Likes Likes:  1
Results 1 to 10 of 10
Thread: M 8 Head Breather Rerouting
    Default M 8 Head Breather Rerouting
    M8 Head Breathers
    • Drill a hole 5/16th at the back of the stock air cleaner back plate.
      T the breather hoses off the head bolts
      Run the New line down the back of the backing plate out the hole
      Down the back of the engine and down under the oil tank
      That is where I put on the in line filter, I used a brake fluid master cylinder bleeder on the female end, the male end gets a plastic cap for draining
      And it works good, I got about a teaspoon of oil @ 150 miles today with 3420 miles on so far and Quicksilver 20-50 oil my first time EVER using synthetic oil
      The filter can be had for about 20.00, I have 2 of them so the new one became the sacrifice
    M8 Head Breathers
    I have since added a new filter with a drain on it
    200+ Posts
    Nov 2015
    palm bay
    Be very sure that the new breather can breath freely.
    Quote Originally Posted by vito View Post
    It does and easy to drain
    Final breather is done if y'all want I WILL POST PICS OR make y'all one cheap aint no business or looking to make a killing on this product
    5+ Posts aeroshots's Avatar
    Sep 2016
    Gulf Breeze, FL
    A teaspoon of oil per 150 miles seem a lot to me. My first thought is oil level. Don't get me wrong, this is just my thought. You may be okie dokie with it and that's okie dokie. I just completed the mod on mine and will be watching oil caught closely.
    By the way, the M8 vent modification is so much easier than my Softtail Slim S. I'm still looking for some very small fittings to thread into the vent bolts.
    gerald martin
    Guest
    Default Vent
    Pictures would be great thanks
    Quote Originally Posted by gerald martin View Post
    I have a new design again send me your e mail
    gerald martin
    Guest
    Default Venting
    Martingw@telus.net
    Got it
  1. Breather Tube Bypass
    By rcurnayn in forum Harley Tri Glide
    Last Post: 08-26-2016, 02:53 PM
  2. Breather Tank Install
    By msocko3 in forum Harley Trike Conversions
    Last Post: 03-11-2014, 04:06 AM
  3. 2014 Air Breather
    By Geezzer Glide in forum Harley Tri Glide
    Last Post: 08-30-2013, 06:34 AM
  4. Oil from breather
    By roadrumble in forum Harley Trike Conversions
    Last Post: 01-29-2012, 08:37 AM
  5. Loosing oil thru air breather
    By Rod69 in forum Harley Trike Conversions
    Last Post: 01-08-2012, 04:36 PM
