Likes Likes:  3
Results 1 to 18 of 18
Thread: Disc brake conversion.
    150+ Posts CaveManDave's Avatar
    Apr 2016
    Spokane, WA USA
    Lightbulb Disc brake conversion.
    Good, better, best? Not the EMPI kit, so many bad reviews.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Ok then....
    You can spend as much as you want on disc brakes. Some really great dune buggy units out there, wildwood, Jamar ect.
    As light as we are just upgraded drums are fine.
    I do like my disc though. I have ac industries kit on mine. Which is just one of the generic plain jane disc kits.
    I think all the generic brake kits are the same, probably made by the same Chinese folks. Empi is most likely the same as as other generic kit.
    http://www.socalautoparts.com/produc...readed-p-13549
    Meme Master
    Jan 2014
    Farmington, NH USA
    Caveman, Looks good since I saw it last!
    There are several online sources for the rear disc kit.
    They are typically supplied with or without park brake.
    Here are a few in no particular order or preference:
    appletreeauto.com
    cip1.com
    carcraftstore.com
    jbugs.com
    Good luck & keep the shiny side up!
    Apr 2016
    Spokane, WA USA
    Seems like mostly Empi kits for 5x4.75 Chevy pattern. Is there a logical step up in quality?
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Apr 2016
    Spokane, WA USA
    very nice... But no 5x4.75 Thx Death!
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    This is actually the kit that I installed on my trike:
    http://carcraftstore.com/reardiscbra...ute-brake.aspx
    However, after installing the kit I also installed this Wilwood residual valve:
    http://www.amazon.com/Wilwood-260-18...=sr_1_1&sr=8-1
    The system works fantastic!!!
    When ordering though, insure you are getting the correct kit for your IRS transaxle.
    Apr 2016
    Spokane, WA USA
    Thanks Stinger!
    That looks like a great kit and it looks complete. Where did you insert the Willwood presure valve?
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by CaveManDave View Post
    Thanks Stinger!
    I installed the residual valve along the single line between the master cylinder and where it "T"s off to the both rear wheels. However, if you do find you need a residual valve and do the disc conversion, DO NOT get a 10 pound valve. Just get a 2 pound. The 10 pound will be way to much pressure against the rear brakes and they will drag.
    What a residual valve does is keep a certain amount of pressure between the valve and the rear brakes and 10 pounds is way too much for disc brakes.
    Apr 2016
    Spokane, WA USA
    TY again for your advice! I am going to order this weekend.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Same varga style 2 pin calipers and same rotors as all the rest of the generic kits.
    The only difference that I know of in any of the generic kits is the caliper mounts. I was warned about the stamped bracket, so I got the forged bracket.
    As long as the stamped bracket is dimensionally correct (alignment) it should be fine on our light weight app.
    Check the thickness of the brackets to the removed back plate. Shim or machine as necessary.
    Check the caliper alignment for twist. Not sure how to correct this with stamped.
    Check the caliper alignment for centered. Shim or machine the spacer rings on the axle.
    There are numerous different depth of axle end castings and bearing caps. The generic kit is only made in one of the possibilities out there. Make sure it assembles right. Sometimes it is a straight bolt on, sometimes not.
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    can someone explain the benefits of having disk brakes on a trike?
    I was going to switch over but just could not justify it.
    I still have drum brakes but I am using a larger wheel cyl.
    I would think the benefits would be more noticeable on something heaver like a car.
    I have drums and when I hit my brakes hard they lock up my wheels fine. How would disk brakes improve that?
    Hey guys not trying to put anyone down or discourage anyone from doing this I just want to understand why.
    Thank you
    Bob
    Apr 2016
    Spokane, WA USA
    I have weighed the cost also. I think for now I am going to wait off. I have enough upgrade projects to finish. Maybe I will see how I feel after a season of riding.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Exactly what I said to start with.
    A good drums brake is enough at our weight.
    Correctly size the hydraulics for a rear single circuit only.
    The only real advantage is fade.
    Drums can only soak up so much energy before overheating.
    Disc can scrub off more energy.
    Say.... 100mph panic stop.
    Drums are gonna be fading and taking more and more peddle pressure.
    Disc won't.
    Another possibility that Dave has is the oversize tires will take more to stop, leaving you less for stopping the rest of the mass.
    Sep 2014
    Moneta VA
    if you want a cheaper upgrade to your rear brakes get some larger wheel cylinders.
    I don't remember the exact size but I used front wheel cyls on the back of my trike.
    They cost about $10-$15 or so and was easy to do.
    Be warned though I had to change the ends of the brake lines. My nuts were not long enough. But even with that I believe the entire cost was still under $50 (that was a few years ago so don't hold me to that price)
    Thank you
    Bob
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Actually that kit that I linked to includes shims to align the plate and caliper. That was one of the reasons I ended up getting that specific kit.
    However, as stated, there is nothing wrong with keeping the drum brakes.
    They worked just fine on the bugs for 40 years.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yes stinger.
    Just gotta know to use them shims and measure where and how much.
    I put mine on an early short axle swing.
    I bet they come real close to a bolt on swap on a later irs.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    It was very close. One side I had to use some of the shims but the other side was a direct bolt on swap.
  1. Drum to Disc Brake Conversion
    By stanley175 in forum Lehman Trike
    Last Post: 12-05-2023, 08:25 AM
  2. Disc Brake Conversion
    By stinger608 in forum VW Powered Trikes
    Last Post: 07-26-2015, 06:10 PM
  3. Disc Brake Conversion
    By joelin5386 in forum Harley Trike Conversions
    Last Post: 09-21-2013, 04:22 PM
  4. Disc brake conversion?
    By Carbon_One in forum Harley Trike Conversions
    Last Post: 05-18-2013, 07:15 AM
  5. Disc Brake Conversion
    By mcdonaldroadcapt in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-30-2012, 12:38 AM
