Likes Likes:  5
Results 1 to 8 of 8
Thread: Squeaking noise
    I have a knife addiction..
    Gone2Three's Avatar
    Aug 2016
    Pflugerville, Tx
    Default Squeaking noise
    So maybe this is nothing but just have to ask... for the past week when coming to a stop my breaks squeak. Not bad but you can definitely hear it. I've read about this problem for the Tri, but didn't know if it's common in the Freewheeler. Thought it might be due to temperature changes since it's warm in the day and cool at night. Any chance that's he case? Also I do a lot of stop and go in my commute due to the traffic situation so I'm sure this doesn't help
    Jun 2010
    Indianapolis, In.
    Nature of the beast! Cure it on my Ultra by using EBC organic pads.
    You may need to deglaze your rotors by doing some hard stops!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    I taught Brake class for 30 years, that said it is the biggest complaint around
    I have solved some and lost some
    You need to clean ALL the hardware clean the rotors with hot soapy water
    Re sand the face of the pads
    DO NOT use any chemicals on the friction
    Apply dilectric grease
    To all pad backing plates and slider areas, no guarantee but it will cut the noise
    450+ Posts Bill G's Avatar
    Mar 2015
    Bakersfield California USA
    Take an air compressor with a blowing tip on the hose and blow out all the brake dust real good in your brake calipers and around your brake pads. (Front and rear).
    I do this on a regularly. I also clean and detail my trike regularly this is part of my routine. I also own a nice air compressor a must have for many reasons.
    Brake dust build up can cause squeaking.
    Ride Safe All,
    Bill G
    Through Jesus Christ, I a sinner am saved. Not by my doing but through his doing by his sacrifice and Blood Shed on the Cross. His gift to all mankind that will only believe and accept him by Faith. Through his Death and Resurrection I am Saved by Grace and someday I will be with our Lord in Heaven forever.
    Gone2Three's Avatar
    Aug 2016
    Pflugerville, Tx
    Got it!...probably going to start with the compressed air since it's the easiest. Then go from there.
    Quote Originally Posted by Gone2Three View Post
    Dont want to be a wise guy but that is just a band aid on a broken leg, not sayin I am 100 per cent but your noise will not go away for long plus the dust gets on everything wear a mask and gloves and eye protection
    Mar 2015
    I don't mean to be a wise guy. But the practice of keeping the brake dust blown out or washed out is a good one. It's a good maintenance practice. Quite often brake dust build up can cause squeaking issues and is the only culprit of the squeaking. Sure there could always be another issue at hand causing the squeaking in the brake system. Why do you think old brake mechanics back when there were more drum brakes around would pull the drums and blow out the brake dust.
    The brake dust just blows away it's a dry powder. Yes wear a dust mask, not a big deal and common since.
    Ride Safe All,
    Bill G
    Quote Originally Posted by Bill G View Post
    Ride Safe All,
    Bill G
    .....Go to the obvious thing first...[Occam's Razor]
  1. another new noise
    By starrider1946 in forum VW Powered Trikes
    Last Post: 10-15-2016, 11:07 PM
  2. Noise above 60 mph
    By Kentosh in forum Honda Trikes
    Last Post: 07-18-2016, 10:55 AM
  3. 2012 Goldwing CSC Viper Squeaking ??
    By MrCement in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-18-2015, 03:41 PM
  4. Noise With the BT-45
    By FRR in forum Honda Trikes
    Last Post: 05-09-2015, 06:21 PM
  5. Squeaking front suspension...
    By pmar6004 in forum Stallion Trikes
    Last Post: 09-16-2011, 01:22 PM
