dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Jack Klarich2ISP-FLGeneral Harley ChatExhaust Heat Shield
gfaltersack4ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
Jack Klarich2Jack KlarichGeneral Harley ChatExhaust Heat Shield
Likes Likes:  14
Thanks Thanks:  1
Results 1 to 15 of 15
Thread: square exhaust
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Default square exhaust
    found this online and just thought these exhaust look cool
    Not sure how well they work though
    Thank you
    Bob
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Not sure how it would work either, but it looks badazz!
    "The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility, it's right. If it disturbs you, it's wrong until either the machine or your mind is changed." - Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Sampson tried it in Sturgis in 90 did not sell well
    Sep 2014
    Moneta VA
    but I wonder how well it works?
    Thank you
    Bob
    La Villa Strangiato MarkFL's Avatar
    Sep 2016
    St. Augustine, FL., U.S.
    Quote Originally Posted by Fowler View Post
    When a fluid flows through a pipe, the amount of frictional loss is largely due to the surface area of the pipe...a circle encloses more area for some fixed perimeter than does a square (or any other shape for that matter), so generally for the best flow, you want pipes with a circular cross-section.
    In this application, the difference may be so small as to be considered negligible...but that's the simple physics of it.
  6. #6
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I bet they would work pretty good. There was a video on youtube sbc new headers on a dyno. They wanted to see what the horsepower loss was if you dented the header during installation. They started with small dents nothin. Pretty soon they were beatin hell out them. Didn't show a power loss until they were almost pounded closed.
  7. #7
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    Quote Originally Posted by MarkFL View Post
    round has the best aspect ratio also square 45's 90's are not good for air flow i would always ure round if i could..
    mike aka magoo
    hd sidecar rig/building v6 supercharged trike
    "even a blind squirrel finds a nut once in awhile"
  8. #8
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    With the engine tuned at a set RPM they will work great...Like in a dragster...
    For varying RPM's....All the pipes would have to of be equal lengths ...
    Thats the reason for Spaghetti headers...If you were to straighten out all the pipes they should all end up the same length......
    2019 Tri-Glide.......
  9. #9
    Sep 2014
    Moneta VA
    I have been thinking about them lately since my Trike build is moving forward
    I would love to do it but would hate to spend the time and money and find out they do not work very well
    Thank you
    Bob
  10. #10
    Dec 2014
    Grand Junction, Co. USA
    The head loss in a square system would be significantly higher than round. Add the 45's and 90's in a square system and it would be really significant.
    Having said that, the head loss could be over come using much larger diameter piping ... been too long since I was in nuclear power for me to remember the calculations, but, they are general heat transfer and fluid flow formula's ... shouldn't be that tough to figure a square system that performs as well as a round.
    You'd also have to figure back pressure as well. We all know engines "need" some back pressure to perform well.
    Be an interesting project, and if your just overloaded with $$$ .. there is software that would do the work for you ... LOL ... being overloaded with $$$ is not now or has never been my issue.
    Just had another thought ... you could make a round system, then weld square tubing around it like a heat shield to make it "look" square.
  11. #11
    750+ Posts
    Jan 2010
    east windsor ct
    my bet would be unless you are racing wouldnt make enough difference to notice
  12. #12
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    google marine headers or manifolds. boats used 4.3's also...maybe something there would strike your eye!
  13. #13
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    I think the square tubes along with the sharp angles would slow down the exhaust gas and cause TOO much reversion. ( hot exhaust would re enter the cylinder) The intake charges would be drastically effected JMO
  14. #14
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    By the pix , it looks like the collector is the same size as the tubes. If so , it should be x2 min. Of the tube size. Doesn’t look like a performance viehical, so it don’t matter . JMO
    Show n Go
  15. #15
    750+ Posts
    Jan 2010
    east windsor ct
    Thumbs up
    Quote Originally Posted by 1dn5up View Post
    Show n Go
    exactly my thought most factory exhaust is 8 into 1 with short runner cast iron manifolds and the pipe is 1-3/4 or 2" from the manifold all the way to the tail pipe
  1. 5/8 EMPI square Master CYL rebuilt kit
    By Fowler in forum VW Powered Trikes
    Last Post: 10-29-2015, 08:17 AM
  2. Cutting Square Holes
    By David357 in forum General Discussion
    Last Post: 08-09-2015, 10:36 AM
  3. 69 Square back Trike to be...
    By Wyldeman in forum VW Powered Trikes
    Last Post: 10-13-2010, 06:20 AM
