Likes Likes:  5
Results 1 to 9 of 9
Thread: Trunk Lock ?
    150+ Posts mirider's Avatar
    Jun 2015
    West Michigan
    Default Trunk Lock ?
    Have a strange problem with the trunk lock on my 14' TG. When not locked, the door stays closed when riding down the road but when locked, it tends to pop open. This has happened twice now, I was notified by a passing motorist the first time but the second time I didn't know it til I stopped. Anyone have this problem or have any ideas on why this would happen? I've treated the lock with a lubricant and it doesn't seem to be sticking.
    Dave
    14 HD Tri Glide
    H.O.G. Member
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    Want you to try something. Gently shut your trunk until you hear 1 snap and then push a little harder 'til you hear a second snap. Then lock the trunk.
    See if that cures your issue.
    8~\o
    1000+ Posts
    Aug 2016
    Des Moines IA US
    I would do as Texan said but another thing, don't slam it, have seen more broken latches because of this, it is just a plastic ring of some sort.
    All for now Trampas
    I had that happen a few times when i first got my 2011, What i found that the the spade-pin on the door was not letting the locking mechanism fully seat into the groove [bearing] in the pin [Dropping in like a Guillotine] and letting it slip off... 5+ years now and it hasn't popped open ....If the pin is out to far it will hit the stop and push out a little and then not allow the lock to fully seat in groove [bearing].....Without locking' The guillotine will stay spring loaded and with body movement fall into the groove... When Locked it will if not adjusted pop open when the trike hits a sharp bump....
    1000+ Posts screwball's Avatar
    Santa Clarita, SoCa & Bullhead City, Az
    Wife had the same problem with her '08 and '11. Cure was WD-40 on the lock mechanisms both push button and latches. Also, when you close the door, grab the handle and give it a couple of tugs. No problem on her '14
    good luck
    http://www.triketalk.com/forum/custo...epic4494_1.gif
    Why 3 wheels?
    because 2 isn't enough and 4 is too many
    We are really Steve & Vesta Brown
    Her: 2014 Tri-Glide Me: 2015 Freewheeler
    Vietnam Vet 1967-68 U.S. Air Force
    White Lithium grease and check the adjustment
    100+ Posts 470004's Avatar
    Sep 2013
    Astoria, New York, USA
    I had the same problem with my 2013. When closing the trunk door, I now push it gently until I hear a click and then push it a little harder to make sure the latch is caught.
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Default trunk lock
    I think Motor Trike has the best I've seen system. Harley you have a fubar here fix it hint, hint
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    The latching pin (with groove for retaining disc to lock into) may need adjusting in/out.
    I regularly lube my button with Tri-Flow gun oil. I also gently push until I hear a click. The click is the locking disc sliding into the locking groove. 1/16" of metal to metal contact is all that holds it shut.
    If you are worried about it coming open .... get a small bungee cord and wrap it several time around the door support cables while closing. The bungee around the support cables will keep it from coming COMPLETELY open.
    2014 with 26K miles and no trunk lock issues ..... "touch wood LOL".
    Bob
  1. Trunk lock ??
    By Beorn of Ga in forum Harley Trike Conversions
    Last Post: 01-08-2017, 12:55 PM
  2. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  3. Trunk lock cylinder
    By Dottie j in forum Stallion Trikes
    Last Post: 08-26-2014, 03:14 PM
  4. Trunk lock on Hannigan kit
    By motoadvrider in forum BMW Trikes
    Last Post: 04-24-2013, 08:04 AM
  5. TG Trunk lock
    By Bones in forum Harley Tri Glide
    Last Post: 12-06-2011, 10:13 PM
