Likes Likes:  250
Page 5 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 81 to 100 of 203
Thread: SBS Project - Sportster Chop w/ Lots of Photo's
  1. #81
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    We got the tank pieces laser cut, and the bungs came in from Bung King.
    Here are all the parts laid out...
    ...what goes where.
    Today we are just going to tack everything together, making sure it all fits.
    Before starting we coated the threads in anti-sieze and put bolts/fittings in to keep the threads from deforming while being welded.
    The four tophats are the only pieces that will be fully welded on the inside. They will also be welded fully on the outside. These 4 points are where the tank will be rubber mounted to the skid plate.
    Tacking in the drain plug bung.
    Don't laugh...or go ahead, it is pretty funny. The last time I welded was 42 years ago!
    Devin held the 1st side plate in place while I tacked it. Not pretty, but it held.
    btw, I've shared this before, but....
    The way that DK Custom Products got started was when I (the "K" in DK) had an idea for some Custom Handlebars. I had several shops that said they would weld them up for me...NONE of them had even started them within weeks of when they said they would be finished with them.
    Devin (the "D" in DK) was, at the time, engaged to my daughter. On a flyer I asked him if he could weld them up for me. He said sure...AND, he had them done pretty quickly!
    I had a few other ideas for parts...he made them up. Then other folks started asking for parts, and it grew from there.
    More on the oil tank in next post.
    www.DKCustom.com
  2. #82
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Oil tank continued...
    After tacking in the second sideplate we put in the first cross plate.
    Everything is square!
    Backplate tacked in....
    L-Tray tacked in...
    Looking at how the filler bung will be placed. Have some cutting to do, plus we'll be welding the entire tank before welding this big bung in.
    Top piece...
    Corner piece. This part of the tank is "cut-out" to accommodate the curve in the frame rail on the low side.
    All tacked together, and square.
    From an idea, to a card stock mock up to....
    ...holding it in place on the bike....
    How it sits now. Gotta weld it up, and do the skid plate...but hard part is done.
    www.DKCustom.com
  3. #83
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Wow, it has been almost 2 weeks since I've done anything on this build. I have NOT lost interest in it. We've just been very busy.
    I have this coming Friday afternoon blocked out to do some work on it. Will be updating soon after that.
    www.DKCustom.com
  4. #84
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Last Friday we had some time (not as much as we hoped) to make a little progress on the SBS Chop bike.
    Oil tank is sitting right where we left it 2 weeks ago-
    Tacking a little holder ring to the corner piece...
    ...so we could hold it in place while tacking it to the tank.
    All done-
    Even though the seams are not at a 45*, we are beveling one edge so that the welds will look centered.
    It begins...
    ...turned out nicely. We are going to be doing some pressure testing when done, fix any leaks, then we will clean everything up before powder coating.
    Continued in next post.
    www.DKCustom.com
  5. #85
    Meme Master
    Jan 2014
    Farmington, NH USA
    Man, that bike is going to be totally tricked out & cool when done
    Great job so far, Kevin!
  6. #86
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Oil tank continued-
    Another weld done. We are doing these for strength/seal and trying make them so that they have enough meat to spend some time to make them look good too.
    All done with the seams, except for one last on in the corner bottom....
    ...cleaning it up just a bit, looking for any obvious points that might leak.
    Time to get to work on the bungs...
    hahahaha, I have no idea what I'm doing...only the second or third time I've welded in the last 40 years.
    All done for the day....
    ...going to do the fill hole and tank skid plate next time we have some time to work on it.
    www.DKCustom.com
  7. #87
    Apr 2013
    Redmond
    Oil tank continued-
    Roger
  8. #88
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by geezerglide11441 View Post
    Roger
    Thanks guys!
    www.DKCustom.com
  9. #89
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Yesterday afternoon we had a bit more time to work on the bike.
    Pulled it out...
    ...onto the shop floor. We need to do some welding on it.
    This is a combo mounting plate/skid plate...
    ...that the tank sits on. The one hole is for access to the drain plug. The others are for air circulation. It is fastened in the 4 corners...
    ...and rubber mounted.
    Getting it lined up in the frame...
    ...and level.
    The angled bottom of the tank follows the same line as the rails.
    Ready to start tacking it together.
    Cutting some metal for the front skid plate brace.
    www.DKCustom.com
  10. #90
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Put a few holes for air flow in the front plate support bracket.
    Tacking the front support bracket and the two side support brackets to the frame and the tank mounting plate.
    It's tacked in pretty solid for now....
    ....the next time we pull the engine out we will fully weld all three support brackets to the frame and the mounting plate.
    Last step...
    ...figuring the angle for the oil filler bung.
    Tacking it in place, so we can check the angle one more time on the bike.
    Looked good, so here we go....
    All welded up.
    I need to get some fittings, clean out the inside of the tank, and then do some pressure testing. If there are any leaks, we'll fix them, clean and test again.
    Hope to have time to work on it some more later this week.
    www.DKCustom.com
  11. #91
    Meme Master
    Jan 2014
    Farmington, NH USA
    Is there a "dipstick" on the filler cap?
    I'm curious, as the angle it enters the tank looks steep
  12. #92
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    No dipstick.
    Harley's are a remote system. How much oil is in the tank is irrelevant to lubrication and oil pressure, as long as it is not too low...there is a wide variable between "too low" and too high. I will be able to see down in the filler hole enough to make sure it is in the "safe" zone fill wise.
    www.DKCustom.com
  13. #93
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Had a few things progress the last few days-
    Got the battery in...
    ...so now we can start thinking about options of a tray and securing it into the tank shelf.
    Had to send the handlebars back...they arrived with quite a few scratches and some poor chroming.
    Just got the replacement in yesterday. I peeled back a bit of the protective foam and what I saw looks good/better than the last set.
    Will check it out more thoroughly after I transport them to the shop.
    Tested out the new mount we made for the floorboards on the DK Sporty. Looks good, so now we will go from the plastic printed mount to machining it out of steel.
    That's all the photo's right now. We did spend some time on the jockey shift and foot clutch designs this last Friday. Will hopefully have time this next week to make some progress in that arena.
    www.DKCustom.com
  14. #94
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    This showed up on my desk today....gotta love these new plastic printers.
    Tomorrow we should have some time to test fit it.
    www.DKCustom.com
  15. #95
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    This last week was BUSY!
    We did get to spend a bit of time on the Sporty chop.
    Here are a few pics of the 1st Gen Jockey shift we made with the 3D printer.
    Shift arm added-
    We did not like how the pivot arm was so far forward up top. So we made a different pivot arm that is more upright on top.
    Another view-
    After much looking & playing with it, we decided we did not like it at all.
    We made the following decisions:
    1. The S-shaped shifter arm is cool (to us), but it sticks out too far. It is being redesigned with 1 less curve in it.
    2. The main bracket (XXXX) is too big and ugly. A smaller one is being designed and will mount up at A & B points shown in the photo below.
    3. The whole concept of a pivot arm (Y) & accompanying shift lever plate was interesting, and different, but in the end it was too busy, & has leverage challenges. So we are starting fresh, and we'll have a simpler design printed out soon.
    After putting that to bed, we spent a couple of hours looking for fresh ideas on a foot clutch. We came up with a few different drawings (can't find the photo's I took of them), but we still have not settled on one.
    We even spent about 45 minutes studying how the cams on a compound bow works, seeing if we want to use something similar in the foot clutch design.
    We did come up with one steampunk style design that is pretty cool, but I don't want to use it on this particular bike where I am trying to keep everything as clean/simple looking as possible.
    Any ideas, photo's or drawings are appreciated.
    www.DKCustom.com
  16. #96
    Meme Master
    Jan 2014
    Farmington, NH USA
    They look fairly rugged as is, so making the main bracketry smaller might compromise overall durability?
    Perhaps you could make the final renditions out of stainless plate, with some type of ball milling or other decorative machining to make them more eye appealing without attracting too much attention away from the rest of the build?
    Keep up the good work!
  17. #97
    Mar 2015
    Warrenton, VA, USA
    Shift arm added-
    Another view-
    What about combining the Shifter Arm and Pivot Arm (Y) into one piece. That would make it less busy and may take care of some of the leverage challenges.
  18. #98
    Meme Master
    Jan 2014
    Farmington, NH USA
    Quote Originally Posted by rallsqh View Post
    My engineering degree is still yet to be had, but rallsqh's suggestion sounds reasonable. Less is sometimes better.
    It might take a try or 2 to get the shifter into its "ergonomically optimal" position, so the 3D printing perhaps comes into play from a financial standpoint as well...
  19. #99
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Great minds think alike!
    www.DKCustom.com
  20. #100
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    All this stuff from Version 1.0 .....
    Replaced with these two pieces from Version 2.0
    Will be testing it out later this week, along with some clutch ideas.
    www.DKCustom.com
  1. DK Custom PROJECT TRI-GLIDE Report w/ Lots of Pics
    By DK Custom Products in forum Harley Tri Glide
    Last Post: 03-04-2019, 05:50 PM
  2. pork chop at patties settelment . Grand Rivers KY.
    By tom w in forum BBQ, Grilling, Cooking, Recipes
    Last Post: 09-18-2016, 05:42 PM
  3. Lots of Goodies for Sale
    Last Post: 01-17-2016, 10:32 AM
  4. Lots of extras
    By 01winger in forum Accessories
    Last Post: 12-13-2010, 09:23 AM
