Results 1 to 14 of 14
Thread: Stallion U-Joint
    250+ Posts Dean H's Avatar
    Oct 2010
    Tampa, FL
    Default Stallion U-Joint
    A reminder to check and grease the U-Joint periodically.
    Dean - 480.734.7161
    Tampa, FL
    dean.hauser3@gmail.com
    '09 Stallion #643
    May 2011
    San Angelo
    Ouch!! Hopefully it wasn't too difficult getting that sucker out. Did it leave you stranded Dean?
    Get-er fixed and get out there!!
    2015 GL1800/Roadsmith HTS1800
    Oct 2010
    Tampa, FL
    Quote Originally Posted by Gold Rush View Post
    I was coming home from a rally traveling 75-80 mph. I started to feel a vibration thru the gas pedal and when I slowed down to stop for gas I could then hear the screeching sound. I limped it home and all fixed today. Easy to unbolt the u joints. It a ordinary joint so easy to find.
    Dean - 480.734.7161
    Tampa, FL
    '09 Stallion #643
    The real issue is trying to get grease in the joint. Very hard to get onto the fitting if you even due.
    20+ Posts
    Sep 2015
    Olney, TX
    I recently tried to grease my U-joints. I could not get the grease gun on the zerk. It just would not quite line up so I could. Have others had this issue? Maybe a different angled zerk or a skinny gun nozzle, if there is such a thing.
    John in Olney, TX
    White Stallion #142
    Oct 2010
    Tampa, FL
    Quote Originally Posted by Ployboy View Post
    John in Olney, TX
    White Stallion #142
    It appears a needle nozzle is needed:
    Dean - 480.734.7161
    Tampa, FL
    '09 Stallion #643
    20+ Posts
    Sep 2015
    Olney, TX
    Dean, thanks for that video. I'll get a needle injector for my gun.
    John
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    Quote Originally Posted by Dean H View Post
    Dean whats your milage now ?
    300+ Posts
    Signal Mountain Tn
    I have lubed mine twice in 56K. I put the bike on ramps, then jack one wheel clear so that I can rotate it and get a clear shot on each fitting. I have one of those injectors, but I was able to get on it with a standard grease fitting. I use the Ford long life grease.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Disconnected the drive shaft and greased mine yesterday.
    Tomg
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    Greased the U-Joint with the injector and it worked great. I wish everything worked that easy.
    Quote Originally Posted by Ed Hobgood View Post
    Ed can you please post a picture of the "injector" that you used. I've yet to find one to work for me.
    Jan 2011
    Dexter, MO, USA
    Ted, I got the injector at O'Reilly and the item number is PFM W54216 and it cost $7.99 I'm trying to send a picture but for some reason I've not been able to get it to download (to big).Name:  Injector 1 001.jpg
    How's the weather for you guys down there?
    Thanks ED Looks like just some wind for right now unless it turns.
  1. Which U-joint grease?
    By Mick in forum Honda Trikes
    Last Post: 12-25-2023, 08:24 AM
  2. Hem joint bearings?
    By gunny2426 in forum Stallion Trikes
    Last Post: 08-12-2015, 02:07 PM
  3. CV Joint Boots
    By michael2480 in forum Honda Trikes
    Last Post: 09-25-2014, 06:30 AM
  4. U-Joint?
    By Las Vegas Biker in forum Stallion Trikes
    Last Post: 08-20-2013, 01:34 PM
  5. U-joint question
    By bigbuck in forum General Discussion
    Last Post: 10-31-2010, 04:50 PM
