Results 1 to 4 of 4
Thread: Tri-Glide reverse motor breaker
    Jun 2010
    Coram, NY USA
    Exclamation Tri-Glide reverse motor breaker
    Just a semi-quick update on a new Tri-Glide reverse motor problem I just had. At 248 miles, the electric reverse seemed to have died. Still heard the relay closing.
    The dealer initially said the motor burned out. After they discussed it with H-D factory, It was found that breaker had PARTIALLY tripped. This allowed enough voltage to get through for the relay, but not enough to run motor.
    The solution was just to open breaker completely and reset.
    The factory mentioned to dealer that they have run across this a couple of times. I notice the owners manual mentions location of reset (right side, under seat, behind hard to remove plastic cover on my 2010 model).
    Hopefully this info will save someone the pain of having to leave trike at dealer.
    250+ Posts Shriner Jim's Avatar
    Apr 2010
    Greeneville, TN
    Default Re: Tri-Glide reverse motor breaker
    Too bad the moco doesn't offer a "gear-driven" reverse, like Champion?????
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Shriner Jim View Post
    HD doesn't but,
    AIM Corp*::*Reverse Gear Mamba
    BAKER Drivetrain | F6R
    Not much more than being gouged for some amenic electric motor!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    750+ Posts
    May 2009
    Down South
    I'm surprised that somebody at Harley actually admitted to having any problem at all. Not surprised that a HD mechanic can't tell if a starter motor is burned-up or not.
  1. Reverse motor repair
    By ehroyal in forum Harley Tri Glide
    Last Post: 09-07-2017, 10:53 AM
  2. Tri Glide Reverse Motor Falls Off!
    By Guiderider in forum Harley Tri Glide
    Last Post: 03-23-2015, 10:12 AM
  3. Reverse Motor
    By roadrageisfun in forum Harley Trike Conversions
    Last Post: 06-17-2012, 06:54 AM
  4. Reverse Circuit Breaker
    By Cap'n Pete in forum Harley Trike Conversions
    Last Post: 03-05-2012, 04:03 PM
  5. Where is the reverse gear circuit breaker located?
    By TaylorMcStrat in forum Harley Tri Glide
    Last Post: 08-20-2011, 06:55 AM
