Likes Likes:  8
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 48 of 48
Thread: Tri Glide trunk lock
  1. #41
    100+ Posts
    Oct 2013
    Ohio
    Quote Originally Posted by NHBAGGER View Post
    Yup, my 14 door came open once. I quickly learned it takes a bit of a &quot;slam&quot; to shut it and then a tug on the handle to make sure it's shut.<br />
    At times the push button is a bit sticky, but no big deal.
    I agree my 14 has done it too
  2. #42
    250+ Posts
    Feb 2016
    Pelham AL USA
    Default This fixed mine.
    The first ride I took on my new 16 TGU was for about 100 miles. During this trip my trunk popped open 4 times. Needless to say I was not a happy camper. I tried closing slow and easy, slow and harder, and finally slamming it. When I got home I looked at my 2016 Trike Model Supplement Service Manual and found the process for adjusting it.
    Well I have tried to post this picture vertical (the way I took it) but something insist on turning it. Anyway, the manual says to adjust the height (2 in pic) to 1.050 inches. I played around with this a bunch of times and ended up at a measured dial indicator reading of 1.125 for mine. Now when I close it I just raise it up, then with my thumbs on the top corner on each side, I just push on both corners firmly and hear it click in. I keep it oiled (not too much) periodically and once or twice a year I squirt a LITTLE liquid graphite in the key hole. My trunk has not come open one time since I did this. I am a firm believer in the DON'T SLAM IT suggestions. Hope this might help some of you.
    Well I tried to delete the duplicate pic but couldn't. Sorry about that.
  3. #43
    1+ Posts Ektarr's Avatar
    May 2019
    Greer, SC, USA
    Default One more time...
    Hi...first post, thanks for having me. I found out today that my trunk lock broke, but reading through this thread it appears that what’s actually broken is the plastic shield/surround/sleeve that the lock set fits into. I imagine that’s an easier (and less costly! $160 +tax!) fix than replacing the entire lock assembly, but can someone walk me through the nickel tour of how to do it? Once I have the sleeve, and the lock assemble out and inserted into the new sleeve, how do I reinstall and assure that it doesn’t just fall out...which would be par for the course from me. Thanks in advance...
    P.S. ‘15 TriGlide
  4. #44
    Ed.........Welcome to Trike -Talk...........When you do get it fixed remember do not slam the trunk to close it ...Use just a gentle push, And when it clicks a slight tug to make sure it is in fact locked.....
  5. #45
    20+ Posts
    Oct 2017
    Spartanburg,SC,29307
    My 16 trunk lock just pulled out, black plastic ring had broken, I was getting for the Petty Ride, no time to order a new one. If you look in the hole, there is a horizontal strip of metal, press that piece with a screw driver and the latch will open. I bought a rubber cork at Lowe’s that is tapered and plugs the hole perfectly. On the trip, I used the trunk often with no problems, plug stayed in place. I never had locked the trunk, I may just leave it that way!!
  7. #46
    May 2019
    Greer, SC, USA
    Quote Originally Posted by Vtrod View Post
    I wasn’t locking the trunk either, until I found it was flopping open while riding UNLESS it were locked. So...
    I’m heading in to my local H-D pusher...I mean “dealership”...in the next few days to see if I can get that plastic ring replaced. I know others here have — maybe someone can share what I should expect to pay for such an item.
  8. #47
    I never locked the trunk or top box on either of my tri-glides A thief will do more damage moneywise to the locks than whatever you might have inside cost 😱📞
  9. #48
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I've started doing that also. If on a road trip I leave nothing of value in the tour-pak and only a few odds and ends in the trunk. Let them open and look rather that damage the trike.
  1. Freewheeler Trunk lock
    By manny in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-24-2022, 01:41 AM
  2. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  3. Trunk lock handle
    By adventurer 08 in forum Yamaha Trikes
    Last Post: 12-03-2013, 09:16 AM
  4. TG Trunk lock
    By Bones in forum Harley Tri Glide
    Last Post: 12-06-2011, 10:13 PM
