Likes Likes:  3
Results 1 to 6 of 6
Thread: Motor Trike Questions
    60+ Posts
    Jun 2016
    Windham, NH
    Default Motor Trike Questions
    I have a 2016 Motor Trike Razor on a 2004 Gold Wing.
    First, I seem to get exhaust "dirt" all over the back of the trike. I think it is because the exhaust does not clear the trunk. Does anyone else have that problem? Were you able to find exhaust extensions?
    Second, The rear wheel fenders seem like thy could be dressed up with chrome trim. Motor Trike doesn't offer anything like this for the Razor. Has anyone found chrome trim strips?
    Thank you.
    Don - New Hampshire
    2004 Gold Wing 2016 Motor Trike Razor
    May 2011
    San Angelo
    Quote Originally Posted by 3 for 2 View Post
    First, I seem to get exhaust "dirt" all over the back of the trike. I think it is because the exhaust does no clear the trunk. Does anyone else have that problem? Were you able to find exhaust extensions?
    Thank you.
    Here is a photo of the '06 Motor Trike I use to have. The exhaust turndowns (difficult to see well) should fix you soot issue. I used 1/2 in wide 3M peel and stick chrome trim over the wheel wells..
    Name:  06 Rear Ramps.jpg
    2015 GL1800/Roadsmith HTS1800
    60+ Posts
    Jun 2016
    Windham, NH
    Quote Originally Posted by Gold Rush View Post
    Thanks again Jerry. I appreciate your inputs.
    Don - New Hampshire
    90+ Posts lasso's Avatar
    Nov 2011
    Baskin, Louisiana, USA
    I had the same problem with the exhaust. Pulled the mufflers out and added 2" of pipe, on each side. The mufflers now stick out about and inch and half from the back of the body. No more exhaust soot.
    250+ Posts wehrme's Avatar
    May 2014
    Decatur, IL
    I have a '12 w/Razor.
    My tips extend about 2~3 inches past the end of the body... I didn't do anything to them.
    Maybe they changed the adapters that widen the pipes, and made them extend longer (?)
    Brother Mike
    50+ Posts
    Jul 2013
    Buffalo Lake Mn. USA
    For chrome around the wheel wells, I used 3/8 chrome car trim. Around the wheel well, to the rear, around rear, to the center. Has held up for three years, not very expensive, and easily curves and corners cuts with scissors. Can buy at auto parts stores.
  1. Razor Motor Trike Kit Questions?
    By netminder in forum Honda Trikes
    Last Post: 08-23-2022, 07:29 PM
  2. Sorry, More trike Questions............
    By mgwtrike in forum Honda Trikes
    Last Post: 03-20-2016, 08:30 PM
  3. New to me trike with questions
    By Warlock in forum Honda Trikes
    Last Post: 10-31-2015, 06:04 PM
  4. New Honda 750 Motor Trike Owner with Questions
    By dennisgb in forum Motor Trike
    Last Post: 05-29-2013, 04:33 PM
  5. Gold Wing Motor Trike Air Questions
    By skuuter in forum Motor Trike
    Last Post: 11-30-2011, 05:19 PM
