Results 1 to 16 of 16
Thread: Custom rear rims for C90 Lehman jackal
    Aug 2016
    Wilmington, NC, USA
    Default Custom rear rims for C90 Lehman jackal
    I'm looking to see if anyone could give me any insight on where to buy new aftermarket custom rims for my 2008 C90 Lehman Jackal conversion. As I understand it the rear end is build after a 1978 Mustang II which is Four lug 4.25 pattern. Thanks in advance for any help you could give me.
    Quote Originally Posted by Jimbysea View Post
    Hi,Jim. I might be able to help you. What is your wheel size? 15"? Do you know the advertised width? Tire size?
    Just for info but that bolt pattern is also used on H-D TriGlides and Freewheelers.
    Aug 2016
    Wilmington, NC, USA
    Clint the rim is a stock Lehman it's 15x7 offset is 17.7mm backspace 4.719. I am thinking about moving up to a 16 inch
    Zero offset on a 7" rim equals 4" backspacing so your numbers sound correct,to me. With that amount of backspacing,that's a positive offset wheel. A lot of the 4x108mm (4x4.25) wheels I've looked at are negative offset. That may or may not make the search harder.
    Do you have any side shots of the wheels currently on your trike,that you can post? Can you post a photo of a wheel you would like to switch to? I've been working with some custom wheel manufacturers about building some four bolt wheels,for H-D trikes,but I'm sure we can build them for just about any application. It just kinda depends on one's budget.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    TriGlide wheel will set out too far and rub the fenders if it fits at all.
    http://mjtrikes.com/shop/index.php?m...index&cPath=87
    choose your poison. I also have chromed front wheels for C-90 too.
    Jim Murphy
    Iron Butt Rider 2001
    TG wheels are 15x5.5 and have 2.81" of backspacing. I only mentioned them because they are the same bolt pattern,Jim.
    What would a pair of those Centerline Razors cost? They look pretty spiffy.
    Just to add for those of you with a TriGlide or Freewheeler,those Centerline Razors wheels are in a 15x6, 15x7,and 16x7 sizing, with 3.5" backspace. All will fit your trike.
    Martinsburg, WV
    They were around $650.00 a pair (rear wheels)..... I don't know what they are now. Would have to call.
    http://centerlinewheels.com/wheel_deals_list.php
    Jim Murphy
    Any guess what a matching front would cost?
    I appreciate the info.
    Martinsburg, WV
    Default Matching front ?????
    ooffff......... over $1100.00.......
    Jim Murphy
    Billet front wheels are expensive,no two ways about it. I was guessing at least $900-$1,000.
    Is M & J still in business?
    Martinsburg, WV
    Default M&J ? In business ?? Still ???
    Quote Originally Posted by Clint44 View Post
    I still be there !!!!
    Just 2 of us and my recovery is going slow......
    Building a custom CVO trike as I write......
    Jim Murphy
    Sorry I missed you today,when I called.
    900+ Posts 03VolusiaTrike's Avatar
    Dec 2013
    Chicago, Illinois
    I found rear rims that fit my C50 at Jegs.com. Search by bolt pattern and check out what they have. Not a huge selection, but it is a little more than what you see normally, and they are very affordable. Hope it helps
    Never ride faster than your angel can fly !
    Martinsburg, WV
    But they are 17" or larger.....
    Jim Murphy
    Dec 2013
    Chicago, Illinois
    15x7 with a 4.75 backspacing, fit my trike perfectly. No rubbing at all. $120 each approximately.
  1. Lehman Jackal Suzuki C90 Rear End Fluid Change
    By Yogisan in forum Suzuki - Kawasaki Trikes
    Last Post: 04-08-2021, 07:18 AM
  2. Other Lehman Jackal riders?
    By dadorfman in forum Lehman Trike
    Last Post: 05-29-2014, 10:29 PM
  3. lehman jackal
    By jamieryder57 in forum Lehman Trike
    Last Post: 09-07-2009, 05:17 PM
