Likes Likes:  3
Thanks Thanks:  1
Results 1 to 5 of 5
Thread: 2013 Stallion electrical problems
    Apr 2016
    Akron,OH,Summit
    Default 2013 Stallion electrical problems
    Our stallion has check engine light on and door open light on. The fuel gauge works but none of the other gauges work.
    My husband can't find any bad fuses. Has anyone ever had this problem?
    300+ Posts
    Signal Mountain Tn
    Quote Originally Posted by Rocky330down View Post
    There is a diagnostic plug under the hood around the oil filler. If a diagnostic tester is connected it should give you a trouble code. It is the same diagnostic
    tester used on most late model cars. If you locate the plug, Autozone and some other automotive parts retailers will connected their tester and check it for you.
    You can purchase a small tester for around $75. Good to have around. I have not seen that particular problem on this forum in over six years. Hope that you can locate the problem.
    maybe check behind the panel and see if everything is plugged in
    Feb 2019
    Swansea, SC USA
    I'm having the same problem. I suspect a problem with the computer not being grounded properly.
    Feb 2019
    Swansea, SC USA
    Default having the same problem
    I seem to have isolated it to the wiring harnesses and plugs on the left side between the power distribution bos and the instrument panel. also thought possibly a loose ground connection on the competer.... still troubleshooting though
  1. I want to sell my 2013 Stallion
    By nklosterman in forum Stallion Trikes
    Last Post: 04-15-2017, 09:35 AM
  2. 2013 Stallion
    By Clell12 in forum Stallion Trikes
    Last Post: 05-10-2016, 01:27 PM
  3. Electrical problems - horn, cruise control
    By gctrikeguy in forum Stallion Trikes
    Last Post: 07-23-2011, 07:21 PM
