Likes Likes:  2
Results 1 to 7 of 7
Thread: VW Trike Speedometer Problems
    10+ Posts Triker Billy's Avatar
    Jun 2013
    White Creek NY 12057
    Default VW Trike Speedometer Problems
    Hi
    I have a problem with the speedometer on my VW trike.
    The wire pieces that bolt to the front wheel behind the gear broke off.
    Can anyone tell me how they work, can I replace them?
    It is an electronic magnetic type.
    I will try to attach better pic tomorrow
    Thanks TrikerBilly
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Do you know the name of the manufacturer of the speedo? Google them and see if there's a website, or dealer outlet. You should be able to get replacement parts for just about any of them. Or, post some pics of the set-up and broken parts. There's some pretty creative folks here, and they may be able to give you some advice as to how to make a replacement part yourself.
    Nice lookin' ride, by the way!
    God speed and ride safe!
    Jun 2013
    Default VW speedometer problems
    Thanks Doug
    I posted more pics.
    Bill
    Welcome to the Gang ... Nice Looking Ride ... The guru's in the VW forum are amazing ... I'm confident they can help ya out.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    As Doug stated, if we knew the brand we could probably find info on the parts needed Bill.
    And, that is an sweet looking Dub trike bro!!!!!!!!
    Jun 2013
    Default Problem Solved
    I just wanted to let you know, I figured it out.
    The wire and clips were mounted on the wheel just to turn the gear. Witch operated the speedometer. I just mounted a little nylon block on wheel to turn the gear. Nothing electrical. Thanks for the reply
    Bill
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    That's awesome man!!!!! Glad you got the issue fixed.
  1. Trike Installer Problems
    By jayhawkokie in forum Honda Trikes
    Last Post: 08-26-2014, 07:24 AM
  2. 3 Honda Trike Problems in same week
    By skibridg in forum Honda Trikes
    Last Post: 09-09-2013, 06:53 PM
  3. Trike Speedometer
    By onahog in forum Harley Trike Conversions
    Last Post: 06-08-2013, 08:32 AM
  4. Problems with Trike
    By wwcar1953 in forum Harley Trike Conversions
    Last Post: 04-12-2013, 06:32 AM
  5. dyna Trike 2001 speedometer and odmeter stopped working in mid rid
    By shelley.shumaker@gmail.com in forum Harley Trike Conversions
    Last Post: 07-16-2012, 01:02 AM
