Likes Likes:  2
Results 1 to 5 of 5
Thread: Spedometer using magnet on driveshaft. Or something. Need help!!!!!
    70+ Posts BMB Guns's Avatar
    Dec 2015
    Louisiana
    Default Spedometer using magnet on driveshaft. Or something. Need help!!!!!
    Ok. This post pertains to my deisel trike build... So, the Spicer 3053a has no output or anything for a speedometer. It's designed to feed a divorced transfer case and the speedometer is attached to it. I've seen speedometers that work with a magnet on the front wheel. I would really prefer something that would work off the driveshaft. I've seen analog, electric, GPS (not fond of the GPS idea), sending units that I have no idea what goes with what, etc. I'm totally ignorant to universal speedometers so any help that can be provided would be appreciated.
    The Warrior of the Wasteland! The Ayatollah of Rock and Rolla!... FYI: My 12 year old daughter drew my Ghost Rider on a trike Avatar for me! She's so talented!
    50+ Posts
    May 2014
    NH
    I used one of these. worked perfect for me and the price is right. http://www.ebay.com/itm/Motorcycle-O...tXQmpc&vxp=mtr
    Dec 2015
    Louisiana
    Quote Originally Posted by diver View Post
    That spedometer setup does look like a problem solver! It has everything! Only problem for me is that I have a Deteoit Diesel industrial engine instrument pannel that I really want to use. There is room in the front for me to cut a hole for a speedometer. I'd really like to use something that looks like this.
    Founder: Roadsmith Trikes
    TrikeTalk Sponsor
    May 2016
    Daytona Beach Fl
    Default Mr trike
    Quote Originally Posted by BMB Guns View Post
    Hello- VDO makes a 3 3/8" face speedo that works great. I have used hundreds of these in the VW application. On the VW, you JB Weld 6- 1/2" magnets on the CV joint equal distant apart then mount a sending unit so the face is within 1/4" of magnets. Run the 2 wires from the sending unit to back of speedo. Follow the directions in box to calibrate speedo to your tire diameter. This will work great as long as the 1/4" spacing is constant." Keep-On-Triken"
    Nov 2014
    loughman
    Default gps spedo
    Bought one on ebay. $70 no tripset. Works on anything.
  1. Spedometer Problem & Emergency Brake Problem
    By JohnT1949 in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-20-2016, 12:29 PM
  2. Hannigan driveshaft
    By bmw in forum Hannigan Trike
    Last Post: 12-15-2015, 05:04 PM
  3. Is a trike a chick magnet ? ?
    By Captain H in forum Trike Travel
    Last Post: 11-11-2014, 04:55 PM
  4. Trike is a chick magnet
    By jaxbobg in forum General Discussion
    Last Post: 01-03-2014, 09:53 PM
  5. driveshaft
    By sweat12 in forum General Discussion
    Last Post: 02-02-2010, 11:52 AM
