Likes Likes:  13
Thanks Thanks:  2
Page 2 of 2 FirstFirst 1 2
Results 21 to 34 of 34
Thread: TRUNK LOCK - turns but will not open the lid - HELP
  1. #21
    70+ Posts topsgt75's Avatar
    Jul 2015
    Lexington, Ky
    Quote Originally Posted by Finally Harley! View Post
    The service guy didn't mention the holes, but I asked about it. He said if it really bothered me, he could check with Harley to see what they might do. I don't think it bothers me, for now.
    See if the dealer can put a small rubber grommet in the hole!
  2. #22
    20+ Posts
    Dec 2015
    San antonio,tx
    Default trunk locked
    Glad to read, that it got fix. Just a suggestion for those who have not had the problem. Take a wrench and check the bolts that hold the bracket. Put the blue lock tied on the bolts and tighten them up. An easy fix before the problem begins. The rubber plug is a good fix as mention on the previous thread. Again glad to know that its fixed. happy riding!
  3. #23
    20+ Posts
    Jul 2016
    Simi Valley, CA, USA
    Thanks everybody! When you tighten and locktite the screws, also zip tie the cable to its bracket, as that is another source of latch failure. And the rubber plug is a good idea, but I also lol'd at the water in-water out perspective!
  4. #24
    150+ Posts
    Aug 2016
    Longview, TX USA
    Default Thomastrike
    Okay, so, HD dealer drilled a tiny hole in the trunk bottom, a tinier hole in the trunk liner, and fished around with a long screwdriver type thing until they made contact with the latch. Said it took 2 hours, but all warranty work. As mentioned in HDBOB posts, 1 of the 2 screws fell out, and the latch was crooked. The HD recommended fix? Lockite on the screws, and as a precaution, a small zip tie holding the cable to the cable bracket.
    Thx for the update.Would be a good idea to put locktite on those 2 screws now before something bad happens.
  5. #25
    20+ Posts
    Jul 2016
    Kansas City Is USA
    Checked bolts at latch and lock and bolts were just finger tight so took out and locktighted all bolts. Also put ziptie around cable at latch. From this thread would suggest you check bolts.
  6. #26
    Jan 2016
    Nashville, TN USA
    Hello again,
    Just got back from a ride, and my trunk lock turns, but will not disengage the lock to lift the lid. Of course, my purse, keys, cell phone, etc. are in the trunk, so I MUST GET IT OPEN!
    I read old posts about the screws coming loose and falling out, and the cable coming loose, but that's good info if you can open the trunk in the first place. I also read on old posts that there is no other way in the trunk except taking off the wheel and the fender. Hate that thought.
    Does anyone have a great idea? I tried pushing on the trunk lid, pulling on it, turning the lock, locking and unlocking the lock, etc.
    Thanks!
    Debbie
    Beat on top of lid hard and quickly causing the lock to move and turn loose. Then use lactate on screws that has fallen out.
  7. #27
    Jun 2019
    Wylie, Texas, USA
    Arrow Latch Repair
    Fixed the latch on my 2015 FLRT. Cause was a latch screw fell out and the other was very loose. I removed the right rear tire and fender. Using a 1 1/4” spade bit placed a hole in the trunk wall, and a minor hole in the liner from the spade bit point. Was able to easily push the trunk liner in, shine a light and use a small straight screwdriver and easily release the latch. Lock-Tite on both bolts and now good to go. Cover the hole with duck tape and is covered by the fender.
  8. #28
    200+ Posts
    Sep 2018
    Pa
    Default Duct tape
    Quote Originally Posted by Roosp View Post
    Eventually the tape will get wet or other wise leak at the most inopportune time. Just a quick search on amazon...50 Piece Flush Mount Black Hole Plug Assortment for Auto Body, or just go to your local auto dealer, the plugs are usually found in HELP section
  9. #29
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I noticed 1 loose last year, pulled them 1 at a time, cleaned the threads & used the blue Loctite on both & they have not moved since. I pretty much use it on everything on the Freewheeler, except the seat bolt.
  10. #30
    Sep 2023
    Camp Hill
    Default Happy Ending
    Just went through the inoperable trunk latch nightmare. After scouring the forums and learning what I could I tackled the problem. I got some heavy duty rubber foam (to protect the paint) and draped it over the trunk lid and body. I then took a dead blow hammer and gave the lid a few wacks while lifting up on the luggage rack. To my delight, the latch released and I could open the lid (Thank you Lord). One of the two screws holding the latch had fallen out and allowed the latch and cable to get mis-aligned. I glued a shim in the lower portion of the plastic housing and made a cable clamp to add when I reassembled the latch. Here are a few pics...
    I was VERY lucky being able to open the lid. I wish everyone the same if they have to tackle this job.
  11. #31
    Quote Originally Posted by Freewheeler2018 View Post
    Hey, Mark Welcome to Trike-Talk..........
  12. #32
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Welcome to Trike Talk Mark!
  13. #33
    300+ Posts
    Mar 2018
    Waelder, Texas
    Glad you got it open. Welcome aboard.
  14. #34
    Hi Mark, to Trike Talk and your first post
    Good fix, thanks for sharing
  1. Freewheeler Trunk lock
    By manny in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-24-2022, 01:41 AM
  2. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  3. Trunk lock cylinder
    By Dottie j in forum Stallion Trikes
    Last Post: 08-26-2014, 03:14 PM
  4. TG Trunk lock
    By Bones in forum Harley Tri Glide
    Last Post: 12-06-2011, 10:13 PM
