Likes Likes:  2
Results 1 to 13 of 13
Thread: ***Limited Time*** 10% Savings Code on All DK Custom Lights
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Default ***Limited Time*** 10% Savings Code on All DK Custom Lights
    [CENTER]SEE & BE SEEN
    Save 10% on ALL DK Custom Lights
    Use Coupon Code
    Save-10 At Checkout
    Voice 662-252-8828
    Text 662-420-4891
    www.DKCustomProducts.com
    SAVE 10% On ALL
    LED Headlights - Passing Lights
    LED Run-Brake-Turn Lights
    Turn Signals
    Visor Headlights - LED Driving Lights
    STEALTH LED FRONT
    TURN SIGNALS/RUNNING LIGHTS
    SEE & BE SEEN
    [/LEFT]
    Special Saving Code valid through November 2, 2016
    www.DKCustom.com
    Sponsor - DK Custom Products
    TrikeTalk Sponsor
    DK Custom's Avatar
    Aug 2016
    Red Banks MS
    Multi-Fit Stealth LED Front Turn Signals /White Running Lights
    Kelsey
    Click HERE for NO MESS OIL CHANGES + COOLER RUNNING OIL -
    PHONE: 662-252-8828
    Text: 662-420-4891
    TrikeTalk Sponsor
    DK Custom's Avatar
    Aug 2016
    Red Banks MS
    Tri-Glide Tour-Pak Filler w/ Run-Brake-Turn LED Lights
    Kelsey
    PHONE: 662-252-8828
    Text: 662-420-4891
    350+ Posts Springman2007's Avatar
    Sep 2014
    Grafton, OH, USA
    OK,
    I have a 2015 FLRT Freewheeler. Which LED replacement Headlight bulb fits it? Part Number Please?
    Also, I am fitting my freewheeler with 4.5 auxiliary light this winter. Any LED bulb offering for them?
    Springman
    ...PS - a price break on a Lithium Battery would be nice.......
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Springman2007 View Post
    OK,
    Springman
    The bulb at this link will fit for the headlight-
    http://www.dkcustomproducts.com/Prem...-H4-HL-LED.htm
    • Item #: DK-H4-HL-LED
    The bulbs at this link will fit the HD aux lights-
    http://www.dkcustomproducts.com/Prem...-05-PL-LED.htm
    • Item #: DK-05-PL-LED
    On a discount for the battery....call or email the shop (see contact info below) they will be able to help you some, especially if you are getting other items at the same time.
    www.DKCustom.com
    TrikeTalk Sponsor
    DK Custom's Avatar
    Aug 2016
    Red Banks MS
    Tri-Glide Mud Flaps w/ Run-Brake-Turn LED Lights Built-In
    Kelsey
    PHONE: 662-252-8828
    Text: 662-420-4891
    TrikeTalk Sponsor
    DK Custom's Avatar
    Aug 2016
    Red Banks MS
    Premium White LED Bulbs for Harley Passing - Driving Lights
    Kelsey
    PHONE: 662-252-8828
    Text: 662-420-4891
    TrikeTalk Sponsor
    DK Custom's Avatar
    Aug 2016
    Red Banks MS
    OK,
    Springman
    You can use the H4 LED drop in replacement at the link below. The part number is DK-H4-HL-LED.
    http://dkcustomproducts.com/Premium-...-H4-HL-LED.htm
    Yes, if it is the HD Passing lights, that is the bulbs we have at this link below. The part number is DK-05-PL-LED.
    As for the battery we can't combine discounts. However, if you can give us a call at the office we will be glad to help you out with some sort of savings
    Hope this helps! Happy Friday
    Kelsey
    PHONE: 662-252-8828
    Text: 662-420-4891
    TrikeTalk Sponsor
    DK Custom's Avatar
    Aug 2016
    Red Banks MS
    Kelsey
    PHONE: 662-252-8828
    Text: 662-420-4891
  11. #10
    TOI - Idaho BinIdaho's Avatar
    May 2009
    Caldwell, Idaho
    Quote Originally Posted by DK Custom View Post
    Kelsey
    Kevin,
    Will these mud flaps replace the Tri-Glide mud flags I have installed on my '13? Is this an installation by the dealer and what wiring is required for the lighting? Thanks Barbara
    Barbara
    2020 HD Tri-Glide
    River Rock Gray/Black Accents
  12. #11
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by BinIdaho View Post
    Kevin,
    Hi Barbara,
    They do replace the HD brand Tri-Glide mud flaps...they share the same holes. You could have the dealership do it, but it is fairly easy to do in your garage or driveway.
    It comes with step-by-step instructions, including for the wiring. It is easy, and requires NO cutting, splicing or soldering of any wires. It comes with Posi-Tap connectors that connect into the factory wiring right under the seat.
    If you would like a copy of the instructions, email the shop and ask for them, we'll get them emailed to you.
    www.DKCustom.com
  13. #12
    TrikeTalk Sponsor
    DK Custom's Avatar
    Aug 2016
    Red Banks MS
    Savings end on 11/2 !!
    Kelsey
    PHONE: 662-252-8828
    Text: 662-420-4891
  14. #13
    TrikeTalk Sponsor
    DK Custom's Avatar
    Aug 2016
    Red Banks MS
    LAST DAY OF SAVINGS!!
    Kelsey
    PHONE: 662-252-8828
    Text: 662-420-4891
  1. ***Limited Time*** 10% Savings Code on New Dyna/Softail Coil Look
    By DK Custom Products in forum DK Custom Products
    Last Post: 08-29-2016, 04:20 PM
  2. ###Limited Time - Savings Code for International Customers - DK Custom###
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 12-18-2015, 10:29 AM
  3. ***Limited Time - 10% Savings Code on All Lights!***
    Last Post: 08-30-2015, 03:50 PM
  4. ****DK Custom Thank You ~ 10% SAVINGS On Everything ~ Limited Time****
    Last Post: 11-29-2014, 07:11 PM
