Likes Likes:  4
Results 1 to 20 of 23
Thread: Install/Remove a Battery
    400+ Posts mgwtrike's Avatar
    Nov 2014
    Loving the Southern Life in Central Florida
    Default Install/Remove a Battery
    Anyone ever attempt to remove or install their battery in a Roadsmith Trike?................
    I left my ignition on and thought my battery was died so I tempted removed it and OH MY, what a pain.
    Any suggestions would help.
    Goldwing:
    A real butt kicking, wheel popping, tire burning old man's bike.
    MIKE W.
  2. Roadsmith banner
  3. #2
    20+ Posts
    Jun 2015
    Nova Scotia Canada
    Quote Originally Posted by mgwtrike View Post
    The way I fixed mine (same problem) I moved the battery to the trunk and installed new cables from the battery to the old battery cables.
    Bob
  4. #3
    100+ Posts
    Aug 2011
    Cumberland Md USA
    I just changed mine and for awhile it really gave me fits. I finally put a little piece of
    tape at each end of the little slot to hold the nut in place. Worked like a charm. If you
    are installing a Yusa it probably has brass nuts & bolts. These strip very easy so be careful and start with your fingers if possible.
  5. #4
    Nov 2014
    Quote Originally Posted by gwnut View Post
    If you
    Yes it is a Yusa and to get my fingers in far enough to start the bolts was the trouble.
    After hours of trying, I finally pulled the whole battery out stretch the positive cable,
    and got it threaded, then carefully wedged the battery back in place to attach the Neg. post.
    Goldwing:
    MIKE W.
  6. #5
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Don't know what kit you have, but my Roadsmith Kit duz not change the access to the Gold Wing battery at all.
    Nov 2014
    Quote Originally Posted by Lucky View Post
    Which model kit do you have?
    Goldwing:
    MIKE W.
    Dec 2009
    LaFayette
    2013
    Nov 2014
    2013
    No, which model Roadsmith
    Goldwing:
    MIKE W.
  10. Roadsmith banner
  11. #9
    Sep 2016
    Springfield, Mass. USA
    You know after reading this post, (yes I know it's an old post) I went out and looked at my trike... Yes it's going to be a total "bear" to remove that battery, and replace it..WHY did they make it so it so hard, to service that battery??? There's a hard plastic lip that's in the way, that make it impossible to just slide out the battery to remove or change or even worse, if yea have to use jumper cables to jump start your bike in case of an emergency...
    Just asking here: If anybody found an easier way to service or remove a Yasa battery??? From a Goldwing with a Roadsmith conversion???????????
  12. #10
    Hey, Ronnie removing the battery from Tri-Glide ain't much easier ....-
  13. #11
    Nov 2014
    There is no easy way to remove/install the battery in a Roadsmith trike conversion.
    That said, for jumping a died battery, my '12 Goldwing came with a "charging harness" that will work to jump the battery.
    Just make sure you have the correct connection.
    Goldwing:
    MIKE W.
  14. #12
    Moonshine Mike
    Oct 2015
    st. albans
    I just replaced the battery in my rs/hts , I removed the left rear wheel, made it easy to disconnect positive cable. Then took a thin flat bar at the negative end and it came right out.
  15. #13
    Sep 2016
    Quote Originally Posted by mwebster View Post
    Are you saying that you actually had to remove the rear wheel to remove a battery??? [Uggggggggg ] I'm actually thinking about taking a drummel tool and shaving down that plastic lip that's in the way.. (it really serves no purpose) and it's covered up so it's not seen.........I'm just "thinking out loud here" but what happens if your out on the road and your battery goes dead, what a pain that would be to also have to remove a rear wheel as well.. *not trying to argue that fact*, but again, if on road,and broken down with a no start problem , you'd have to also have a jack to lift bike up off the road, and tire iron with correct sized lug nut socket set...THERE HAS BE AN EASIER WAY!!!!!!!
    [ACTULLY THE WORSE CASE would be, what if your riding with a Harley buddy , and his bike is running fine, and your Honda broke down lol Embarrassment!!!
  16. Roadsmith banner
  17. #14
    From what i understand that 98 percent of all the Goldwings that were built in the last 15 years and that also includes even the ones that once were built right here in America are still on the road today ,
    The other 2 percent made it home....
  18. #15
    Nov 2014
    I'm guessing roadside assistance would be the answer here.
    Haul it to your friendly Honda dealer, invest in a new battery and let them worry about the installation.
    Goldwing:
    MIKE W.
  19. #16
    Sep 2016
    Good *come-back* LOL
  20. #17
    Sep 2016
    You know, I like your idea! Hmmmmmmmmmmmmmmmmm! I guess my battery is now approx. 5-6 years old (it's getting too be time!) thank you!
  21. #18
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    2 yrs peace of mind, then into the lawn mower. $100 wont brake me ☎️
  22. #19
    200+ Posts lgjhn's Avatar
    Jun 2013
    SW Louisiana
    Resurrecting this thread because I had to replace my battery this week and ran into this very issue.
    Sure enough, there is a lip in the way of removing the battery making it practically impossible to remove.
    I solved this by sliding the battery out as far as it would go till it hit the lip. I then marked the area where it was hitting.
    I pushed the battery back in, took a small file and filed away just the minimum amount of material in the marked area enough to allow the battery to easily be removed/installed just like it was prior to the conversion.
    Mine is a 2013 Roadsmith on an '06 Wing.
  23. #20
    Sep 2016
    Quote Originally Posted by lgjhn View Post
    Yep! That is exactly what I did... (Good/smart move) This will help you in the future "big time"
    2010 Goldwing on a 2104 Roadsmith
  1. Battery life and battery purchase
    By pcombe in forum Harley Trike Conversions
    Last Post: 02-21-2019, 05:53 PM
  2. Cam Install
    By Trapper54 in forum Harley Trike Conversions
    Last Post: 07-03-2016, 06:42 PM
  3. What is the BEST battery for ...
    By TwoBye in forum Honda Trikes
    Last Post: 10-22-2014, 05:53 PM
  4. Help LED Install
    By sprinkman in forum Harley Trike Conversions
    Last Post: 05-02-2013, 08:12 PM
  5. Gel Battery
    By docb in forum General Discussion
    Last Post: 03-17-2008, 02:44 PM
