Results 1 to 4 of 4
Thread: Roadsmith Trike brake question
    Jul 2010
    California MO USA
    Default Roadsmith Trike brake question
    I have a 2003 Gold Wing 1800 with a Roadsmith Trike kit done last year. I don't seem to have enough rear tire brake. Shouldn't I be able to "lock up" the back when braking for emergencies?
    It has the stock master cylinder--or do I need a bigger master cylinder for the back? Someone mentioned this, but I am not sure.
    I think the brake seems soft when I have to stop hard.
    TomWine in MO
  2. Roadsmith banner
  3. #2
    Jun 2010
    Indianapolis, In.
    Default Re: Roadsmith Trike brake question
    If it seems soft, that's an indication bleeding and possibly a top off of fluid is needed.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  4. #3
    Aug 2010
    Lorena, Texas
    Make sure your installer raised your brake lever up a couple of notches. And yes there are many Trikeshop owners having brake issues. Contact Trikeshop. Great folks ot deal with and they will stand behind their product. No complaint at all about customer service, just design issues. You will probably need to rebled the brakes and have the residual check valve replaced to cure your problem. Yes your rear brakes should lock up. Not always a good thing but yes they will.
  5. #4
    300+ Posts mpolissky's Avatar
    Jun 2009
    Boynton Beach, FL
    I had the same problem and it was resolved by the Trikeshop within an hour at no charge to me. They replaced the residual check valve and rebled the brakes. Now the pedal feels great
    GL1800 with 2009 Roadsmith Trike Conversion, Traxxion Suspension and much more...
  1. Roadsmith HDT Brake rotor
    By tinker in forum Roadsmith Trikes
    Owners Forum
    Last Post: 04-03-2023, 01:23 PM
  2. Roadsmith Trike question
    By coolpoolken in forum California Sidecar Trikes
    Owners Forum
    Last Post: 08-20-2017, 06:22 PM
  3. Parking brake for the Roadsmith
    Last Post: 03-20-2013, 10:45 AM
  4. Roadsmith question
    By steve047 in forum Honda Trikes
    Last Post: 11-29-2012, 07:12 AM
  5. GL Brake Recall -- Roadsmith Trikes
    By kerr88 in forum Honda Trikes
    Last Post: 12-10-2011, 02:36 PM
