Likes Likes:  4
Results 1 to 16 of 16
Thread: Fuel pump help
    Jul 2016
    Birmingham
    Unhappy Fuel pump help
    The pushrod in my fuel pump is not straight up. It's leaning over to the side so how do I get it straight up again? It's a generator type 4 1/4"..
    750+ Posts Bruce's Avatar
    Sep 2010
    NY, USA
    Default help getting it straight
    Viagra ????
    Quote Originally Posted by Nighttrain View Post
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Sounds like the plastic push rod guide is worn out or broken.
    Jul 2016
    Birmingham
    I can't put the plastic guide on because the pushrod is canted over. The pushrod will not stand up straight to put the plastic guide on.
    Quote Originally Posted by Bruce View Post
    Viagra ????
    Tried that but it clogged my fuel line. lol
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Any type 1 I have ever seen the push rod is held in by the plastic guide.
    As in ..... the guide goes in first, then the rod, then the pump. Not counting gaskets.
    If you are trying to get the rod in first I suppose you are just lucky that it has not fallen through into the cam gear galley. Not much fun splitting a case just to fetch out a dropped part.
    You do have a type 1?
    Picture up so we can help you better.
    Jul 2016
    Birmingham
    Default Fuel pump help
    Thanks. I have been trying to put the pushrod in first. The guide goes first. Again thanks a million.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    If the plastic guide and block are not broke, then I would have to believe that the fuel pump push rod is bent.
    It would really help if you could take some pictures of the push rod laying flat on a surface and pictures of the guide block.
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    So I am just wondering why use a manual pump?
    I just put a block off plate on mine and I use a electric pump.
    Is there some advantage of a manual pump I am not seeing?
    Thank you
    Bob
    Quote Originally Posted by Fowler View Post
    Apples to Oranges .....
    I did that with all my Drag cars in the 60's.. The last one was on my 68 Charger 440 Duel pumper close to the gas tank..
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Don't forget the pressure regulator
    Sep 2014
    Moneta VA
    yep I have one on mine set to 3 1/2
    Thank you
    Bob
    10+ Posts mike hardigree's Avatar
    Mar 2016
    newnan,ga, usa
    Default help
    what kind of regulator are you using , having a hard time cranking mine after sitting after warm seems to be flooding electric pump no regulator.
    Sep 2014
    Moneta VA
    you can see it in this pic
    I dont know what make/model it is
    I think I got it from Advanced auto
    Thank you
    Bob
    Mar 2016
    newnan,ga, usa
    thanks so much bought one today hoping this stops my hard starting after she is warmed up and left setting 10 to 15 min.
    Mar 2016
    newnan,ga, usa
    installed the mr gasket regulator set at 3.5 30 min. ride let set 10 min. cranked right up not a good test yet but a lot better than what it was doing thanks again for the help.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by mike hardigree View Post
    That's great news so far Mike!!!!! Hopefully, that has cured your issue man.
  1. Air pump for RZ seat
    By OldFart in forum Harley Trike Conversions
    Last Post: 06-22-2016, 01:33 PM
  2. fuel pump
    By samsonone1 in forum Honda Trikes
    Last Post: 06-06-2013, 11:52 AM
  3. Fuel Pump
    By bigjoey38 in forum VW Powered Trikes
    Last Post: 06-12-2012, 12:55 PM
  4. Gas pump shutoff?
    By jimdog1356 in forum Harley Trike Conversions
    Last Post: 04-25-2012, 02:04 PM
  5. Ok,Gravity or electric fuel pump?
    By warnerrd in forum VW Powered Trikes
    Last Post: 10-15-2010, 10:46 PM
