custom Dynamics sells those type of things. Good Luck
  1. Replacing brake light?
    By bohomus in forum Honda Trikes
    Last Post: 04-26-2020, 12:54 PM
  2. Freewheeler Third Brake Light
    By Springman2007 in forum Harley Freewheeler / Road Glide 3
    Last Post: 11-25-2014, 06:13 AM
  3. Brake Light/Blinker
    By Clell12 in forum Stallion Trikes
    Last Post: 07-28-2014, 05:06 PM
  4. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
  5. Brake Light Problem
    By Greydog in forum Harley Trike Conversions
    Last Post: 11-01-2011, 09:59 AM
