Likes Likes:  5
Thanks Thanks:  1
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 55 of 55
Thread: How to change differential oil?
  1. #41
    Sep 2012
    Lakeland, FL
    That Mike, will be my procedure next change, thanks. How often do you change yours?
  2. #42
    Sep 2012
    Lakeland, FL
    Gentlemen, this is what I found in my year 2014 file from Road Smith.....
    Hi Bill,
    Since your kit was produced in 2012 that would make your differential a Ford based product. There is a ¾” plug in the rear of the differential that isn’t exactly easy to get to but it is there. As long as there are no major leaks there really isn’t a need to check it however. It is filled with one full quart from the factory. The fluid level from the plug hole should be about one inch below the hole. The differential manufacturer recommends changing the fluid every 50K miles but that’s for normal automotive applications. Since this is on a trike with much less working stress than a car, you could easily go more than that without hurting anything. There is also a heavy magnet inside the diff that would catch any metal shavings before they’d get into the gears.
    Hopefully this helps but as always feel free to let me know if you have any other questions.
    Thanks!
    -Taylor
    Taylor Young
    Roadsmith Trike Conversions
    www.roadsmithtrikes.com
    800-331-0705
    3744 Scheuneman Rd
    White Bear Lake, MN 55110
    Ride With the Expert
  3. #43
    Mar 2011
    mountain home,ar. USA
    Hi Bill,
    Thanks!
    -Taylor
    Taylor Young
    800-331-0705
    3744 Scheuneman Rd
    I changed mine at 50K and will probably do it again at 70K simply because I get bored during the winter.
  4. #44
    200+ Posts lgjhn's Avatar
    Jun 2013
    SW Louisiana
    Arrow
    Quote Originally Posted by mhgoldwing View Post
    I drove the trike about ten miles to warm up diff, removed the fill and drain plug and went to have lunch. When I came back I put a hand pump into the quart bottle of rear end oil and pumped it into the diff. Couldn't quite get all of it out of the bottle and up the pump's hose so a little less than a quart. Worked like a champ and no chance of over filling.
    If you have diff that requires less, simply remove excess from bottle before pumping and get on with it. Again, no chance of overfilling.
    One like this: https://www.google.com/search?q=quar...37675711063167
    Mike,
    I've found that the pump I purchased from Wal-Mart will only pump out about 24 oz out of new 32 oz bottle which is pretty much right on the money for my diff.
    I know the RS written spec is a full quart (32oz), but I'm sticking with Dan's suggestion in that earlier post of only 24 oz. As mentioned above, our diffs are verrrry lightly loaded compared to their original automotive design service.
    FWIW, having done a bunch of ring/pinion changes on Chrysler diffs over the years (I'm an old drag racer), I'd usually fill em about 3/4 of the factory recommended fill for on-road highway service to get a tad less friction from oil windage, but still enough to keep the diff fully lubed. IF you've ever had the cover off and look at approximately where the oil level would be in relationship to the ring/pinion/seal assembly (usually you can see a stain line), the ring/pinion assembly is still getting plenty of lube, especially with the synthetics we have available to us today, but it takes the oil load, especially when hot, off the pinion seal a little bit. I agree that Dan knows his stuff on these, and I'm pretty confident and comfortable with the 3/4 fill for our lightly-loaded trike diffs.
    Hey, IF mine burns up/lets go, I'll just pull the whole darn thing out and rebuild it, but I highly doubt that will be necessary.
  5. Roadsmith banner
  6. #45
    Jun 2013
    SW Louisiana
    I'm surprised NO ONE HAS EVEN MENTIONED the two grease jerk fittings just before the universal area.....
    I just grease those yesterday, along with oil / filter, and spark plugs changed when putting bike away for the winter season.....
    Hi Ronnie,
    I believe I saw somewhere on this forum where RS says those only need a small shot about once/year. I think those are for greasing the splines in the drive shaft.
  7. #46
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by lgjhn View Post
    Hi Ronnie,
    I shoot a few shots of gears in once a season, It gives me a better feeling to know that IT HAS BEEN DONE!
  8. #47
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Hello everyone,
    Bringing this thread up again. Thanks for all this info as it helped me changed the differential fluid last night. First, car ramps is a must then I lifted the front of the bike with floor jack and placed the front wheel on a stack of wood to level it. Found the drain and fill plugs as stated in this thread. According to the R/S information I have the Ford unit per the method of counting the cover bolts. This trike has 51,000 miles showing, I have no idea when this was converted. By the way this is on a 2008 GL1800 we just purchased. I measured the old fluid that drained completely out (28 ounces). I also used the hand pump that screws on to the bottle using the longest suction tube that came with this pump left 5 ounces of new fluid in the bottle, so 27oz went back in the differential. There is no sign of a leak, so the factory did not fill this unit with a full quart? Dan may be correct and the factory may be using less? FYI, a 1" deep well socket was perfect to remove that fill plug.
    Thanks again for all this great info on this forum.
  9. #48
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    A confirmation here on my last post. I call R/S yesterday and spoke to Mike to find out what year my R/S was made. They use two numbers in the serial number to know the year built. Mine is a 2014. The tag is located on the right-side of trailer hitch channel. I was told by Mike and our local R/S installer that these Ford rear ends need that 32oz of gear lube. Last night I added the rest of the bottle.
  10. #49
    Sep 2016
    Thank you "everybody" I'm going to crawl under my bike once this dang weather warms up a bit, and see what I can find, and go ahead, and try that rear end fluid change....Can't see why I can't do it..... I usually find that everytime I'm abit worried about doing a job, I usually find that is wasn't that big of a DEAL, AND I WORRIED FOR NOTHING.. last week I replaced the Radiator fluid in the wing, I worried that I'd not be able to accomplish this job, well it was a piece of cake and I saved myself alot of money, and had hand prints on the back of my shirt, because I gave myself a pat on the back.... LOL
  11. #50
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    I ran the rear wheels up on ramps and then jacked up the front placing wood under the front tire making the bike level. I suggest buying that hand pump the auto parts store sell for changing transfer case fluid. This will screw on to the quart bottle. The longest suction dip tube that comes in the kit will not empty the bottle. I used another container to dump that amount into or you can cut the bottle and still use the hand pump. Per R/S I added the almost the full quart.
    You can do this task. FYI, I used a 20% off coupon at Harbor Freight to purchase their plastic type ramps. Well worth it and I can use them to change oil on my truck verses using a floor jack. I have no problem buying tools: new job-new tool is my moto.
  12. Roadsmith banner
  13. #51
    Apr 2019
    Jamestown,NY,USA
    Default Need more info
    I am new to Roadsmith trikes and goldwings and this forum. I have a question about my differential. I just bought a 2007 GL1800 with 2007 HT1800 conversion. The trike has 49,995 miles on it and it was triked when brand new. The differential is a 9 bolt. All 9 bolts go thru the plate and hold on the cover. There is no access hole thru the plate and no plug in the differential cover . I have not seen any pics of this kind of differential. The manual that came with the bike only shows the plate with the access hole I wire brushed the bottom and found the drain plug. The only place I can find access to refill is by removing the breather valve on the top of the differential. Before I start unscrewing things I am hoping that somebody that knows what they are doing can give me some guidance. I am planning a trip from NY to Arizona in the next month and the info on this forum says that this should be done. Thanks for the help.
  14. #52
    Did you look on the differential side. I'm fairly sure the drain and fill are not in the cover. Never seen that on any differential.
  15. #53
    Apr 2019
    Jamestown,NY,USA
    Thanks for the reply. I went back out, put it up on jack stands and pulled the tires off and took another look. It was on the right side, directly facing the tire.
  16. #54
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Quote Originally Posted by Nels View Post
    Hello Nels, Welcome to the group. I just purchased an 08 GL1800 with 51,000 miles. I am going thru flushing all the fluids to discover that in 2014 when this scooter was triked with the R/S HTS they did not have the rear brake system connected with the front brakes like the OEM bike had. They now sell a kit with all the fittings to reconnect them. The kit is $27. I had my local R/S dealer order me a kit. The front brake pads on mine was worn unevenly due to what I assume is not having all the caliper pistons applying even pressure. Just replacing the pads and flushing the fluid made a big difference in stopping power. At 51,000 miles my clutch and front brake master cylinder reservoirs had a bunch of crap starting to collect at the bottoms.
    Safe travels and enjoy your new toy.
  17. #55
    Sep 2016
    Thanks for all your help, It's now 18* degrees in my garage, BUT once it warms up, I'm going under the TRIKE, to look for those drain and fill bolts...
    I ride a 2010 Goldwing with a Roadsmith trike kit.........
    I like repair'n and service'n my bike myself, the dealership will rape the hell out of my wallet.............
    I put my TRIKE up on 4x4 boards one under each tire, so it's lever and four inches off the floor, give'n just enough room to work under it..
    WARNING:::::: Be sure to WIRE TIE your FRONT BRAKE LEVER to keep the bike from rolling off the boards, (w/you underneath it)
    2/20/24
  1. zerk on differential?
    By bikerbill in forum Harley Trike Conversions
    Last Post: 04-14-2024, 06:19 PM
  2. Champion Differential
    By tingrin in forum Champion Trike
    Last Post: 05-15-2020, 12:29 PM
  3. Did my intial Differential Fluid change
    By schiel1 in forum Honda Trikes
    Last Post: 10-18-2015, 04:31 AM
  4. Differential gear oil change
    By the paparazzi in forum Yamaha Trikes
    Last Post: 04-07-2015, 10:38 AM
  5. Differential oil
    By katonka in forum Honda Trikes
    Last Post: 08-06-2014, 08:46 AM
