Likes Likes:  5
Results 1 to 10 of 10
Thread: Carb ID
    5+ Posts reverand2000's Avatar
    Mar 2016
    Cumming, Ga, USA
    Default Carb ID
    Can anyone help me identify this carb? There is no name or numbers that i can find.
    Thanks for any help.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Welcome to the site.
    Is the air filter hiding anything, like a stamping or casting perhaps?
    Not likely a Solex, also doesn't look like a weber. Maybe a chinese empi
    Sorry not a help but someone reading your inquiry will likely recognize it...
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Looks like karons to me.
    Never owned a set, just going from old memories.
    *kadron*
    Sorry fat fingers and little phone buttons.
    welcome aboard sorry no help on the ID
    Feb 2008
    Anderson, Missouri
    Here is a picture of a Kadron - different views, but here it is for you to compare. More pics and different models of Kaddies, search "Kadron carbs"
    Mar 2016
    Cumming, Ga, USA
    Default Thanks
    Thanks for looking guys. I'm new here and to trikes.
    The defining of this card is there is only three screws that hold the top on.
    I leaning more towards a
    Solex for a Jeep.
    I will try to get more pictures w/different views.
    Thanks again for any help.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    At first, I was leaning towards Kadron as has been mentioned, however, after you stated that it only had 3 screws holding the top down, I don't think it would be a Kadron.
    If nothing else, jump on The Samba and get on their forum and someone there will for sure be able to identify the carb.
    http://www.thesamba.com/vw/forum/
    Unless there is a stamped number around the base of your carb? If so we can probably figure it out.
    Welcome to the gang ... the VW guys were are tops ... lots of great info.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Default Few small pics of Kadrons...
    Mar 2016
    Cumming, Ga, USA
    Default Carb ID - solved
    Thanks everyone for looking and commenting. It turns out this is a carb in the Scat Dual Carb kit.
    It is a Solex P-40. The Scat part number for the kit is 30440.
    Thanks again everyone.
  1. Carb Q&A
    By Doug D. in forum VW Powered Trikes
    Last Post: 02-15-2016, 12:41 PM
  2. p 34 carb?
    By skeeter in forum VW Powered Trikes
    Last Post: 06-29-2012, 10:51 AM
  3. Help with new carb.
    By vwjoe in forum VW Powered Trikes
    Last Post: 03-30-2011, 04:30 AM
  4. Carb cleaning
    By John Luciano in forum General Discussion
    Last Post: 03-17-2011, 08:28 PM
