Results 1 to 7 of 7
Thread: Leaking Motor Trike trunk
    Jul 2015
    Harrisonburg, Va.
    Default Leaking Motor Trike trunk
    Trunk on my 1990 GL1500 with Motor Trike Conversion leaks.
    Any one else have this problem and how did you fix it?
    ALitten
    Just going to say welcome aboard I hope someone has help for you
    600+ Posts keepinon's Avatar
    Dec 2011
    New Caney, Tx
    If you have the Coupe kit, the handles on the trunk door are able to be adjusted, to increase the "pull" into the seal. At least it was on my Valkyrie with the Coupe kit, no top box...
    Mar 2011
    mountain home,ar. USA
    Leaks in these trike trunks can be a bear to stop. Here's what I've done so far:
    1. Clean and re-applied RTV wherever there are wall penetrations such as electrical wires, screws, etc.
    2. Check that door gasket fits properly by putting baby powder on gasket and opening and closing door a few times. If gasket not sealing you might try adjusting to make fit if possible. If gasket is damaged, dried out then replace.
    After all that I still line my trunk with plastic when on road trip. Riding in rain all day seems to penetrate no matter what I do; not much, but enough.
    Good luck.
    Jul 2015
    Harrisonburg, Va.
    Default Thanks
    Quote Originally Posted by ALitten View Post
    ALitten
    Thank you very much, Have had some suggestion to try. Must be a problem with all models.
    Any one else have a 1990 GL1500? Any problems I should be looking for?
    150+ Posts eastkytriker's Avatar
    Jun 2013
    Grayson, Ky.
    ALitten
    I have a 1990 1500 with motortrike and have never had a leak (knock on wood) so there must be a fix for your prob. Just finding it is the thing. Maybe im one of the lucky ones.
    30+ Posts
    Jan 2012
    Eugene, or
    Default Fix
    I had a leak in my MT trunk for GL1800 and was successful in fixing it by finding a trunk seal gasket that was slightlythicker than the stock unit. I walked through a wrecked car yard and looked at several trunk strips of various car brands. I found a couple that were about 1/16 of an inch thicker than stock. I bought several (they were cheap) and went back and tried them out. The one I used was from a Honda Civic and no leaks since.
  1. Rear trunk leaking
    By djaecks in forum Honda Trikes
    Last Post: 11-04-2015, 11:07 AM
  2. Motor Trike Lower Trunk Problem
    By BIGOKIE1 in forum Motor Trike
    Last Post: 12-21-2012, 11:52 AM
  3. Motor Trike Trunk Release Cable
    By paws in forum Motor Trike
    Last Post: 07-21-2012, 09:13 PM
  4. leaking lehman lower trunk
    By docweb in forum Honda Trikes
    Last Post: 06-29-2010, 09:10 AM
  5. Motor Trike Trunk Light Plug???
    By spencerltr in forum Motor Trike
    Last Post: 06-26-2009, 02:29 PM
